Travel assist retrofit
Thank you for your answer@JustOxy
I have just noticed that you own the RS version (Three arms steering wheel).
I was searching the web to find a steering wheel for my car (Style).
There are few models available on the market. PN: 5E3419093 XX XXX
If I understand correctly 5E3419093 stands for the wheel itself and XX XXX stands for some other options.
I was tying to decrypt these letters...
A - these are without DSG paddles, without heating, without Travel Assist button
AE, AA - these are wheels without DSG paddles, with heating
AR - RS type, with DSG paddles, with Travel Assist button, with heating
AG - RS type, without DSG paddles, with Travel Assist button, with heating
AF, AP - these are with DSG paddles, with Travel Assist button, with heating
Do you know any explanation of these letters?
What does these three last letters mean?
There are mostly VKH and VKH letters at the end of the serial numbers.
Will three arms RS steering wheel fit to my Octavia Style?
@East_Yorkshire_Retrofits
Thank you for information.
Unfortunately, there is only one function on demand available in my Skoda store - additional ambient light colors....
In this case should forget about this feature 😞
BR
Mati
  • Replies 162
  • Views 71.4k
  • Check if all below is done :   Select Driver Assistance A5 - Select Long coding - Select KLR - Set to Coded - Select Point of intervention - Set to Early - Select HC Warn Intensity -
  • East_Yorkshire_Retrofits
    New wheel isn't covered under warranty. Rest of the car should be unaffected    Ensure you replace the bolt that secures the wheel, and torque it correctly. Also ensure you don't mark/damage
  • Update from my last post. It appears I forgot to add the following changes A5 -> Hc_Variante: 2 A5 -> Klr: Enabled. This one will enable capacitivesensors.   Travel ass
Has anyone any idea how changing the steering wheel will effect your warranty
  • Sponsor
Ensure you replace the bolt that secures the wheel, and torque it correctly. Also ensure you don't mark/damage the airbag when removing - give them 0 reasons to invalidate other parts warranty
Thanks for the info. I’ve ordered an OEM  5E3419093AE VKH heated steering wheel from cars-equipment.com complete with the capacitive module. Hope it arrives in good condition.
Edited by mitchec
  • Sponsor
It's possible to buy modified units to fit to your canbus gateway which remove the need for the capacative module on the wheel. Also allows for unlimited no hand contact (not that this is safe)
Those of you fitting heated steering wheels will require additional wiring and a new slipring.
Edited by East_Yorkshire_Retrofits
Hi all. Got my capacitive steering wheel. After disconnecting the air bag module I’ve noticed there is an additional yellow and brown  wired connector on the capacitive wheel which I don’t have on the one already fitted. Although I’m not sure I assume it’s for the heated wheel ?
anyway after changing the wheel over and refitting everything I got a load of errors after reconnecting the battery which is supposed to be normal, along with errors on the lane assist and travel assist.
After updating module 13 to add the capacitive steering wheel ( I’d already updated the other modules) I still had a problem with with lane assist which would not activate using the steering wheel button. I also got a load of additional options for travel assist in the assist system screen of the infotainment system. Previously there was only steering feedback.
after taking the car for a short drive all the faults on the dashboard cleared along with the lane assist fault which I could now select.  Note all the previous options I had in travel assist had now gone just showing the original steering feedback.
I cant honestly say it was worth all the effort.
Without changing the steering wheel I already had managed to get travel assist working all be it with an annoying message on the dash to take control, only cleared by slightly turning the steering wheel. I was assuming this was due to not having a capacitive module in the wheel.  With the new wheel I was expecting to be able to just have my hand on the wheel without having to make any physical input to the steering.
Can anyone who has done this mod please let me know if you have multiple options in the travel assist section of the assist screen.
cheers
Edited by mitchec
  • Sponsor
Can anyone who has done this mod please let me know if you have multiple options in the travel assist assist section of the assist screen.
cheers
Capacitive wheels require a good amount of contact between your hand and the wheel. You can't gently rest/loosely hold it. They're annoying as hell
You'd have been better off getting one of the modules that are fitted to the canbus gateway. Usually much cheaper and you can hold the wheel as loose/tight as you fancy
cheers
Travel assist now appears to be working fine and not getting any warnings regarding hands on the steering wheel.
Only thing I’d like to get working is the Travel Assist options on the main Assist screen.
On reflection changing the steering wheel was worth the effort.
  • Sponsor
How tight would you say you have to grip it for it to be happy? I'm now wondering if my formentor wheel was one of the early problematic ones 🤦‍♂️
The required force depends a lot on the moisture of your skin and ambient moisture. Yesterday I could drive with only my left hand gently gripping the lower left quadrant. Other times, when the air has been dry, I've had to grip it harder and even add a touch of my right fingers to the lower right quadrant.
Very lightly. Basically if I just rest my hand inside the wheel next to the bottom Placket/Badge don't get any warning.
On 26/03/2022 at 12:39, JustOxy said:
Update:
I went for it and bought a new steering wheel with capacitive sensors inside it.
Mounting it pretty easy, there are some videos on YouTube. You'll just need a M12 Spline to unscrew it.
Coding is also simple, no SFD unlock required:
Control Unit 13->Long Coding-> byte 2 -> Capacitive_steering_wheel - Enabled.
A5 Driver Assistance - Long Coding - HC_Warn_Intensity - Setting_over_Menu (activates the Travel Assist menu in the interface)
A5 -> Klr: Enabled. This one will enable capacitive sensors.
With these options travel assist will be available
Hi. Could you give me an indication what options you have in the Travel Assist menu in the infotainment screen. All I have is steering feedback
Edited by mitchec
  • Sponsor
I had my formentor for a year and it always wanted just a slight bit too much force applied grip wise. There were some that required replacement early on, I've a feeling mine may have been one of those despite not hitting the requirements
Good to hear Skoda aren't having the same issues
Anyone
  • 4 months later...
Hi,
Can you provide more details about this external unit and how to connect it?
Is the below product a good example of this unit?
https://www.aliexpress.com/item/1005004670611624.html?gatewayAdapt=4itemAdapt
Thank you
  • Sponsor
On 28/11/2022 at 14:51, djmartzian said:
Hi,
Thank you
This isn't compatible with MQB-Evo as the gateways are different. You may get away with fitting it elsewhere as it only requires power, ground & connection to the correct lin-bus. However the MQB-evo KLR modules are different so I'm unsure how you'd get on
Thank you for the info. It's better to retrofit the capacitive steering wheel rather than produce any electrical issues/faults. 🙂
Can someone explain to me what it's the difference between Hc_Variante: Variante_0(coded from factory) and Variante_2(need to be changed accordingly to the above instructions)? Is this coding mandatory for capacitive steering wheel only?
Finally, I found a capacitive steering wheel on eBay in a very good condition, so I went for it. Installation is quite easy, today I did the testing and and it's working fine.
Just for the sake of clarity, it's true that control modules 13 and A5 are not SFD locked modules but security access code is needed. For both of them, security login code is 20103.
Hi Guys,
Does someone else change the steering wheel on an Octavia E-TEC with 48V battery?
Based on the procedures you MUST to disconnect regular 12V battery earth strap before removing the driver airbag. But also you MUST de-energize the 48 V system using vehicle diagnostic tester before un-pluginging  the connections.
This is mandatory for safety reasons because, the 12 V system is powered by the voltage converter, 48 V /12 V -A7- of the 48 V system. For this reason, the 12 V system can only be de-energized if the 48 V system has first been de-energized.
On a quick look on the OBD11 app, I can't find any procedures/apps to do this? Access to ODIS diags it seems necessary in my case.
Any advices will be highly appreciated.
Thank you
Hi,
I've found an Steering Wheel vRS model in a very good condition.
I've installed and tried to code it by following the above procedures but I did NOT manage to enable the capacitive function in Control Unit 13:
Control Unit 13 - Adaptive cruise control - Long Coding
When I've change the option to Installed (I don't have the option Enabled) an error have been returned by the OBD11 App -> "Something was wrong!" something similar to a not supported function.
I've also had a permanent error in Gateway Module: "U112500 - Local data bus error - Aditional installation detected".
What I've did wrong? Does the Adaptive Cruise Control unit is NOT supporting this function?
Any advise will be highly appreciated.
Thank you
  • Sponsor
36 minutes ago, djmartzian said:
Hi,
Thank you
You need to code the Canbus gateway so it's aware the KLR is installed
Can't comment on the coding issue you're having as I've never used obdeleven
On 06/05/2022 at 22:45, East_Yorkshire_Retrofits said:
Yes traffic sign can be activated. However, if it isn't available in the skoda store then it's expensive as hell
Can someone with the Travel Assist fully function can share the Long Coding and Adaptations values for the Can Gateway module, please?
- Select KLR
- Set to Coded
- Set to Early
- Set to Setting_over_menu
- Select HC variante
- Set to Variante_2
- Select Adaptive cruise control 13
- Select Capacitive_sterring_whell
- Set to Installed
- Select Travel Assist
- Set to Activated
- Select Gateway 19
- Select Adaptation
- Select Specified installation of sub-bus users
- Select Control module for sterring whell touch reconition
- Set to Yes
Last one needs sfd, I have skipped it an despite having same error U112500 it all works.
- Select KLR
- Set to Coded
- Set to Early
- Set to Variante_2
- Select Long coding nu
- Set to Installed
- Set to Activated
- Select Gateway 19
- Select Adaptation
- Set to Yes
Thank you mate.
With your suggestions I've managed to get rid of U112500 from Gateway 19 module.
But, Adaptive Cruise Control 13  does NOT accept my coding for the capacitive steering wheel, nor for Travel Assist. I've received the same "Something went wrong!" Error.
Details about my module:
System Description: ACC Bosch MQB
Hardware version: H20
Hardware number: 5WA907572
Software version: 0395
Software number: 5WA907572B
Any extra advises what might be wrong in my setup?
Edited by djmartzian
2 minutes ago, djmartzian said:
Thank you mate.
Security code?
Try with this when coding 13
