Coding of Steering Wheel controls
Hello guys,
I need some help here! Purely from a vanity standpoint, I’ve changed my steering wheel. After installation, the buttons to the left pertaining to multimedia (music, volume, skip tracks etc) are working fine. However I noticed that some of the buttons on the right do not work.
I need advice on coding 2 of the buttons to the right hand side of the steering wheel to reactivate:
1. Changing of digital cockpit views
2. Menu that list down the various vehicle optionality (e.g., Vehicle status, oil temp, reset trip counter etc)
Can anyone help?
  • Replies 54
  • Views 17.2k
  • Update:   1. Steering controls - this was resolved through a LIN convertor which allow buttons to be programmed.    2. Drive select and start/stop button - I installed this and it is
  • I don't think this is a coding issue.     If I remember correctly, the newer style of wheels use different commands so you probably need an aftermarket LIN convertor/adaptor.
  • The new steering wheel is not compatible with the older setup, I believe it’s been covered on here before. but like above, a custom controller would work to fix it. Not easy though
Just for example: https://www.drive2.ru/l/581371172306813158/
Thank you for advising! I’ve assessed the link and translated into English. It appears to be hefty work! 😪
  • 5 months later...
I also changed the steering wheel to a 2020 Ss3. And I installed this module and all the buttons work. But the first time the steering wheel must be coded on the car without this module. then the module is installed.
The new facelift steering wheel looks nice.
Update:
2. Drive select and start/stop button - I installed this and it is working well. Purchase link included here. There’s 11.11 sale. Great deal!
https://www.aliexpress.us/item/3256802851402654.html
Edited by RT_SGP
56 minutes ago, RT_SGP said:
Update:
Got a link to the LIN converter that you used?
Can you guys give us an update about which steering wheel and air bag you have installed?
I want to retrofit my steering wheel in my Super 2019 FL, but I'm not sure which parts I should buy. OEM numbers of the steering wheel/air bag should match?
My steering wheel is like on quoted image on the left, without heating, and I would like to retrofit the one with heating. Is it possible?
Apart from LIN converter do I need something else?
Thanks! ;)
Thanks! /cdn-cgi/mirage/b842c863d70ad70a6e850a28ad8ac3f977bf88aa17efa9c492ceb2760379a738/1280/https://www.briskoda.net/forums/uploads/emoticons/emoticon-0105-wink.gif
Talk to Dumitru Sabin Mihai on Facebook. He has done everything. He is able to tell you what you need or what you need to do.
Can anyone provide a link to the lin adapter mentioned
What module are you referring to?
On 08/11/2022 at 15:10, RT_SGP said:
Update:
Got a link to the lin convertor?
https://www.cars-equipment.com/en/shop/radio-adapter-can-bus-decoder-22/canbus-adapter-reduction-for-steering-wheel-2/
from here I got the mod. I took the full one. not the basic one. the full one is better. but you can write them an email and tell them what it's about, it would help you.
49 minutes ago, STU3Y said:
Did you manage to get all the buttons working, including the heated steering button?
yes all buttons work. but you have to coding them with vas. Dumitru Sabin Mihai from Facebook helped with the coding. Write to him privately on Facebook
  • 8 months later...
Update:
Hi mate,
love these buttons!!! Which style of steering wheel did you state that you had when placing order please?
thanks
  • 11 months later...
So, the monster lives! 😜
Successfully using the MFL (multifunction steering wheel) at the table today. Here's the configuration:
The new MFL buttons (sub 19)
Gateway (19)
Multimedia System (5F)
Steering column control unit (16)
"Analog" speedometer (17)
Coding, adaptation, and data set creation were all done, of course.
The starting point was a Conti 3Q0907530C as hardware and AA as software.
Cairus, did you manage to code the newer steering wheel buttons or do you need an additional module that remaps the buttons?
Can you describe more details for the adaptation and coding of the steering wheel buttons?
On 11/6/2025 at 4:03 PM, Cairus said:
So, a minor setback...
The menu selection in the on-board computer isn't working in the car.
Who or what is to blame, those damn Skoda developers or someone else...?
Skoda decided to have the menu scroll from top to bottom. That's precisely the problem.
The signal from the new steering wheel is left or right.
That's why my setup with the Seat instrument cluster worked; menu selection works left or right...
I'll keep you posted.
Something is not clear to me, karoq 2018 uses an older type of steering wheel, karoq 2020 uses a newer type of steering wheel. Is the problem in the module type (different letters) or just the coding?
Mib2-2.5 have old steering wheel
Mib3 - new steering wheel and new VC
At least for Superb 3, I guess same for Karoq
