Updating Swing radio software
@jls60860 Thankfully I didn't need to translate what you wanted.  I will send you a PM.
  • Replies 408
  • Views 101.1k
  • Yes the update file can be sent to you
  • None 😞
  • Maybe my post do not complies with forum rules and I am so sorry if I'm doing something wrong, but this situation is really serious and against the warranty law: Skoda refuses to fix it, asks for mo
On 08/01/2023 at 18:45, varooom said:
Yes in a few moments...
Apreciate to share the link please .
Thanks a lot
Thanks a lot
I will share what I think you need...
Hey can you help with my infotainment?IMG20230428170700.thumb.jpg.070c01920fc5904d773aad38888cba1d.jpg
Sorry cannot find an update for that Software Train.
Following item can be updated?
SWING OCTAVIA
5F
5E0035871D
8395
9 minutes ago, yakov said:
SWING OCTAVIA
5F
5E0035871D
8395
You need to find a Software Train from your car.
Hold down the Menu/Setup button for about 10 seconds to enter the engineering menu, then post back details or a picture.
details:
21 minutes ago, yakov said:
details:
Ok, I can now send you 8755 version
Thank you very much,
Yes send , if you can, it would be nice.
I have already... top right of screen you have a private message waiting for you to read 🤝
Hi Guys ,  can you share with me this version ?  I need it please
You already have the update and applied it, not sure why you need to have same file again, it won't load if you are on 8755 version now.
Sorry Varoom, I thought that's was new version.
Hello, please can someone help me to send the last update for my infotainment system?
The Software update information you wanted is:
Installed software version: MEN2_EU_SKGPx_P7381L
Installed MU version: 8740
Hardware: 690
Thanks a lot!
Hardware: 690
Thanks a lot!
Yes you will have PM for 8755 version
Hi, do you know if there is a software update for my swing head unit?
Not seen any update for that SW Train value.
Ah ok, thank you for checking anyway 😊
Same issue as others of crackly audio. Is there a downloadable firmware update?
Current details attached: IMG_1343.HEIC
3 hours ago, DPHPHD said:
That has been sent now via PM
Hello!
After the Software update, my new version is MEN2_EU_SKGPx_P0080L, MU 8755.
When I scanned with VCDS an error code appears, which reappears even after I deleted it.
The error: 5F-Information Electr. -- Status: Malfunction 0010
1 Fault Found: 1555 - Check Software Version Management
B201A 00 [009] - -
Can someone help me make this error code go away? Maybe something needs to be reprogrammed?
Thank you.
1. Log-after update software.txt
16 minutes ago, gabic03 said:
Hello!
B201A 00 [009] - -
Thank you.
B201A is a classic error, but it does not affect unit.
It is caused when the car cannot confirm the checksum with the factory.
Have a read at this guide here, the above YT video is just to show use of another tool
https://forums.ross-tech.com/index.php?threads/18798/
Just now, gabic03 said:
I read in a post on the ross-tech forum (If it is not right, please a moderator to delete the link - https://forums.ross-tech.com/index.php?threads/31836/#post-267910) that a code should be written for 5F.
That's probably how I should proceed, but I don't have that code.
You have to open 5F, and locate the value that is stored in that image from your car
Then use the XOR website to input your value at the top
To then make your new code
Then input value with space here
