DCC Slider adjustment option mod
https://www.briskoda.net/forums/topic/535341-dcc-slider-mode/
  • 11 months later...
  • Replies 127
  • Views 48k
  • Well that was all surprisingly easy...   Flashed the DCC module:   Uploaded the Passat dataset (closest in size, weight and wheelbase to the Octavia):   I alr
  • Ok, with some serious help it's been done!   Here is the overall sequence of events that was encountered and followed: Original gateway was 5Q0. Most examples seem to use the 3
  • Youre in luck, this is what youre after.   https://www.glaskugelservice.de/codierung/dcc-auf-index-c   https://github.com/jilleb/MQB-FPA     The first link is bringi
Hello new member here.
very interested in the DCC slider mod and would like to get the contact details of Julian if possible.
Have Prokit springs fitted with whiteline sway bar.
coming from a golf mk7R, suspension in superb is disappointing.
cheers
cheers
They're different beasts; Superb is larger MQB-B chassis; longer and heavier. The car isn't a hot hatch and is a Passat equivalent so better at motorway munching with much better interior space.
Whiteline rear arb is good - hopefully on the stiffest setting. I found although the droplinks weren't necessary, you can notice the firmer bushes based in uprated ones.
