Instrument cluster error code, control module, Fault B200049
Hi i have a MK2 Octavia 2011 1.6 BSE engine.
I recently took the instrument cluster out because the lights for the rev needle was dead, I disconnect the battery, carefully swapped the smd led chips over, and fitted it back in the car, reconnected the battery, turned the ignition, the new lights work but I'm left with an error message on the screen.
I've done a scan and I got the code B200049 (faulty control module) I've spent the last few days checking the coding and adaptions, took it for a drive to see if it would re learn that it's ok.
I've checked the harness for corrosion it's all clean, and I undid all the loom tape and all the wires perfect with no splits or damage.
The gauges still work fine and the working lights all come on.
Is there something I could have done to damage it when dismantling and changing the lights.
I'm guessing I might need to replace the cluster if it is the module on the PCB that's failed.
I'm open for any suggestions as it's really confusing me now.
Ill add a scan report that I did today
Date: 2022-11-05 22:33
    VIN: TMBHA21Z--------------
    Car: Skoda Octavia
    Year: 2011
    Body type: Estate
    Engine: BSE
    Mileage: 142460 KM
Fault
    Control unit: 01 Engine
    Active faults: 0
    Inactive faults: 0
    System description: BSE S71 1.6 2VG
    Software number: 06A906033NT
    Software version: 8459
    Hardware number: 06A906033MP
    Faults:
        No trouble codes found
    Mileage: 142460 km
    Date: 2022-11-05 13:49
Fault
    Control unit: 03 Brakes
    Active faults: 0
    Inactive faults: 0
    System description: MK70 M MASR
    Software number: 1K0907379AK
    Software version: 0105
    Hardware number: 1K0907379AK
    Faults:
    Mileage: 142460 km
Fault
    Control unit: 08 Air Conditioning
    Active faults: 0
    Inactive faults: 0
    System description: AC Manuell
    Software number: 3T0820047R
    Software version: 0401
    Hardware number: 3T0820047R
    Hardware version: H16
    ODX name: EV_ACManueBHBVW36X
    ODX version: A01010
    Faults:
    Mileage: 142460 km
Fault
    Control unit: 09 Central Electrics
    Active faults: 0
    Inactive faults: 4
    System description: BCM PQ35  H+
    Software number: 1K0937087AB
    Software version: 0651
    Hardware number: 1K0937087AB
    Hardware version: 110
    Faults:
        01134 - Alarm horn No signal/communication
            static
        03156 - Anti-theft alarm system sensor No signal/communication
            static
        01299 - Diagnostic interface for data bus no or incorrect basic setting/adaptation
            static
    Mileage: 142460 km
Fault
    Control unit: 15 Airbag
    Active faults: 0
    Inactive faults: 0
    System description: Q4 AIRBAG VW8   020
    Software number: 1K0909605T
    Software version: 2300
    Hardware number: 1K0909605T
    Hardware version: 003
    Serial number: 0038PC24Y89J
    Faults:
    Mileage: 142460 km
Fault
    Control unit: 16 Steering Column
    Active faults: 0
    Inactive faults: 0
    System description: LENKS.MODUL
    Software number: 5K0953521DF
    Software version: 0162
    Hardware number: 5K0953569AE
    Hardware version: 016
    Serial number: 20141215101237
    ODX name: EV_SMLSNGVOLWSXS
    ODX version: A01004
    Faults:
    Mileage: 142460 km
Fault
    Control unit: 17 Dashboard
    Active faults: 0
    Inactive faults: 1
    System description: KOMBI
    Software number: 1Z0920903K
    Software version: 0405
    Hardware number: 1Z0920903K
    Hardware version: H05
    Serial number: 00000000000000
    ODX name: EV_Kombi_UDS_VDD_RM09
    ODX version: A04089
    Faults:
        B200049 - Ctrl. module faulty
            static
    Mileage: 142460 km
Fault
    Control unit: 19 Gateway
    Active faults: 0
    Inactive faults: 4
    System description: J533  Gateway
    Software number: 7N0907530C
    Software version: 0614
    Hardware number: 1K0907951
    Hardware version: H37
    Serial number: 290311F6000706
    Faults:
        02649 - Digital radio tuner No signal/communication
            static
        01044 - Control module incorrectly coded
            static
        02874 - Comfort system central control module 2 No signal/communication
            static
        03272 - External audio source connection No signal/communication
            static
    Mileage: 142460 km
Fault
    Control unit: 25 Immobilizer
    Active faults: 0
    Inactive faults: 0
    System description: IMMO
    Software number: 5K0953234
    Hardware number: 5K0953234
    ODX name: EV_Immo_UDS_VDD_RM09
    ODX version: A03008
    Faults:
    Mileage: 142460 km
Fault
    Control unit: 37 Navigation
    Active faults: 0
    Inactive faults: 7
    System description: RNS315-EU
    Software number: 5JA035192J
    Software version: 0410
    Hardware number: 5JA035192J
    Hardware version: H77
    Serial number: SKZAZ2P0201780
    ODX name: EV_RNS315EUV2UDS
    ODX version: 001705
    Faults:
        B106113 - Left front treble speaker Open circuit
            static
        B110413 - Connection for external audio sources (AUX-IN) Open circuit
            static
        B111913 - Antenna 1 for radio Open circuit
            static
        B111A13 - Antenna 2 for radio Open circuit
            static
        B110313 - Digital radio antenna 1 Open circuit
            static
        B105313 - GSM antenna Open circuit
            static
        U111100 - Function limitation due to missing message
            static
    Mileage: 142460 km
Fault
    Control unit: 42 Driver Door
    Active faults: 0
    Inactive faults: 0
    System description: Tuer-SG         009
    Software number: 1T0959701T
    Software version: 2120
    Hardware number: 1T0959701T
    Faults:
    Mileage: 142460 km
Fault
    Control unit: 44 Steering Assistance
    Active faults: 0
    Inactive faults: 0
    System description: EPS_ZFLS Kl. 67
    Software number: 1K0909144M
    Software version: 3201
    Faults:
    Mileage: 142460 km
Fault
    Control unit: 52 Passenger Door
    Active faults: 0
    Inactive faults: 0
    Software number: 1T0959702R
    Hardware number: 1T0959702R
    Faults:
    Mileage: 142460 km
Fault
    Control unit: 62 Rear Left Door
    Active faults: 0
    Inactive faults: 0
    System description: Tuer-SG         007
    Software number: 5K0959703A
    Software version: 2101
    Hardware number: 5K0959703A
    Faults:
    Mileage: 142460 km
Fault
    Control unit: 72 Rear Right Door
    Active faults: 0
    Inactive faults: 0
    Software number: 5K0959704A
    Hardware number: 5K0959704A
    Faults:
    Mileage: 142460 km
