Battery drainage
Hi guys,
Hopping that someone can help me understand what can i do with this battery drain problem.
For the past 2 months i've got a problem in my Skoda Octavia that if i do drive it for a day when i get the next morning my battery don't start the car.
I've tried to debug the problem to see if i've got a drain somewhere and i've got this number:
This is the number that i get after everything is disconnected.
This number is normal??
I've verified every fuse inside the car and no change. When i disconnect the fuse from the radio (inside the fuse box of the engine) the amps drop to 0.01.
My question is the drain from the radio is normal?
Cheers.
Edited by Bigster
No, it is far higher than it should be, something closer to 0.02 would be good.
No.
Which year and is the radio the original? Also, do you trip the bonnet lock to simulate the bonnet being shut?
The radio is not the original, but it has a lot of years. I would say at least 10 years.
About the bonnet i didn't test it but when i removed the radio fuse the amps drop to 0,01 so its not the bonnet.
No.
Yeah i was hoping that this was normal but in back of my head i already no the truth!!! ;)
Any idea on how to debug the radio? Or how to solve the issue?
I confess that with the radio i'm a bit lost.
I already had a strange behavior from the radio because when i shut down everything in the car the Bluetooth continues to work and the phone continues to be paired with the radio but the radio is shut down.
Does the bluetooth drains 0,47 amps???
cheers.
No personal experience of radio issues, sorry. Pretty sure I've read that some factory-fit ones can develope a fault where an internal cooling fan stays on when it shouldn't,  but I guess yours is something aftermarket?
Isn’t there a known problem fitting a non factory radio to anything pre 2007, will drain the battery or was that only when fitting a Columbus. A newer version of a component needed to be installed to prevent this. I forget the name of it. The OP has a 2005 car.
That will explain the behavior.
A bit more info about the radio if someone can help a little bit more:
- The radio is a 2 DIN that i've buy in https://tecnochin.com/.
- Has GPS, Bluetooth, DVD, USB, TV (that not work in Portugal), SD Card
- Win CE version (so very old school)
Cheers.
What you are talking about is when a pre 2007 PQ35 platform car gets a later head unit where you need to change the CAN BUS but I would not expect it to take 10 years to show up.
It might be an error in translation, I suspect he means the radio is 10 years old but may have been fitted more recently, were they even selling Win CE head units 10 years ago?
I had exactly the same problem in the same vehicle with the same Win CE head unit, once connected the Canbus system will not go into sleep mode nor the various other modules it communicates with resulting in a half amp or more battery drain.
The only solution is to replace the Canbus gateway unit with a later revision one, it will also need reprogramming for the installation list of your vehicle.
Plenty of info about it on the Ross-Tech web site.
Hi J.R. thanks for you help.
The radio is installed in the car 10 years ago, i probably always had this problem but with age the problem seems to got bigger, i don't know!!!
That's a bit out of my knowledge doing that kind of things but i'm eager to try. Can you point me to the CAN Bus that is need to get?
i found this video in youtube that is probably doing exactly what you said:
If not can you point me to the correct direction? Like i said i'm a newbie on this.
Cheers.
Another thing that is going on is i've lost the turn lights sound and alert sounds from my central console and now the back sensors sound is also doing some weird sounds. It seems that the electrical part (columns) are going bad!!!
So i've got some news. I've plug in the Ross interface into my skoda octavia and i've got a lot of errors:
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: Malfunction 0010
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1Z0 907 044 H
   Component: ClimatronicPQ35 084 0304
   Shop #: WSC 00000 000 00000
   VCID: 3B75D1677A907BC6811-806E
2 Faults Found:
00576 - Terminal 15
            002 - Lower Limit Exceeded - Intermittent
00926 - Terminal 30
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 M    HW: 1K0 909 605 M
   Component: Q2 AIRBAG VW8   024 0700
   Revision: 07024000    Serial number: 0038DD0R8XN%
   Coding: 0020786
   Shop #: WSC 73430 790 00000
   VCID: 3663C05341B2A6AE7EF-8063
   Subsystem 1 - Serial number: 6332MSME75495E08
   Subsystem 2 - Serial number: 6342MSME105F5E08
   Subsystem 3 - Serial number: 6351HSME621A7706
   Subsystem 4 - Serial number: 6361HSME624A7506
1 Fault Found:
00532 - Supply Voltage B+
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 G    HW: 1K0 953 549 G
   Component: Lenks‰ulenmodul 021 0050
   Coding: 0002042
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: Lenkradmodul    007 0050
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
            014 - Defective - Intermittent
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H11 0110
   Revision: 11          Serial number: 29001052211261
   Coding: 3D3F07C0072302
   VCID: 29591B2F800CF956E3D-807C
1 Fault Found:
01304 - Radio
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 254
                    Reset counter: 29
                    Mileage: 137125 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 10:07:35
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX1.lbl
   Part No: 1T0 959 701 A
   Component: Tuersteuergeraet 09 0165
   Coding: 0000118
   VCID: 3561C75F5CB4ADB6775-8060
1 Fault Found:
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Component:    KSG              0401
   Coding: 00D002007F2D8505484FC61004C8
   VCID: 79F90B6F302C89D6D3D-802C
   Subsystem 5 - Part No: 1Z0 951 171 A
   Component: NeigungsSensor  008 4802
   Coding: 00000000
   Shop #: WSC 00000
   Subsystem 6 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H02 1301
   Subsystem 7 - Part No: 1Z0 951 171 A
   Component: Innenraumueberw.008 4802
1 Fault Found:
00668 - Supply Voltage Terminal 30
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX1.lbl
   Part No: 1T0 959 702 A
   Coding: 0000118
1 Fault Found:
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 B
   Component: Tuersteuergeraet 06 0219
   Coding: 0000048
   VCID: 2F6DF537BEE897663D9-807A
1 Fault Found:
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 B
   Coding: 0000048
   VCID: 306FF64BA3D6889E243-8065
1 Fault Found:
01814 - Supply Voltage for Door Controller; Rear Right (J389)
Address 76: Park Assist        Labels: 1Z0-919-283.lbl
   Part No SW: 1Z0 919 283 B    HW: 1Z0 919 283 B
   Component: Parkhilfe 4-Kan H04 0020
   Coding: 0000001
   VCID: 3D71DF7F648475F6BF5-8068
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 190602 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:08:22
Address 77: Telephone        Labels: 5P0-862-335.lbl
   Part No SW: 5P0 862 335     HW: 5P0 862 335
   Component: FSE_2P5x        H18 0030
   Revision: 00000001    Serial number: 00000000188674
   Coding: 0000422
   VCID: F0EFB64BE356489EE43-80A5
1 Fault Found:
01523 - Microphone for Telephone (R38)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 101
                    Mileage: 183641 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:52:17
It seems and there are some opinions that this is only a battery issue others don't, just ignore.
What are your opinions?
On the replacement of the CAN Bus Gateway can you guys show me where can i get the CAN bus that solves the problem?
Cheers.
If you start with the number of your gateway now from your scan, it goes like this... (it's a long path)
1K0 907 530E <-- Your current
1K0 907 530F
1K0 907 530K
1K0 907 530L
1K0 907 530Q
1K0 907 530S
1K0 907 530AD
7N0 907 530
7N0 907 530C
7N0 907 530H <-- Final replacement in theory
From your VCDS Scan
Has the battery condition been tested?
1K0 907 530F
1K0 907 530K
1K0 907 530L
1K0 907 530Q
1K0 907 530S
1K0 907 530AD
7N0 907 530
7N0 907 530C
I was pointing to ...530S, but H probably is better you are right.
But where do i found this part, i was searching and i can't find it. Only found for VW and other versions of Skoda (ex: 1.6). Can i use this part that was on other car than mine?
Ex: https://www.b-parts.com/pt/pecas-auto/eletrica-e-electronica/centralina-fecho-central-skoda-octavia-ii-1z3-16-tdi-7n0907530h-2004-2005-2006-2007-2008-2009-2010-2011-2012-2013-7920309?reference=7N0907530H&gclid=CjwKCAiAp7GcBhA0EiwA9U0mtg5s8F9G2ITG_x5ZHiIRgroAvVIWdVspFTS8lpEEmcy0180Sj9T3ahoC58gQAvD_BwE
Cheers.
Edited by Bigster
Hi, yes i've tested the battery today.
Values not good!!!
battery in rest: 11,83V
Engine started: 13,85V
Engine at 3000 rpm: 13, 93V
Battery has 8 months.
Cheers.
34 minutes ago, Bigster said:
Cheers.
I put in the current value from your VCDS scan for existing gateway as the starting point in the parts program, and if you keep clicking on the supersession of the parts, you eventually should end up with the 7N0 907 530H value.
So in theory that should be the correct part (you can ignore the Audi/VW badge as they are all over your car already!)
Values not good!!!
Cheers.
Hello Bigster, I assume that when you say 'battery has 8 months' you mean it is only 8 months old - is that correct?
If you didn't do this before the test, I suggest that you give your battery a full charge, on a good charger at the correct rate - not a 'boost' or trickle charger, then retest after removing the surface charge (headlights on for around a minute)
The parasitic drain you report from your radio is possibly skewing your test result.
Yes, the battery in only 8 months old.
I've already received the CAN Bus gateway today and i will try to do the installation this weekend and then proceed with the measurements again and then charge the battery and also run the battery tests, again.
Hopefully i get all things right or else i don't have car anymore, at least for a long period ;)
Sooooooo... updates from this quest!!!
I've installed the new CAN BUS Gateway (...530H) and when i've tried to measure the battery drain my multimeter melt...
Now i need to buy a new multimeter!!!
But about the gateway i've got a few questions and news.
This is the result of the new scan:
Chassis Type: 1Z (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76 77
VIN: TMBGE61Z952080524   Mileage: 191270km/118849miles
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Not registered 0011
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Not registered 0011
So the only malfunction that worries me is the one from the Gateway itself. Here is the detailed failure:
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 H    HW: 1K0 907 951
   Component: J533  Gateway H42 1620
   Revision:   H42       Serial number: 070911F1002505
   Coding: 352302
   Shop #: WSC 73430 790 00085
   VCID: 3561C75F9CB4ADB6775-8060
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 191274 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:32:07
After a lot of tentatives and digging into the subject i´m out of options.
Here are the detail pictures of the configs:
1314035898_CANBUS-INSTLst1.png.28604d2cf2b0d3d001a7835a7ae24f08.png415774138_CANBUS-INSTLst2.png.a63625c146ffc0245cfd8ea29ab76d10.png277789578_CANBUS-INSTLst3.png.4a8b3f297fe3a170bd7dc0f23aec8faf.png1811462494_CANBUS-INSTLst4.png.84bb9e1b26239f8992cbcc587987ba5e.png
This is one thing that is very different from the old gateway:
Any idea / way / option that solves the problem of the gateway fault?
Cheers.
Do you have these items in your car, as the Gateway seems to think they are not there via your tick choices, but VCDS can 'see' them?
If they are not actually in your car, do you have old VCDS scan?
Hi, i've remove the tick from the Installation List because it was giving me errors and also the error from the gateway was there.
For example when i had the Telephone ticked this was the error that appear:
   Coding: 0000422
1 Fault Found:
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 12
                    Mileage: 191274 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:33:37
This was the Installation List before i've changed the gateway:
1409841164_CANGTWInstalationlist2.png.7f55d1e13bea5f73d6b011c2e1f2aafe.png627670929_CANGTWInstalationlist1.png.4b7051213ab6b174312ccc9eaf72bbae.png
So the Radio and the Telephone are there but with the new one it gave me different errors.
What should i do? Should i tick the radio and the telephone?
Cheers.
The fault in your new Gateway is stored because on it's list you don't have these selected...
But the new gateway knows they are there!
If you tick the two choices, then the gateway fault can go away, in theory, and also hopefully they can RESPOND back to the gateway they are ready for sleep, this allows the gateway to put the CANbus into sleep mode... saving power!
It doesn't matter that the car will complain that there is a fault in the Telephone, that can be fixed at a later date or never depending on how you use the car.
tl;dr Tick 56 & 77 in new gateway, store and save.  Then see if gateway fault is clear.
