New Octavia tips and tricks
I have a new FL vRS with Dual zone Climatronic, how do I get into these settings everone talks about on page one!? Or can't I? I don't know what to do, or press button wise.
please advise.
  • 4 weeks later...
  • Replies 181
  • Views 338.2k
  • Just a quick one for those of you who plan to keep their cars for a while, I have found that if you use the drivers electric window switch a lot, the black edge of the switch will wear away revealing
  • here are all the climate contol settings. Now these have been translated by someone else from Spanish. The translation is not brilliant and where I have been able to, I have made it easier to unders
Can you send me some pictures showing How to activate the ON/OFF center switch on the CLIMATRONIC in my skoda octavia II?
Thank you in advance
Balazs Szekeres ([email protected])
Skoda dealership has it, it's called VAS. Few of us have it from RossTech and it's called VagCom. It's bit expensive but you may ask for a help from some member with VagCom living close to you.
If you're interesting in buying one:
Ross-Tech: Home
There are european distributors for that tool as well.
Also, there is forum on Briskoda that has a lot of useful things and the map of members with VagCom and their location:
Diagnostics & VAG-COM General Motoring Discussions - Diagnostics & VAG-COM at BRISKODA.net - BRISKODA - The Skoda Forums
Hi, I just tried the Diagnostics & VAG-COM link just now (24/5/10) and it did not work - I have a Octavia Classic 2007 (Jan) and the cental locking (I do not have remote central locking) just unlocks the drivers doore, I have to press the button on the centre consol to unlock the other doors.
The manual says this can be changed,I live in Jersey and would like to get this changed when I am on the UK mainland in June with my car, I will be going near Oxford, is there some kind person willing to do this for me?
Or should I take it to the local dealer?
thanks
thanks
I thought the classic was based on the old Mk 1 Octavia. If this is correct then you may need to check the convenience unit in the drivers door. This is a known weak spot in the central locking system.
If it is a Mk2 Octavia then have you tried pressing the unlock button twice in quick sucession as this should then unlock all doors.
Except the poster said they haven't got remote locking...
Wake up damn you!! :zzz: :D
Jerseyman... the link is bust, it's from the old site. Try >> here << :thumbup:
D'oh, should not read posts while trying to watch the last episode of Lost.
I miss so many tv programmes thanks to this site! :rofl:
  • 2 months later...
Hi
Many thanks for your help with my unlocking question.
Discovered the following;
1 - On my 2007 (Jan) Classic Octavia 1.9 DSG that pressing the switch located by the ciggy lighter had no effect.
2 - By turning the key in the drivers door quickly twice to the right (unlock position) this unlocked all the other doors and the rear door!
Fantastic!!!
thanks all.
Found another one the other day - pressing and holding the interior lock/unlock button will close or open the windows respectively!
As mentioned in the first post of this thread ;)
No, i'm not on about using the remote - im on about the lock/unlock switch inside the car ;)
Haha - very good! Not quite sure why you'd want to when you're inside - but anyway, it's still a good tip :clap:
Cheers,
Steve
Oh, and I've requested this is made a sticky again :thumbup:
Cheers,
Steve
You can do it at anytime when keys out, engine running, moving etc so is quite useful.
Tried that the other day but it doesn't work on my 06 vRS. :( booo.
(works with the remote fine though)
did this yesterday while aux was on hold the two forward and back a track together and it comes up with hardware and somethin else, and get the option of CD trans on the rite and PWM. does anyone know what PWM means??
I have tried to set the MPH by using the climate control menu, i followed the guide but cannot get the display in MPH to show up anywhere. Do you need to save the new setting and if so How? where will the setting be displayed?
07 plate Octavia PD TDi Vrs, with the dual zone climate.
Thanks Andy
Should be setting 19.1 on the dual zone for MPH. Turn the passenger temperature dial to 19 and the fan speed dial to 1. It works on my car anyway.
Thanks but I've done all that but I can see no Digital display for MPH, where will it be shown??, do you need to save the setting??
Is it shown on the radio, if so which model does it have to be, or the display settings where the dash speedo / revs etc
Thanks, this works great :)
The speed is shown on the driver's side temperature display on the dual zone air conditioning. 19.1 is shown on the passenger side temperature indicator to tell you you've selected the correct mode.
Has anyone found, or does anyone know of a better translation for the Climatronic Display Settings, instead of that Spanish effort?
I can translate the spanish if you want, just send me a PM, also the resetting of the gas pedal is great , ignition on halfway, hold down pedal to the florr for 25 seconds , turn off ignition and release the pedal.
It's a pre-FL only trick...
Simbo: out of curiosity, do you know why Skoda didn't carry over the climatronic control trick to the FL model?
What do you mean with resetting the pedal?
