Superb Scout edition harsh suspension
I’m following this thread with some interest; need the increased height/ rough road package on my estate but will be looking to improve the level of damping,  at the front in particular, at some point in the future.   ( still got a year of extended manufacturer warranty left and LT 30 k miles on the car so not in a hurry to change yet).
Was hoping Bilstein B6 would fit.
  • Replies 75
  • Views 14.6k
  • I may be wrong. But if you take a look at each spring, transport blocks are big enough, so that they can’t be missed. No real need to go to a dealer to check if they’re still ON. 😉
  • Have you checked the transport blocks have been removed. They fill in some of the from suspension to reduce the body movement in transport. Some dealers forget to remove them. They are usually in the
  • I agree, this forum is flooded with what later turns out to be BS because people believe what a garage tells them.   Check yourself by jacking the car up and lifting the piston rod shroud, t
19 hours ago, Carlston said:
Do you want to try standard ride height shock absorbers, such as Bilstein B6, with your increased ride height springs, or do you want to drop the ride height by changing to standard ride height springs.
I would like to stay with the current increased height. Thats why I bought the Scout.
I dont know from where the height comes ? Only due to the 'longer' springs? If that is the reason - how the Biltein B6 for normal height will work with the longer springs ?
I am getting the daily feeling that the car is 'swimming' or and feeling like a boat. Its just that feeling that car is sitting only on the springs and even the smalles bump that are on the road are transferring to the cabin. It is very strange that the car leans a lot, there is a lot of movement of the body, it has the boat feeling but when I hit a bump or a sleeping policeman there is sooo much noise and it seems I am bottoming out the suspenion. Does that mean that the spirngs are soft or the shocks are soft ? As far as I can understand the Bilstein B6 are much harder shocks and I have to know what will be the end result before I spent a lot of money and replace the oem 3 years old suspension.
Duplicate
Edited by Tonies
Duplicate
Wonder if these would work ? It suggests they will for “ increased height”, and KYB struts generally are good
https://www.autodoc.co.uk/kyb/14359022
and
https://www.autodoc.co.uk/kyb/14359027
Personally speaking with my car and the uses it is put to, I can live with the generally soft, comfort “boaty” suspension most of the time BUT  on country lanes - typical Northumbrian /Scottish A class roads- even at moderate speeds, small road ripples or rough surfaces on bends tend to throw the front end off line ( with “jiggling/ rattling” feel ) and theres a particular spot just off a bend where a slight depression across the road leads the front end to compress/ load up - thats ok - but is then followed by a second depression 3 -4 metres further on where the front end bottoms out heavily on the bump stops. Feels like the shocks are still loaded up from the first “bump” and haven't recovered in time for the second depression. Im talking just shallow very smooth depressions in the road here and have tried different lines / angles of approach and dropping speed as low as 20 -25 mph, and get the same bottoming out.
Our other cars ( admittedly models renowned for good handling) barely feel these depressions when cruising steadily in the same place at anything up to 40-45mph.
Been like that since the Superb was new.   Strange the back end damping and springing  is fine and controlled even when heavily loaded up.
Edited by Shuggyboatsuperb
Corrected link
4 minutes ago, Shuggyboatsuperb said:
Wonder if these would work ? It suggests they will for “ increased height”, and KYB struts generally are good https://www.autodoc.co.uk/kyb/14359027
Personally speaking with my car and the uses it is put to, I can live with the generally soft, comfort “boaty” suspension most of the time BUT  on country lanes - typical Northumbrian /Scottish A class roads- even at moderate speeds, small road ripples or rough surface tend to throw the front end off line ( with “jiggling/ rattling” feel ) and theres a particular spot just off a bend where a slight depression across the road leads the front end to compress/ load up - thats ok - but is then followed by a second depression 3 -4 metres further on where the front end bottoms out heavily on the bump stops. Feels like the shocks are still loaded up from the first “bump” and haven't recovered in time for the second depression. Im talking just shallow very smooth depressions in the road here and have tried different lines / angles of approach and dropping speed as low as 20 -25 mph, and get the same bottoming out.
Oh my God, this was exactly written just out of my minds. I have absolutely the same feeling. I had to drive sooo slowly sometimes that there has been a queue behind me with much more cheaper and old cars that want to overtake me. This never happen with any of my old cars. I also think that when you hit the first bump, the suspenion is not been able to set up again in a normal position. May that means - the shocks are soo soft and lazy that dont want to decompress at all. As I said, overall feeling is that I am driving on springs only.
Now, about the KYB, I am thinking that most of the OEM replacement will be pretty much the same and thats why I would risk with a time proven product as Bilstein. I am feeling more and more confident about that change. I am just afraid what will happen with changing the current soft dampers to B6 and keeping the old Springs.
Tonies,   I have the same doubts about going to B6 if the comfort on major dual carriageways/ motorway roads suffers.
I am certain the diagnosis is that the OE front shocks compress too easily but rebound too slowly so cannot handle well against repetitive rough spots or dual small “ bumps” , one close after the other.
 My car has increased ride height and weight range 5 springs ( 2.0D FWD manual gearbox) and I think this weight range spring in this model shouldnt be too soft a spring.
Simply, the OE dampers are too slow to re-extend on multiple slightly-rough areas  of road.
I would hope some replacement front shock brand will still be comfortable but respond more quickly on rebound, - but I would like to get it right the first time rather than experiment / risk everyday driving getting worse!
and
The KYB 3358015 front shock absorbers and KYB 3448024 rear shock absorbers are listed as aftermarket replacements for lowered ride height shock absorbers, standard ride height shock absorbers, and increased ride height shock absorbers, ie. it's a one size fits all approach from KYB so might not be a close match to the specification of the original shock absorbers. It's a similar story with most of the other aftermarket shock absorbers. However, these KYB shock absorbers should be long enough for the increased ride height car otherwise KYB shouldn't be listing them for it.
KYB 3358015 front shock absorbers are sold to replace the following OEM part numbers
OE 3Q0413031BN — VW
OE 5Q0413031CJ — VW
OE 3Q0413031BM — VW
OE 3Q0413031BR — VW
OE 3Q0413031AL — VW
OE 5Q0413031EC — VW
OE 5Q0413031CF — VW
OE 3Q0413031AR — VW
OE 5QA413031AA — VW
OE 3Q0413031AQ — VW
OE 3Q0413031AM — VW
OE 5QA413031AB — VW
OE 5Q0413031CG — VW
OE 5Q0413031CH — VW
OE 5Q0413031HR — VW
OE 5Q0413031GG — VW
OE 3Q0413031CB — VW
OE 3Q0413031AP — VW
OE 5Q0413031CM — VW
OE 3Q0413031BA — VW
OE 5Q0413031HS — VW
OE 3Q0413031CC — VW
OE 5Q0413031CL — VW
OE 5Q0413031GJ — VW
OE 3Q0413031BQ — VW
OE 3Q0413031BS — VW
OE 3Q0413031AN — VW
OE 3Q0413031AS — VW
OE 3Q0413031AT — VW
OE 3Q0413031CE — VW
OE 3Q0413031CF — VW
OE 3Q0413031CG — VW
OE 3Q0413031CK — VW
OE 3Q0413031CL — VW
OE 3Q0413031CM — VW
OE 5Q0413031CK — VW
OE 5Q0413031FT — VW
OE 5Q0413031GL — VW
OE 5Q0413031HP — VW
OE 5Q0413031HT — VW
OE 5Q0413031JK — VW
OE 5Q0413031JL — VW
OE 5Q0413031JM — VW
OE 5R3413031H — VW
OE 5R3413031J — VW
OE 5WA413031AT — VW
OE 5WA413031BA — VW
OE 5WA413031BJ — VW
OE 5Q0413031FN — VW / SEAT
OE 5Q0413031FP — SKODA
OE 3Q0413031BG — SKODA
OE 5Q0413031ER — SKODA
OE 5Q0413031EP — SKODA
OE 3Q0413031BF — SKODA
OE 5Q0413031FS — SKODA
OE 3Q0413031BH — SKODA
OE 5Q0413031EQ — SKODA
OE 3Q0413031BJ — SKODA
OE 3Q0413031CQ — SKODA
OE 3Q0413031CR — SKODA
OE 3Q0413031CS — SKODA
OE 3Q0413031CT — SKODA
OE 5Q0413031JC — SKODA
OE 5Q0413031JD — SKODA
OE 5Q0413031JF — SKODA
OE 5Q0413031JG — SKODA
OE 5WA413031AF — SKODA
OE 5WA413031AG — SKODA
OE 5WA413031AH — SKODA
OE 5WA413031AJ — SKODA
OE 5WA413031AK — SKODA
OE 5WA413031AL — SKODA
OE 5WA413031AP — SKODA
OE 5WA413031S — SKODA
OE 5WA413031T — SKODA
OE 5Q0413031ET — AUDI
OE 5Q0413031ES — AUDI
OE 5Q0413031DF — AUDI
OE 5Q0413031EL — AUDI
OE 5Q0413031FE — AUDI
OE 5Q0413031HJ — AUDI
OE 5Q0413031GE — AUDI
OE 5Q0413031EG — AUDI
OE 5Q0413031EF — AUDI
OE 5Q0413031GD — AUDI
OE 5Q0413031GT — AUDI
OE 5Q0413031GN — AUDI
OE 5Q0413031GS — AUDI
OE 5Q0413031GQ — AUDI
OE 5Q0413031FF — AUDI
OE 8V0413031G — AUDI
OE 5WA413031 — AUDI
OE 5WA413031A — AUDI
OE 5WA413031E — AUDI
OE 5WA413031F — AUDI
OE 8V0413031AB — AUDI
OE 8V0413031AC — AUDI
OE 8V0413031C — AUDI
OE 8V0413031F — AUDI
OE 8V0413031H — AUDI
OE 8V0413031J — AUDI
OE 5Q0413031FH — SEAT
OE 5Q0413031FJ — SEAT
OE 5WA413031AA — SEAT
OE 5WA413031AB — SEAT
OE 5WA413031AC — SEAT
OE 5WA413031AD — SEAT
OE 5WA413031AQ — SEAT
OE 3Q0413031BP — VW / SKODA
OE 5WA413031AN — VW / AUDI
KYB 3448024 rear shock absorbers are sold to replace the following huge list of OEM part numbers
OE 5Q0513029DQ — VW / SEAT
OE 5Q0513029DP — VW / SEAT
OE 5Q0513029GL — VW / SEAT
OE 5Q0513029EQ — VW / SEAT
OE 5Q0513029EN — VW / SEAT
OE 5Q0513029EM — VW / SEAT
OE 5Q0513029EP — VW / SEAT
OE 5Q0513029FE — VW / SEAT
OE 5QN513049AT — VW / SEAT
OE 5QN513049BA — VW / SEAT
OE 5QN513049BB — VW / SEAT
OE 5QN513049BC — VW / SEAT
OE 5QN513049BH — VW / SEAT
OE 5QN513049BJ — VW / SEAT
OE 3Q0513049GF — VW
OE 3Q0513049GE — VW
OE 3Q0513049GG — VW
OE 5Q0513029EH — VW
OE 5Q0513029BQ — VW
OE 3Q0513049FA — VW
OE 5Q0513029LL — VW
OE 5Q0513029EG — VW
OE 3Q0513049ER — VW
OE 5Q0513029LM — VW
OE 5QA513029AH — VW
OE 3Q0513049GL — VW
OE 5Q0513029FM — VW
OE 5Q0513029FT — VW
OE 5Q0513029DB — VW
OE 5Q0513029JK — VW
OE 3Q0513049EQ — VW
OE 5Q0513029DA — VW
OE 5Q0513029HC — VW
OE 5Q0513029LK — VW
OE 5QN513049AN — VW
OE 5Q0513029HB — VW
OE 5Q0513029FS — VW
OE 5Q0513029JR — VW
OE 3Q0513049FB — VW
OE 3Q0513049GR — VW
OE 5Q0513029NH — VW
OE 3Q0513049FG — VW
OE 5Q0513029AR — VW
OE 5Q0513029JJ — VW
OE 5QN513049AM — VW
OE 3Q0513049FC — VW
OE 3Q0513049GK — VW
OE 5Q0513029AP — VW
OE 5Q0513029HA — VW
OE 5Q0513029JP — VW
OE 5QF513049AP — VW
OE 5QF513049T — VW
OE 3Q0513049HB — VW
OE 5QF513049BN — VW
OE 5Q0513029JH — VW
OE 3Q0513049GQ — VW
OE 5Q0513029HJ — VW
OE 5QF513049BP — VW
OE 3Q0513049ES — VW
OE 3Q0513049HE — VW
OE 3Q0513049JL — VW
OE 5Q0513029GP — VW
OE 5Q0513029NG — VW
OE 5QA513029AG — VW
OE 5Q0513029HP — VW
OE 5QF513049AL — VW
OE 3Q0513049EC — VW
OE 3Q0513049ED — VW
OE 3Q0513049EE — VW
OE 3Q0513049EF — VW
OE 3Q0513049EG — VW
OE 3Q0513049EH — VW
OE 3Q0513049EJ — VW
OE 3Q0513049EK — VW
OE 3Q0513049ET — VW
OE 3Q0513049FD — VW
OE 3Q0513049FE — VW
OE 3Q0513049FF — VW
OE 3Q0513049FH — VW
OE 3Q0513049FJ — VW
OE 3Q0513049FK — VW
OE 3Q0513049FL — VW
OE 3Q0513049FM — VW
OE 3Q0513049GH — VW
OE 3Q0513049GJ — VW
OE 3Q0513049GS — VW
OE 3Q0513049GT — VW
OE 3Q0513049HA — VW
OE 3Q0513049HC — VW
OE 3Q0513049HD — VW
OE 3Q0513049HP — VW
OE 3Q0513049HQ — VW
OE 3Q0513049HR — VW
OE 3Q0513049JC — VW
OE 3Q0513049JK — VW
OE 5Q0513029AQ — VW
OE 5Q0513029DG — VW
OE 5Q0513029DH — VW
OE 5Q0513029DR — VW
OE 5Q0513029DS — VW
OE 5Q0513029GA — VW
OE 5Q0513029GB — VW
OE 5Q0513029GG — VW
OE 5Q0513029GH — VW
OE 5Q0513029GJ — VW
OE 5Q0513029GK — VW
OE 5Q0513029GS — VW
OE 5Q0513029GT — VW
OE 5Q0513029HD — VW
OE 5Q0513029HF — VW
OE 5Q0513029HG — VW
OE 5Q0513029HK — VW
OE 5Q0513029HL — VW
OE 5Q0513029HM — VW
OE 5Q0513029HN — VW
OE 5Q0513029LN — VW
OE 5Q0513029LP — VW
OE 5QA413031AC — VW
OE 5QA513029AJ — VW
OE 5QA513029AK — VW
OE 5QA513029AL — VW
OE 5QA513029AS — VW
OE 5QA513029AT — VW
OE 5QA513029BA — VW
OE 5QF513049AA — VW
OE 5QF513049AB — VW
OE 5QF513049AK — VW
OE 5QF513049AM — VW
OE 5QF513049AN — VW
OE 5QF513049AQ — VW
OE 5QF513049BR — VW
OE 5QF513049BS — VW
OE 5QF513049Q — VW
OE 5QF513049R — VW
OE 5QF513049S — VW
OE 5QN513049AP — VW
OE 5QN513049AQ — VW
OE 5QN513049AR — VW
OE 5QN513049AS — VW
OE 5QN513049BF — VW
OE 5QN513049BG — VW
OE 5QN513049BL — VW
OE 5WA513029BC — VW
OE 5WA513029CE — VW
OE 5WA513029CF — VW
OE 5WA513029S — VW
OE 5WA513029T — VW
OE 5Q0513029EC — AUDI
OE 5Q0513029EB — AUDI
OE 5Q0513029GM — AUDI
OE 5Q0513029AS — AUDI
OE 5Q0513029EL — AUDI
OE 8S0513029 — AUDI
OE 5Q0513029BK — AUDI
OE 5Q0513029EK — AUDI
OE 5Q0513029JE — AUDI
OE 5Q0513029CJ — AUDI
OE 5Q0513029CK — AUDI
OE 5Q0513029ET — AUDI
OE 8S0513029A — AUDI
OE 8V0513029F — AUDI
OE 5Q0513029GN — AUDI
OE 8S0513029D — AUDI
OE 8V0513029H — AUDI
OE 8S0513029B — AUDI
OE 5Q0513029CM — AUDI
OE 5Q0513029BM — AUDI
OE 5Q0513029ER — AUDI
OE 8V0513029E — AUDI
OE 8S7513029D — AUDI
OE 8S7513029G — AUDI
OE 5Q0513029HQ — AUDI
OE 8S7513029F — AUDI
OE 5Q0513029HH — AUDI
OE 5Q0513029JF — AUDI
OE 5QF513049BL — AUDI
OE 5Q0513029EA — AUDI
OE 5Q0513029ES — AUDI
OE 5Q0513029FA — AUDI
OE 5Q0513029HR — AUDI
OE 5Q0513029NQ — AUDI
OE 5QF513049BM — AUDI
OE 5QF513049CD — AUDI
OE 5QF513049CE — AUDI
OE 5QF513049CM — AUDI
OE 83A513049B — AUDI
OE 8S7513029E — AUDI
OE 8V0513029J — AUDI
OE 3Q0513049FN — SKODA
OE 5Q0513029GC — SKODA
OE 5Q0513029FL — SKODA
OE 5Q0513029EF — SKODA
OE 3Q0513049FR — SKODA
OE 5Q0513029FN — SKODA
OE 5Q0513029KF — SKODA
OE 5Q0513029FK — SKODA
OE 5Q0513029FB — SKODA
OE 3Q0513049FT — SKODA
OE 5QF513049AS — SKODA
OE 5Q0513029DF — SKODA
OE 5Q0513029KB — SKODA
OE 3Q0513049FQ — SKODA
OE 5Q0513029FQ — SKODA
OE 5Q0513029ED — SKODA
OE 5Q0513029FD — SKODA
OE 5Q0513029GD — SKODA
OE 5Q0513029EE — SKODA
OE 5Q0513029FC — SKODA
OE 5QF513049AT — SKODA
OE 3Q0513049GA — SKODA
OE 5Q0513029KC — SKODA
OE 5Q0513029KK — SKODA
OE 3Q0513049FP — SKODA
OE 3Q0513049FS — SKODA
OE 3Q0513049GB — SKODA
OE 5Q0513029DD — SKODA
OE 5Q0513029DE — SKODA
OE 5Q0513029DL — SKODA
OE 5Q0513029DN — SKODA
OE 5Q0513029DT — SKODA
OE 5Q0513029FP — SKODA
OE 5Q0513029JM — SKODA
OE 5Q0513029JN — SKODA
OE 5Q0513029JT — SKODA
OE 5Q0513029KA — SKODA
OE 5Q0513029KD — SKODA
OE 5Q0513029KE — SKODA
OE 5Q0513029KH — SKODA
OE 5Q0513029KL — SKODA
OE 5Q0513029KT — SKODA
OE 5Q0513029MH — SKODA
OE 5Q0513029MJ — SKODA
OE 5Q0513029MK — SKODA
OE 5Q0513029MM — SKODA
OE 5Q0513029MN — SKODA
OE 5QF513049AH — SKODA
OE 5QF513049AJ — SKODA
OE 5QF513049BG — SKODA
OE 5QF513049BH — SKODA
OE 5QF513049CB — SKODA
OE 5QF513049CC — SKODA
OE 5WA513029AR — SKODA
OE 5WA513029AS — SKODA
OE 5WA513029AT — SKODA
OE 5WA513029BA — SKODA
OE 5WA513029BF — SKODA
OE 5WA513029BG — SKODA
OE 5WA513029BH — SKODA
OE 5WA513029BJ — SKODA
OE 5WA513029BK — SKODA
OE 5WA513029BL — SKODA
OE 5WA513029BM — SKODA
OE 5WA513029BN — SKODA
OE 5WA513029BP — SKODA
OE 5WA513029BQ — SKODA
OE 5Q0513029FF — SEAT
OE 5Q0513029FG — SEAT
OE 5Q0513029CT — SEAT
OE 5Q0513029HT — SKODA / SEAT
OE 5WA513029AD — SEAT / CUPRA
OE 5WA513029AE — SEAT / CUPRA
OE 5WA513029AH — SEAT / CUPRA
OE 5WA513029AJ — SEAT / CUPRA
OE L5QD513029G — VW (FAW)
Edited by Carlston
Thanks Carlston,
As for the B6 on increased ride height cars- whats your thoughts or opinion, is the length suitable?
Spelling
As far as I can see for Bilstein - this is the part number that is needed for my Wagon - 35-229872.
I did some research and we can see the sizes here 548mm:
Also we can notice the specified NOT FOR - Scout ...
However, According to the sizes because If I compare it to the KYB 3358015 above front size is from 520mm to 550mm (550mm that is supposed to be the size for the Raised vehicle ) - it means that B6 should also fit on the OE springs ?
Increased ride height cars are only about 15mm higher than standard ride height cars. If you've ever jacked up a car, you will have seen that the car's body goes up quite a way before the tyre lifts off the ground. Therefore, it might be worth giving the standard ride height Bilstein B6 shock absorbers a go.
As you can see below, autodoc are listing different Bilstein B6 shock absorbers for the (Passat B8 Alltrack, Karoq) compared to the (Passat B8, Octavia MK3, Superb MK3). I suspect it might be better to use the (Passat B8 Alltrack, Karoq) versions for the Superb MK3 4x4 with increased ride height.
Bilstein B6 shock absorbers for the Passat B8 Alltrack and Karoq for the Superb MK3 4x4 with increased ride height.
Bilstein B6 35-273806 front shock absorbers (for Passat B8 Alltrack, Karoq)
https://www.autodoc.co.uk/bilstein/9612727#shock-absorber
Bilstein B6 24-267137 rear shock absorbers (for Passat B8 Alltrack, Karoq)
https://www.autodoc.co.uk/bilstein/9350571
Bilstein B6 shock absorbers for the Passat B8 and Superb MK3.
Bilstein B6 35-229872 front shock absorbers (for Passat B8, Octavia MK3, Superb MK3)
https://www.autodoc.co.uk/bilstein/7522722#shock-absorber
Bilstein B6 24-229890 rear shock absorbers (for Passat B8, Octavia MK3, Superb MK3)
https://www.autodoc.co.uk/bilstein/7543304#shock-absorber
Edited by Carlston
I am not sure that the comparision between Alltrack and Scout is correct because as far as I have  seen an Alltrack - it looks higher than my Skoda.
Also the regular Passat estate is also lower than the Alltrack:
Now, about the link above for the Alltrack version of B6. Its strange that according to the site above, the shown B6s are fitted to VW Alltrack series eg - Golf, Passat, even Tiguan, and for Skoda - only for Karoq. So considering that the Passat Alltrack is higher than Skoda Scout, and the presented part is also fitted to a SUV like Tiguan and Cupra Forementor, Seat Ateca - can we judge that this is not proper replacement for the Superb even with higher suspension ? May be the 'normal' B6 version for Skoda will be better approach? Sadly, It seems there is no website containing that Bilstein B6  Alltrack dampers what size are they to compare with B6 for Skoda Superb  - even the official Bilstein site...
Looking at the gknautomotive.com spring catalogue you can see that the Passat B8 Alltrack has similar length front springs to the Superb MK3 4x4 with increased ride height. So the Passat B8 Alltrack has +15mm increased ride height suspension just like the Superb MK3 4x4 with increased ride height.
This is good news because it means that the below Bilstein B6 shock absorbers should be ok for the Superb MK3 4x4 with increased ride height.
Edited by Carlston
Great info, thanks:  Tonies and Carlston.
Now hopefully to close this off from my perspective, for the FWD estate ( lighter than AWD) it seems  the alternative B6 shocks in your post above Carlston, would appear suitable - i.e.  those for the standard superb mk3
just so I have the info for replacing some time in future.
If you have a Superb MK3 front wheel drive with increased ride height then it might be better to use the Bilstein B6 shock absorbers for the Passat B8 Alltrack because that car also has increased ride height.
However, the Passat B8 Alltrack is 4x4 so maybe the Bilstein B6 rear shock absorbers for that car would be a little firm for use on a front wheel drive.
Edited by Carlston
Carlston:  Thanks very much for your thoughts and experience.
What  youre saying makes a lot of sense and sure you will be right.
TBH although I often carry a heavyish load, my standard rear shocks and springs are currently fine- the problem is at the front - but obviously may need to move to more “ balance up” front and rear if fitting Bilsteins to the front.
So will likely go for the B6 alltrack version for the front and superb B6 on the rear.
Will keep my eye out for any discounts (always hopeful!) and get a set put away for future fitting.
thanks again.
and hope it goes well for you Tonies.
I am 100% sure and ready to order 4 shocks - I just want to be 100% sure which one of both options will suite better for my configuration. I have sent an email to Bilstein with all the details we had here.
Meanwhile, I found another user with Scout complaining about that and reached Bilstein before a few years back:
"Unfortunately we have to inform you, that we don't have a BILSTEIN solution in the catalog for the mentioned vehicle with option Scout, which is softer then series."
That was the short reply to his email. This somehow confirms that the Scout has a soft setup than the regular one.
I am just waiting to see the Alltrack shock size because it seems that even on a Bilstein catalog there is no data for it.
What  you're saying makes a lot of sense and sure you will be right.
If you're going for the standard ride height rear shock absorbers, I suggest you match them with standard ride height front shock absorbers.
After all, the difference in ride height between increased ride height and standard ride height is only about 15mm.
Perhaps try the rear modification first, as not only are the rear shock absorbers cheaper than the front but there's a lot less labour to change the rears.
Edited by Carlston
There's probably only around a 5% difference in the stiffness of the Passat B8 Alltrack springs and the Superb MK3 4x4 Scout springs. Even VAG will use the same shock absorbers for a range of springs that could be up to around 15% difference in stiffness, ie. shock absorbers aren't matched on a one to one basis with springs, they are fitted to a range of springs with different stiffnesses. I've seen this in VAG parts catalogues where each shock absorber might be matched to three or four different weight range springs.
I doubt Bilstein will be able to help you with a non-standard choice of shock absorbers. Until recently, Bilstein were listing their B6 shock absorbers for the Passat B8 but not the Superb MK3. They didn't seem to have the mental agility to realise that the suspension on these two cars is very similar...although to be fair the Bilstein staff would only be able to repeat the information that is already in their catalogues. Some owners took it upon themselves to fit the Bilstein B6 Passat B8 shock absorbers to the Superb MK3 and found that the handling was transformed albeit with the shock absorbers being on the firm side. Bilstein at the time, simply said that they had nothing to offer for the Superb MK3.
Edited by Carlston
You could retrofit standard springs and shocks for a non-Scout but use a gentle lift kit of 20mm to make up for the height. Ive heard of companies in CZ and here in BG that sell these.
When VAG use increased ride height springs they tend to be stiffer than the standard ride height equivalent because the car's centre of gravity is raised, so the stiffer springs help to keep the car stable. Because cars with increased ride height might be used off-road or at least on poorly surfaced roads, the stiffer springs also help the car's suspension from bottoming out.
If you increase the ride height but use the springs from the standard ride height car (by using a lift kit) the springs will be too soft. You could fit stiffer springs but these might not be available aftermarket, as aftermarket tends to only sell what they can sell a lot of.
Even if you did find suitable stiffer standard ride height springs (to go with the lift kit), the standard ride height shock absorbers might then be a little under-damped for the stiffer springs.
A little update and info from my side. I did go to the dealer and asked what are my current suspension setup and I asked for a prat numbers:
Front shocks - 3Q0413031CT
Front springs - 5Q0411105HS
Rear shocks - 3Q0513049GA
Rear springs - 3Q0511115AS
According to the front shock number - this clearly matches the Bilstein B4 but again nothing for B6... I am sure that Bilstein doesnt even know that the Scount is just a Superb with a rised suspenions/bad road.
I am attaching a few pictures that I got in the past from beneath the car. Front one seems to match but am I wrong that I see a different part number on the rear shocks ? It clearly can be seen as - 3Q0512011JC by ZF ? I am confused now.
According to the above information, which bilsten B6 will be most suitable to order for my Scout ?
I thought it was self explanatory that the lift was a gateway to a wider variety of shocks and harder springs as well.
23 hours ago, Tonies said:
A little update and info from my side. I went to the dealer and asked for the part numbers:
These Bilstein B4 shock absorbers are from the Passat B8 and might be suitable for the Superb MK3 2.0TDI/2.0TSI 4x4 with increased ride height. However, it might be best to get the VIN of a similar Passat B8 to your car and find out the OEM part numbers of that car's springs and shock absorbers. You could then compare the Passat's springs with the Superb MK3's springs to make sure they are similar. Check the length and wire diameter. The springs will be similar if they are about the same length and within 0.25mm wire diameter. Then check the OEM part numbers for the Passat's shock absorbers against the below list.
Bilstein B4 22-253415 front shock absorbers (from Passat B8)
3Q0413031AS
3Q0413031AT
3Q0413031BA
3Q0413031BQ
3Q0413031BR
3Q0413031BS
https://www.autodoc.co.uk/bilstein/9266904
Bilstein B4 19-253428 rear shock absorbers (from Passat B8)
3Q0513049ES
3Q0513049FF
3Q0513049FM
3Q0513049GE
3Q0513049GF
3Q0513049GG
3Q0513049GH
3Q0513049GL
3Q0513049GQ
3Q0513049GR
3Q0513049GS
3Q0513049GT
3Q0513049HA
3Q0513049HB
3Q0513049HK
3Q0513049HL
3Q0513049HM
3Q0513049HN
3Q0513049JK
3Q0513049JL
5QD513029AL
https://www.autodoc.co.uk/bilstein/9129924
The Bilstein B6 shock absorbers don't appear to be listed against OEM part numbers.
Notice that the below Bilstein B6 shock absorbers are listed for both the Karoq and the Passat B8 Alltrack. This would suggest that they are both for increased ride height cars.
Bilstein B6 35-273806 front shock absorbers (for Passat B8)
Bilstein B6 24-267137 rear shock absorbers (for Passat B8)
https://www.autodoc.co.uk/bilstein/9350571#shock-absorber
Edited by Carlston
Is there any possibilities that the passat alltrack B6 version is logner than the Skoda Superb standard ride height one?
I am curious from where the differences in the ground clearence comes for the Superb Scout, Passat Alltrack and Skoda Karoq:
 Karoq 172 mm
Passat Alltrack 174
 Superb Scout 151 mm
There is clearly something related between the Karoq and Passat - just as it is stated and pointed that the Bilstein B6 35-273806 is for.
Hows that possible that there is not a single word about the technical data and size for Bilstein suspenions?
Do you think there can be any major differnces in the sizes between the two versions B6 - Skoda Superb standard height and the passat/karoq?
Karoq 172mm
Passat B8 Alltrack 174mm
Superb M3 Scout 151mm
Do you think there can be any major differences in the sizes between the two versions B6 - Skoda Superb standard height and the passat/karoq?
The front and rear springs are very similar between your Superb MK3 280HP Scout and the Passat B8 Alltrack. The Passat B8 Alltrack has slightly stiffer springs, but only about 0.25mm increase in wire diameter which is about 5% stiffer.
The front springs are so close that Kilen/Lesjofors sell the same aftermarket front springs to replace both 5Q0411105HS (your front spring) and 5Q0411105DP (Passat B8 Alltrack front spring).
Lesjofors 4095142 front spring (sold to replace both 5Q0411105HS (your front spring) and 5Q0411105DP (Passat B8 Alltrack front spring)
https://www.autodoc.co.uk/lesjofors/15270767
The 151mm ground clearance for the Superb MK3 Scout seems incorrect, if the Passat B8 Alltrack is 174mm.
The Superb MK3 Scout is clearly increased ride height just like the Passat B8 Alltrack. If it wasn't, you wouldn't have almost the same front and rear springs as the Passat B8 Alltrack.
As the Superb MK3 Scout springs are similar to the Passat B8 Alltrack springs it's probably better to use the Bilstein B6 shock absorbers that are listed for the Passat B8 Alltrack on the Superb MK3 Scout, rather than the standard ride height Bilstein B6 shock absorbers.
The Bilstein B6 shock absorbers for the Passat B8 Alltrack are probably a little longer than the Bilstein B6 shock absorbers for the standard ride height car. This is because the front shock absorbers on the standard ride height car use bump stops with a 70mm height, whereas the front shock absorbers on the increased ride height car use bump stops with a 90mm height. So if the front shock absorbers on the standard ride height and increased ride height cars were the same, using 90mm bump stops would reduce the front suspension travel by 20mm on the increased ride height car. Hence, it would make sense for the increased ride height car to have longer front shock absorbers than the standard ride height car.
Edited by Carlston
