VCDS options on Superb III.FL
  • Replies 264
  • Views 86.4k
  • Why would you want them off? Auto lights are notorious for people driving around in poor visibility and no rear side lights.   Personally I always code them to be on.
  • https://github.com/olli991/mib-std2-pq-zr-toolbox Here you can find out whether it is suitable for MIB or not
  • Paikesejanku
    Paikesejanku
    Yes, you have to change two values: 09 – Central Electrics - Adaptions Search 'scheinwerferreinigung' (headlight cleaning) Select 'SRA Verzoegerungszeit' and set value to '2000' (don't wor
i'm so missing followings, if compare to my previous Mk3 MY16 220ps Style
1. Closing trunk from interior knob
2. Eyelashes with DLR
Hello, thanks for the list, there's a lot of stuff in it, I can't find a trunk lock either, and there's no option for it in the menu...
There is also this thread:
thank you, I need a facelift, and here are more pre versions.
On 07/09/2023 at 09:05, MartiniB said:
17 Dashboard
            Adaptation
            -> Shift exit warning
                        orig.     Car exit warning
                        ->         Exit warning, VW commercial vehicles
IMHO this one may be the warning when you open the door with engine shut down but contact still ON...
17 Dashboard
            Adaptation
            -> Acceleration display:
                        orig.     No
                        ->         Yes
IMHO, this could be to activate the G-meter... Only possible on Sportline version (+ TSI280?) I think.
Edited by Bap33
 I activated 1 using Car scanner pro
Hello, how can I turn on SPORT / PERFORMANCE MONITOR, with the coding in the video below, I did not succeed.
SUPERB 2.0CRDT 12.2022
Thank you.
AFAIK, this is only possible for Sportive versions. Not available for other ones. I've tried unsuccessfully on my MY2018 L&K.
the SWaP/FEC codes cannot b activated using ur standard VCDS or OBDEleven tools.
u need specialist tools for that, ur MIB unit needs to b hacked, and patched with the appropriate files too.
Edited by JR RS
Don’t have it but I do have OBD11 Pro. Can you share what you changed? In case same would be possible with OBD11…
Great job - thanks a lot for these. It’s been a pain to try to find FL coding options on-line, especially those compatible with OBD11.
I see there is one-click app for enabling trailer assist, has anyone figured out the specific adaptations / long coding required to enable it?
What about disabling the tailgate opening warning sound? Instructions I’ve found for non-FL did not work.
Ok, now I saw this in original post:
23.07.05          OK
OBDEleven App
            -> Tailgate Sound
                        orig.     ON
                        ->         OFF
…but what does this mean in practice? 1-click app only?
that means, no detailed info, what exact were changed in parametric area of module,
by compare Long Coding data, before and after, no changes were detected
coding by app method i use only, when no alternative presented
Ok, thanks.
I must have dreamt about the trailer assist 1-click app, I cannot find it anymore 😅
No long coding instructions available either for FL Superb, Kodiaq only and pretty sure the same does not apply…
2.0 tdi, super sport🤣. I did it on my car.
Edited by igrozan
54 minutes ago, igrozan said:
super sport
Mon smartphone automatically corrected « Sportline » into « sportive »…. 🙄
What’s the trick to do it on a non-Sportline version? TIA… 😉
The main thing in MIB was navigation.  Then the toolbox is installed.  The patch is stitched and the swap is transferred.  Everything is working.
Here I changed the image in the "Car" menu
@igrozan
2017. isn't FL, about which is current tread
p.s.
i haven't seen yet Mib-Toolbox for Mib3
Which toolbox and patch are you talking about? Do you mean you´ve uploaded a new software/firmware?
1 minute ago, MartiniB said:
@igrozan
p.s.
Yes, that's right. This only works on MIB 2.5.
Nevermind, it is still there in the app 👍 Along with some other intersting ones, the list on the website is not as comprehensive as what you see in the app once it is connecte to the car...
On 07/09/2023 at 10:05, MartiniB said:
*** Minimize Lane Assist's Ping-Pong Effect
A5 Driver Assistance
            Long coding
                        00020898116E4020089F10001030008001418000000000000000000000000000
            ->         00020898116E4020889F18001030008001438000000000000000000000000000
or         -> Point_of_intervention:
                        early    ->         early_setting_over_menu
            -> HC_Warn_Intensity:
                        No_Setting      ->         Setting_over_Menu
            -> Lane_assist_off_text:
                        disabled           -> enabled
One thing that annoyed with the car (-23 Superb iV L&K) from the start (when compared to old -19 VW Passat) was the normal lane assistant that kept going from sideline to middle line, i.e. the "ping-pong effect". Travel Assist works fine, like on Passat, when ACC is activated, but Passat kept itself on the middle of the lane even without ACC. I hoped this would've helped to reach a similar effect for Superb.
I changed all thee settings:  Point_of_intervention: early -> early_setting_over_menu, HC_Warn_Intensity: No_setting -> Setting_over_Menu and Lane_assist_off_text: disabled -> enabled. This brought "adaptive lane assist" to the lane assist menu and also possiblity to set the warn intensity (no idea what this actually does, the options are low, medium, high). But even with the adaptive lane assist checked, the car seems to behave exactly the same as it did, going from side to side. Has anyone faced this kind of issue? Any pointers what could be tried to overcome it...? Electornics should be in order as the Travel assist works...
Recently Browsing 1
