Kamiq Hill Hold ?
May 2023 Kamiq SE Drive.
Should the SE Drive have the Hill Hold feature?  If it should mine isn't working
Welcome to the forum.
Do you have a car with a DSG?
Is it Hill Hold Assist (Hill hold control) that you do not have, as in from the brake pedal to the accelerator the car does not hold without rolling back for a couple of seconds?
Good morning Rooted, that was a fast reply given that this forum is fairly quiet .
It’s a manual 1.5 SE Drive, as it’s near the top of the range I expected Hill Hold although the Škoda website impies it.s an option but doesn’t say on which model it’s an option, and of course the 2024 model levels are different.
In the 2022 brochure there is no mention of it at all that i can see
https://autocatalogarchive.com/wp-content/uploads/2022/04/Skoda-Kamiq-2022-UK.pdf
It states standard equipment in the 2023 brochure
https://autocatalogarchive.com/wp-content/uploads/2023/10/Skoda-Kamiq-2023-UK.pdf
if your car is a "registered" may 2023 not built in 2023 it is possible it's a late 2022 model build?
Also not sure if the facelift was August 23 before announcing the new 2024 version.
Thanks Stonekeeper for all the info, I can’t see any mention of it as std-fit or option either. FYI it was a “to order” build May5th 2023.
Ooops Stonekeeper,Hill Hold is there in the 2023 SE std equipment. Thanks again.
I’m very pleased with the car, now to see how good, or not, Marshalls are at warranty work. Based on my previous Marshalls (other branch)  experience with my Audi my expectations are not high.
When did you order it?
After a quick dig production change dates
Screenshot2024-03-24at13-00-20kodaOwnersManuals.png.f008dbecd78b780075abc5ce38c40dbf.png
So it appears 2022/11 would apply to your car
No mention of the feature that i can see
That's what i thought i said
A car built before  June 2023 would be a 2022/11 spec
Darn!  Thanks for clarifying Stonekeeper.
Can someone please tell me what difference you have with Hillhold Assist with a manual gearbox and a manual hand brake?
Is the 'Anti-stall' not enough and driving as normal with a manual box?
Sorry for the late reply but how did you get on with Marshals?
If you haven't been there yet, is there an option in the menu to disable it I wonder? I haven't checked because I've only just seen your post but on my daughters Fiesta it can be disabled and just wondered if thats the case here.
Edited by Stoker
Actually I found that my May 2023 does indeed have hill-hold. It only works if I hold the car on the foot brake, then release, it holds the car for approx 2 secs.
I previously thought it was faulty as I always hold the car on a hill with the handbrake, then the hill-hold does not function. Not sure if this normal, it doesn’t seem very logical to discourage the use of the handbrake.
That's normal. If you're using the handbrake just release it as if you're doing a hill start.
Edited by sussamb
I agree with this, if you apply the hand brake the expectation is you use clutch and accelerator in conjunction with it on a manual box to do the hill start.
Having hill hold assist negates the need to do a hill start hence no need to apply the handbrake at all on an incline.
So it makes sense to me to have it activate from the footbrake only.
With the DSG box even simpler. Foot brake to stop, if on enough of an incline hill hold assist activates and accelerator to go.
Surely the creep function of a DSG will stop an auto car rolling back on a slight incline. This may mean that the hill hold is un-necessary ans is use of the handbrake?
Would you ride the clutch of a manual to stop yourself rolling backwards on a hill?
If the stop start activates and the engine has cut out I'm pretty Sure I feel hill hold rather than instant creep on the restart.
I have a 2021 1.0 manual SE Kamiq and I have hill hold. Maybe there was a period with chip shortages when it was removed?
I would hate to end up with a 2022 Kamiq that had a lot of features removed and came with windy windows.
  • 5 months later...
On the auto box cars the handbrake is really considered as a parking brake and the expectation is that you hold the car on the foot brake. Not how I was taught but I was always on manual cars. Friend got reprimanded in driving test for handbrake use. My Merc actually had a foot operated “handbrake” so it really only could be used for parking.
I use handbrake if I'm going to be stationary for a while, eg at traffic lights, otherwise brake lights can dazzle those behind.
OT. &
Not relevant to a Kamiq if no e-brake or no Autohold,  but models that do have Autohold have the brake lights on when stopped and aytohold is active.
  • 6 months later...
Hill Hold requires an electric hand brake. Kamiq is cable operated so NO hill hold
Hillhold assist / hillhold control with a DSG does not require an e-brake. It holds the car for 2 seconds once activated on a slope with the brake pedal pressed. Holds between going brake to accelerator. AUTOHOLD required an e-brake. MK2 Fabia with a DSG and manual Hand / parking brake could have Hillhold.
@marty1945 My manual gearbox Kamiq has a manual handbrake & definitely does have hillhold. It operates on the footbrake.
My Kamiq also will not roll backwards when my foot is on the brake pedal, but if I take my foot off the brake pedal when on a slope, after just 2 seconds the car does start rolling backwards unless I put the hand brake on.
My partners VW Passsat has Hill Hold. Come to a stop on a hill, take foot OFF the brake and the car will stay in place - does not roll backwards.
