Power steering light.
I replaced tha battery and all warning lights are still on I will replace the fuses tomorrow but I think there is a bigger issue.
  • Replies 59
  • Views 5.5k
  • Breezy_Pete
    Breezy_Pete
    Yes, the fusebox on the end of the dashboard. Good, the battery light should come on and then go off as the engine starts. There's a common wiring fault, especially on the diesels where there's m
  • I don't think so; you're wasting your time with that garage though.
  • Breezy_Pete
    Breezy_Pete
    Try to get (and post) a nice, sharply-focussed photo of the strip fuses in the holder above the battery. Sometimes a near-invisible hairline crack in the power steering one can give such symptoms.
I've been doing a bit of playing about this morning 1st  thing there was way to much fluid in the power stearing so I've syringed it out, 2nd thing  light is still on but I noticed if I start engine straight away light is on but if I turn the key wait for light to go out then start it light stays off  I've tried this several times and always the same outcome.
Thanks Natalie; I've added "check PAS fluid level within limits" to my list of "cheap and easy checks".
@Breezy_PeteI'm replacing the fuses can you tell me the correct size for here please as the one I have taken out says110A on it. Thankyou
20240404_135246.heic
Nevermind it's 110 😅 I wish I had become a mechanic when I left school I guess it's never too late to learn 🙃
Edited by Natalie1982
Glad I could help 😆
  • Sponsor
Yes, that second one is 110A, which covers the while interior and its fusebox.
Power steering one next to it in position 3 should be 50A, then the last ones with the dodgy fuses should both be 40A. I would leave the one for the fans (thinner red/black wire) as-is, but change the right-most one with the red/green wire for a 'legit' 40A one. That's the ABS pump fuse.
Clean contact surfaces before fitting new fuses, ideally.
Edited by Breezy_Pete
I've changed all fusses and cleaned, all lights still on though power steering is only coming on now when I start the engine if I wait for the light to go out when I put the key in then start it stay off.
Just took it to a local garage he didn't want to know wouldn't even put it on diagnostic just told me to scrap it he was actually rather rude am I waisting my time trying to fix this car?
  • Sponsor
Bring it over to me in Oxfordshire some time. :thumbup:
There's a few round here that are the same I live in a small town so I guess they get busy and don't need the work so can't be bothered or just don't know how to fix it. I don't know but it's frustrating. I really would like to keep the car running. I'm not giving up yet.
You're only about 2 hours from me I may take you up on that .😀
  • Sponsor
I can't promise to fix everything, but I bet we could understand what needs doing pretty quickly. Might be as simple as a bad connection between alternator and battery. Or the engine earth connection being a bit corroded.
Do you have a multimeter? Or know someone that could lend you one? Could maybe do some measurements that would tell a story.
I have a multimeter. I could do with getting my self some ramps to cause I'm guessing at some point I'm going to need to get under  the car😀
  • Sponsor
Probably don't need to lift the car for the measurements I'm thinking of.  👍
I'll have a think and post more tomorrow.
Ding ding ding ; We have a winner (somewhere between "Don't know" and "Are sexist idiots").
I've encountered a few who don't seem to want to deal with a woman and practically laugh in my face or try to rip me off.
Ok great. Thankyou
I'd love to give you a recommendation but am male and don't live anywhere near you.
I don't see what being male has to do with anything 🙂
Serious answer; I won't get the same sort of experience of sexism as you will.
No I agree. 😭
I have good news maybe 😌 i managed to get the the fault codes for abs and power steering. I took pictures.
  • Sponsor
Might be the actual front left (nearside) sensor, or possibly a broken wire or corroded connection in the loom plug,  Worth checking wiring near connector, and visual impression of connector contacts before spending on a replacement sensor, if poss.
The ABS code I would be suspicious of relating to the blade fuse that the thinner red/green wire is going to (25Amp one?) or damage to that wire between there and ABS module. Unplugging connector from ABS module, and measuring voltage at the relevant connection would be ideal. Will give pin number later.
