Infotainment system switches itself on
Thanks, Martin. However, I am not replacing the screen (or at least not until i find a used H49 version). I just want to unplug the touch bar to temporarility fix the issue. And I saw some instructions that the infotainment should be on before unplugging it, so that's why I asked, to double check whether the ignition and radio need to be on or off during the unplugging.
  • Replies 102
  • Views 34.3k
  • DeelyStan
    DeelyStan
    I have just disconnected the touch bar/volume slider using the instructions from this forum. So far it has fixed the issue. If it helps the exact steps I followed were: Remove long trim piece under
  • MartinOctavia1969
    MartinOctavia1969
    I bought it from a dutch company called vd Ven is a dealer in parts for all cars.. I saw that RRR.lt sold them to. Ebay.co.uk has them. But watch the H49 hardware versions there should be a picture w
  • Well, I had another go at disconnecting the flat cable as suggested earlier in this post. I had both, the black and blue plugs connected and the radio was on (not sure if the ignition was also on). I
Then you can leave everything inplace. All screws van be losing with the cables in place.
Just turn the screen 180 degrees. Then losing the screws and unplug the volume
Hi there! Of course I'm here because of my 2021 Octavia's infotainment system has the same weird behavior described in this topic. On yesterday I was at Skoda Service and they updated the software version to 1989. And of course it did not get resolved.
On some reddit an user posted a video where he solved this issue by unmounting and replacing the sticky link below the volume bar (@mods: can I put the link to both reddit and the video here?).
Just wanted to ask if someone here knows about and tried his procedure (and, of course, if it works).
Thank you all, Max
Edited by meee
