Infotainment system switches itself on
Thanks, Martin. However, I am not replacing the screen (or at least not until i find a used H49 version). I just want to unplug the touch bar to temporarility fix the issue. And I saw some instructions that the infotainment should be on before unplugging it, so that's why I asked, to double check whether the ignition and radio need to be on or off during the unplugging.
  • Replies 101
  • Views 31.7k
  • DeelyStan
    DeelyStan
    I have just disconnected the touch bar/volume slider using the instructions from this forum. So far it has fixed the issue. If it helps the exact steps I followed were: Remove long trim piece under
  • MartinOctavia1969
    MartinOctavia1969
    I bought it from a dutch company called vd Ven is a dealer in parts for all cars.. I saw that RRR.lt sold them to. Ebay.co.uk has them. But watch the H49 hardware versions there should be a picture w
  • Well, I had another go at disconnecting the flat cable as suggested earlier in this post. I had both, the black and blue plugs connected and the radio was on (not sure if the ignition was also on). I
Then you can leave everything inplace. All screws van be losing with the cables in place.
Just turn the screen 180 degrees. Then losing the screws and unplug the volume
