1.2 TSI CBZB gasket part number mystery
Hello all,
Just did the timing chain + oil pump chain + sprocket change to my Octavia with the 1.2 TSI CBZB engine. Everything went well, but I accidentally removed a rectangular gasket near the gearbox.
I thought this was RTV silicone and I ripped it out. Well as you can guess, my oil pan is now dripping from there. I've spent hours on searching the part number or name, but cannot find it. Help please :,)
I'm not sure if this helps or confuses further but the parts catalogue page for the CBZB engine block and sump HERE only indicates gasket goo and not a formed gasket for the sump.
Hey, thanks for the response.
The problem is that this is a hybrid one, uses both in reality (RTV + little rubber strip near the transmission side). The issue is that instruction videos never even tell about the rubber gasket near the transmission side. The RTV comes top of the gasket, but if it's missing there's a nice gap, roughly 2mm in depth.
I just understood that I had to scrape all old RTV material out and did the same to the gasket strip..
Argh what to do. If I don't find a part number, I need to cut out some cork and make a gasket out of it..
The only thing that reads on the gasket is 'AEM', nothing else. If this is only available with the engine block, there's no hope for the original part..
Have you looked at the link?  The picture definitely does not show a sump gasket of any sort.
I've tried general searches on skoda-parts.com for 'cbzb sump gasket' and 'octavia sump gasket' but nothing shows.
I suggest you try a call to a Skoda dealer in the hope that either their parts people or a mechanic can shed any more light.
BTW how about making one up using RTV?
  • Sponsor
Can you not just fit the broken bits of the original, with a little help from sealant to hold together?
Unfortunately the original looks too damaged :/
7 hours ago, Breezy_Pete said:
Great shout @xman: the image  here shows it quite clearly as just that:
Rear Crankshaft Seal with Flange Germany 036103171B (skoda-parts.com)
7 hours ago, xman said:
03f103019j block is a CJZC engine (EA211 cambelt) , 03f103101b is a CBZB engine (EA111 camchain)
No such gasket showing on parts diagram unless it comes with item 11
036103171
https://spareto.com/oe/036103171b
Thanks a lot guys. It seems that it comes with the rear crankshaft seal assembly (036 103 171B)
Mystery solved! Ordered the part (FAI brand) for 25€ shipped.
Little update to this: canceled the part order, took Mike's advice and formed a new gasket with a thick layer of RTV. This worked and there are no more leaks. :thumbup:
