No Users function in the menu
“Users” selection missing from the menu
I have a 2022 Skoda Kodiaq and I am not able to add or set user to the system. Only I have the physical buttons next to the seat. I had this feature on my Superb and it was so easy to switch between the drivers/users. Any idea  to install it on Kodiaq?
Edited by KodiaqAdmin
personalization may be in the menu, but it may not be as the car is too new. Depends on the key used to unlock as which user is identified, I believe.
But Users, in the Menu on a Superb? Never seen, mine never had it. Personalization somewhere, yes, but that did very little, and it was in the car settings menu (not the one visible there).
There was no users option on the screen on my Superb. It was called personalization as you mentioned. My point is I am not able to personalize/add/set drivers to the system. I have seen that personalization option moved to the Users option but I don’t have that option tho
The ‘personalisation’ feature related to the adjustment of the seats, mirrors and drive mode was a factory cost option on the Kodiaq, determined by the supply of a third key. Do you have two or three keys?
Unless you have the third key it is unlikely that you’ll have personalisation.
I believe it can be ‘activated’ using VCDS or OBDEleven etc. even without the third key.
I guess that’s the problem. I have only 2 keys. I had 3 keys for the Superb. Do you think I can activate them using the tools that you mentioned?
I activated personalisation on my 2019 Kodiaq with VCDS. Not sure it could be done on 2022 model.
It was done on my MY21, after it was missed off the order, by the dealer's tech guy, but I don't know how or with what tools.
I can give instructions but as VAG has cut off the access to the ECU then someone has to confirm it can be done on 2022 model.
I believe even OBD11 was capable to do it. Which is much cheaper option than VCDS.
Thank you all. I will check your opinions.
