Suspension upgrade installed
Since last year i had replaced the following
H&R Front & Rear ARBs
Whiteline adjustable drop links front and rear
Superpro front lower arms
Bilstein B6 shocks front and rear
It has transformed the car so much feels lot nicer then before. So much more responsive then with stock set up.
Springs are still standard no plans to be lowering it...yet 🤓
I had tracking done after and everything aligned spot on. No uneven wear on tyres since then.
The Eibach pro kit works extremely well with those shocks. No rubbing even with 4up and the dog in the boot.
Sits lovely and rides better than standard springs.
Sounds good to me... What is drop on the eibach kit? I still want it to remain practical
red numbers in my table
It dropped a bit. Maybe 5-10mm. The adaptive dampers already let it sit lower as standard. I think the total drop from a standard factory setup without adaptive is about 20mm.
I’ve had no issues whatsoever. No more hitting bump stops over the slightest thing and has never been a problem when filled on journeys. It practically doesn’t dip at all when 4 up. No problems over speed bumps etc.
Edited by UndertheRadar
If u get the Pro-kit version, and u have DCC shocks - it will drop approx 20 to 25 mm.
Standard shocks will see it drop approx 35 to 40 mm.
Edited by JR RS
Is there anything that lowers it little less? Only looking for 15-20mm max
Mine is standard not DCC
Edited by MarioVrs
I'll look into it thank you mate appreciate it
then choose one in between
@MarioVrs What Superpro arms did you use? I've ordered and received some TRC1070s and now finding conflicting stories about whether they're right for the car or not. Do you still have them on?
