Amundsen MIB1 Firmware update finally completed - MSTD_EU_SK_P6230 MU0490
I used a copy of this MSTD_EU_SK_P6230 MU0490 if anyone else needs, the site I think I had it from was mibsolution.one is currently down though.
I was wary of the copy I had and passage of time, but it worked fine installed, I just have to clear the fault code ( have odbeleven but pro ran out and doesn't cover the adaption by looks of it)
Excuse the state of my interior I don't use the car that much and could use a vaccuum.
  • Replies 110
  • Views 9.7k
Would you be able to send to me? I have the same infotainment part number, currently on MSTD_EU_SK_P3420. Out of interest, which fault code are you getting?
Don't worry. @pab567 sorted me out with the files. Will give this update a shot this weekend and report back!
Any chance to get a download of MSTD_EU_SK_P6230 :-)?
If anyone find MSTD_EU_SK_P6230 please send it please
@Ripmax12345 @pab567 Could you eventually provide the files again?
Sent in PM
Great, thank you!
@pab567 send me the files please
Thank you
Sent in PM
could you share the file with me too
On 13/06/2025 at 14:04, pab567 said:
Sent in PM
Could I have it too please MSTD_EU_SK_P6230
Hi, I have a Škoda Octavia 2014 with Columbus MIB1, HW 5E0 035 043 A. Could you please send me the firmware package MSTD_EU_SK_P6230 (MU0490)? Thanks in advance!"
Hi! I want to update a MIB1 Amundsen in a Yeti built 2013. The hardware is H72 and the current software is 0407.
Could someone send me the update files from MSTD_EU_SK_P6230 MU0490, please?
On 13/06/2025 at 13:23, pab567 said:
Sent in PM
On 13/06/2025 at 15:04, pab567 said:
Sent in PM
MSTD_EU_SK_P6230
Sent in PM
Can u sent me this update too? MSTD_EU_SK_P6230 update.Many thanks!
Sent in PM
MIB1 units have NEVER been used in yeti - only MIB STD2 PQ. You must be wrong.
All others pls check your PMs.
It's NOT a firmware for your unit - it's for Bolero MIB1 and AMundsen MIB1 and yours is Columbus MIB1.
Hello guys! I have a skoda octavia mk3 2014 is my unit compatible with MSTD_EU_SK_P6230 (MU0490) firmware update?
another question, how should I install it on the SD card? unzip the archive and copy the contents to the memory card or do I need to go to the root folders one by one and copy the contents from there and put it on the SD card?
My apologies for the revival, can I get a download link @pab567 ?
Thank you so much!
Link sent in PM.
1. format SD (best max 32GB) under FAT32
2. unpack to root (metainfo2.txt and all the folders must be placed directly on SD, not in any folder)
3. insert SD card into the slot
4. enter Service Menu (long press MENU button)
Hi Pab567,
I have a 2017 registered/manufactured 2015 Skoda Octavia Mk3 with the following hardware and software versions.
Please can you send any relevant updates (and instructions on how to install them) and let me know if it is possible/how I can get smartlink activated and link with Android Auto.
Sorry I can't PM as I am new to the site.
Can I have the download link please?
Thanks in advance
Hallo, suche auch die aktuelle Firmware für den Skoda Octavia Combi III 5E mit MIB1 (siehe Bild).
Auf /mibsolution.one kann ich leider nichts mehr finden. Kann jemand bitte helfen?
Danke schon mal im Voraus
