Intermittent "Oil Sensor Service" Warning - Oil Temp disappears (---) - Superb MK3 1.8 TSI
Hi everyone,
I'm struggling with a persistent but intermittent issue on my 2018 Skoda Superb (1.8 TSI). I would appreciate some expert insight before I spend more money on unnecessary parts.
The Symptom:
Randomly, I get the orange "Oil Sensor: Service Vehicle" warning with a beep.
What I've observed (The "Smoking Gun"):
I’ve been monitoring the Oil Temperature on the Maxi-Dot display.
  • When everything is fine: Oil temperature reads normally (between 96° and 104°).
  • When the warning pops up: The oil temperature immediately disappears and shows three dashes (---).
  • After a while (sometimes minutes, sometimes days), the warning disappears and the temperature reading returns.
What has been checked/done:
  1. Sensor: The oil level/temp sensor has been replaced twice with a Genuine OEM sensor.
  2. Oil Level: Manually checked via dipstick, it is at the MAX line.
  3. Hood Latch Sensor: Confirmed working (I get the "Hood Open" notification on the dashboard).
Since the oil temperature vanishes exactly when the error occurs, I suspect a wiring harness issue or a loose pin in the connector rather than a faulty sensor.
Has anyone encountered this specific behavior? Are there known "rub points" in the wiring loom for the 1.8 TSI engine that could cause such an intermittent communication drop?
I am attaching two photos: one showing the normal temp reading and one showing the "---" with the warning light.
Thanks in advance!
Edited by AviWrx
How old is the battery?
How old is the oil?
Battery replaced by previous owner in January 2025
16 hours ago, BlueWagon said:
How old is the oil?
Oil changed in September 2025
Id be going down a diagnostic route. Check fault codes and report. May give an indication if it's a decide fault, wiring issue or something else causing it.
Have you added anything or changed anything on the car recently? Bulbs etc.
I will be at the garage again tomorrow and ask them to scan the fault codes again if there are any.
And I haven't changed anything in the car.
