Retrofite Blind Spot...
So,
Today we started installing and wiring the radar sensors.
Since it's the facelift rear end, we installed the OEM bracket for the 2Q0 radar sensors.
At the same time, we installed the tow hitch.
The mechanical part is mostly finished; the cables are in the trunk and all that's left is to route and connect everything inside the car. Coding is also required, of course.
A few photos.
I believe the Rear Traffic Assist (not maybe by this name, but you know what I mean) uses the same radar. So try to activate also this. Cannot thank enough this aid to avoid Schumachers in the parking lots.
I know, thanks
RTA short Form
Edited by Cairus
@Cairus- Hello, I am also interested in this topic. Can you tell me where they bought the electrical wiring and what code it has?
Regards
You can buy it on AliExpress or DIY
Edited by Cairus
Are all parts you are using OEM? Or all from AliExpress?
Does the kodiaq have the warning lights on the glass or the mirror covers?
I’m thinking about adding this to my Superb but was looking at the generic kits and then thought about connecting the indicator wiring to OEM lights in the mirror caps.
Control units, brackets, etc., are all OEM parts. Here in the Kodiaq, the visual display is integrated into the mirror glass; these are aftermarket parts because genuine OEM glass costs over €300 each. The wiring harness is partly self-made and partly sourced from AliExpress. It always depends on the current price.
In my Seat, i have the mirror Cap solution(Retrofit Area View)
Edited by Cairus
@Binx1310
Beitrag im Thema 'Vom Superb II zum Superb III' https://www.skodacommunity.de/threads/vom-superb-ii-zum-superb-iii.107347/post-2534538
  • 3 months later...
It continues, in 34°C shade... Driver's door fully wired for lane change assist, only one connector is missing... Driver's door lock also replaced, because it sporadically wouldn't open.
How do you get through from car to door? Is there somewhere a cable can pass through or do you go via a connector.
I have bought an aftermarket Ali express kit and plan to install as proof of concept with the included indicators for inside the cabin but if it works well will add the indicators into the mirror caps but will be non standard wiring to get through to the door so hoping there’s a hole (or a hole can be made) to pass cables through to the door without pinout on a connector.
Use the original wiring. That means the connector at the door near the A-pillar; for me, that's become a boring job.
Is there any spare space in the connector to drill a hole through for non standard wiring. Did that on my mk3 golf many years ago
Enough free Pins, Picture?
Not had a look. Just trying to be lazy and avoid repinning plug
It is so simple, i mean want Pictures from my Car?
Edited by Cairus
I Like IT
@Binx1310 Picture
thanks.
Are the pins in the connector and you just have to connect to wires or do you buy pins and then add to connector?
@Binx1310
No, the connector only has free pins. So, pull the cable through and crimp the pins. I'm not satisfied with the SWA LED solution in the glass. I ordered OEM facelift mirror caps with integrated SWA, LED inserts, and the connector for them.
Oh ok. I’ll have to take it apart and have a look.
I’m planning on using Passat b8 lamps and cutting the Ali express mirror caps to fit them in. If that fails I’ll order the Ali express mirror caps with the lamps mounted in as @JR RS did.
Why Not OEM?
Cost. Trying to do it all as cheaply as possible as it’s a “nice to have” feature that I can enhance as a little project for a low price and basic skills. All in will be less than £100 and look OEM. Functionality may not be as good but I don’t have it now so anything will be better than nothing.
Yesterday i Finish the Retrofit
Can you describe the OEM behaviour of the lights? Do they increase in intensity with proximity? Do they behave differently if you are indicating at the same time as something in your blind spot?
Going to have a go at fitting my non-OEM kit this week and see how it compares. Will then look to connect to OEM lights in the wing mirrors if it works well.
Also can you describe how much coding was required and did you have to remove component protection? Just in case I decide to go down the OEM route.
Guten Morgen.
OEM kann man die Helligkeit einstellen. In dieser Einstellung Leuchten diese konstant, ausgenommen es ist eine Gefahren Situation bei Spurwechsel. Dort ist die LED immer am hellsten und blinkt extrem schnell.
Wenn ein Fahrzeug erkannt wird, leuchtet die LED in der gewählten Helligkeit auf, solange wie es eben das Steuergerät sagt.
Codierung ist ein wenig was.
Good morning.
With the OEM settings, you can adjust the brightness. In this setting, they illuminate constantly, except in a dangerous situation such as a lane change. In that case, the LED is always at its brightest and flashes extremely rapidly.
When a vehicle is detected, the LED illuminates at the selected brightness for as long as the control unit specifies.
Coding is a bit involved.
Recently Browsing 2
