Need help to identify missing plastic under trays and their code number -Monte Carlo Fabia 2013 mk2 TSI
Hi , Can somebody please guide me wht are plastic part numbers which are fitted as to cover engine from underneath e.g under tray, the car is Monte Carlo Mk2 13 plate ( Car is leas than 50k), possibly need driver side actuator as well and need part number of that as well if possible, I shall look up on https://www.skoda-parts.com/online-store.html incase if somebody have experience of opening bumper please advice , I saw underneath there was no plastic cover . I have also seen wheel liner front plastic part was loose and hanging possible missing some screws. I would like to see if mechanic can open bumper and fix properly everything after buying necessary plastic parts attached underwear with bumper. If any body have done bumper replacement please ping me I would get rough idea about efforts and parts needed to get things done properly.
Also please let me know if somebody have done driver side wiring fix, repair work as my central lock is not working , may need repair / new driver door actuator.
I am getting done major service please advice i am missing any thing.
  1. MAP/MAF Sensor cleaning
  2. crank sensor cleaning ( if any )
  3. Engine oil change
  4. Oil filter
  5. Cabin filter
  6. Spark plugs - change
  7. Brake fluid bleed
  8. Coolant flush
  9. Gear box fluid Change
  10. Steering fluid change ( Hope it can be done easily ).
  11. Not sure of Fuel filter ??
  12. Battery is new Already
  13. Oxygen sensor cleaning
  14. Antirust under-seal coating ( Any idea which brand is best )
Any thoughts please would be high appreciated.
Thanks for your time.
Kind Regards
raky
  • Sponsor
Car Parts Catalog - LLLParts
2nd line down on that page, 6R0 825 237D is the only engine undercover I would expect to find on your car, I think, but message me the VIN if you wish me to check properly.
Your service list contains a lot of items that should be deleted, complete waste of time and money, items 1, 2, 9, 10, 11, 13.
Seriously; all of those are more likely to cause a problem if touched than to offer any benefit.
A good mechanic should probably refuse to do most of these, knowing the waste of their time and your money.
9 and 11 might be worth doing in about 100k miles' time.
Item 8 is also probably unnecessary but less likely to cause a problem, although a vacuum/pressure refill is recommended on the rather complex cooling system of these engines. Air pockets can remain and take time to work their way out otherwise, I understand.
I don't have experience of using such equipment.
Buy a genuine oil filter from Skoda, and make sure your mechanic doesn't leave behind the old seal when changing it; bad things happen to oil pressure and engines which suffer this accident.
Edited by Breezy_Pete
Dear Pete , As always grateful to your for invaluable advice, Once I complete VCDS scan I shall contact you for Actuator parts number as well to me it seems the current driver door lock actuataor may be wrong part fitted by mechanic and it has printed on it 26C1S2837016B I think google says 1S2837016B number what matters. The website Skoda-parts.co.uk advice buying OEM part 5N1837016C, 5N1837016M, 5N1837016A, 5N1837016E, 1S1837016C for Monte Carlo mk2 tsi driver door actuator. I shall keep u posted progress will definitely take your advice.
26C → internal factory/mould code
1S2837016B → the actual OEM part number
Once again appreciate your time.
Kind Regards
  • Sponsor
Need VIN to look up parts properly, I would expect right-hand drive (rhd) drivers' door locks to have 2 as the third character, I think. Probably 5N2 837 016C, but need VIN to be sure.
  • Sponsor
Found VIN in a message from you.
Correct door lock module part number is 5N2 837 016C, for driver's door.
Strangely, that seems to unavailable from Skoda as a spare part since before this car was built, with no supersession shown in partslink24. It just says:
5N2 837 016 C Door lock PR:L0R+4F1/ 4K3 £90.97
Dropped: Oct 1, 2012 (EKZ: F) Please contact your dealer for the parts interpretation.
I don't understand that.
Skoda-parts.com seems to list some alternative compatible part numbers at the top of this page: Door Lock - Front Right Škoda 5N2837016M
Note that all of them have 2 as the third character, as I would expect for rhd car.
  • Sponsor
It may be a good idea for you to do this, as mentioned on skoda-parts site:
TIP: Did you know, you can check parts compatibility with your vehicle using chassis number? Sign Up or Log In to your account and add your car to virtual garage.
  • Sponsor
Engine under tray part now confirmed correct with VIN. 6R0 825 237D
Dear Pete , So kind of you for your time and advice .
Stay blessed regards
Hiyeah ,Looks like current fitted actuator (26C1S2837016B) have 7 pins socket and may be compatibility for Volkswagen Up model from 2011 to 2017 for 3 door cars , as @Breezy_Pete advised OEM parts 5N2837016C, 5N2837016M for my fabia , both have 6 pins as per online specification.
MY driver door wiring loom OEM number 5J0120GK as per sticker attached, and motor oem number 6R0. 959.802.AN ( 42556A Inteva ER MR6) look possibly correct part for fabia mk2.
I have also noticed that actuator plug on wiring loom(5J0120GK) have 7 pins as well. hopefully VCDS scan and will give me some insight and no wiring issue.
This existing door lock actuator (26C 1S2837016B) may NOT suitable for Fabia mk2 driver side for sure but may work passenger side of fabia.
Thought this info may help others.
kind regrds
@Breezy_Pete Much appreciated your support as always , I got fitted 5N2837016E which seems locking /unlocking the car and even car making alarm of forced entry test done when one door was not closed, and also as advised 5N2837016E had same PR:L0R+4F1/ 4K3 features like 5N2837016M , FOB is still issue will scan and see if programming issue or some receiving module/ecu issue will investigate with vcds and update , but at least car is getting locked/unlocked mechanically with key .
I have also ordered part 5N2837016M worst case scenario from Germany Autodoc.
Thank you so much
Kind Regards
