Wrong suspension springs -help
Can someone please shine some light on this ?
Time came for the Eibach springs to get fitted last week only to find out that the rear springs don't fit at all. They are hitting rear droplinks without any weight put on them. Yes i know the springs are for estate and my car is saloon but they don't fit. Unless my mechanic doesn't know how to fit them I'm really lost. Pictures attached below
It looks like the F11-79-008-01-HA rear spring (and E10-79-012-04-22 kit) isn't for a Superb MK3...but a Superb MK2 and other VAG cars that were based on the Golf MK5/MK6...
The eibach de website has an online catalogue that should list suitable kits.
https://www.eibach.de/en/iam
Edited by Carlston
That's what i thought...Autodoc is trying to say they sent correct kit but each spring might differ in part numbers ( obviously) and are now doing anything to avoid refund...
Autodoc’s scattergun approach to parts supply.
H&R rear anti roll bar?
The correct rear springs for a Sedan/Saloon mk3 Superb is F11-15-007-04-HA.
I've lost count how many times I've posted this table now.
Don't go by wat these shops r putting on their websites.
Edited by JR RS
Yeah they are cr*p avoid at any cost.
They now have charge back initiated by my bank.... their approach to solving problems is ridiculous.
Yes H&R front and rear 💪🏻
Edited by MarioVrs
This must surely be your favourite topic on here John 😁
Yeah these were wrong from the start but autodoc has moved it to another level by putting two different springs wrongly into wrong box 🙈
isn't your spring mounted too much forward?
picture is with OEM, but diameter is same
Not sure mate but this Eibach spring definitely is bigger diameter than my stock spring🤔
Umm. This statement is the answer. Wrong part number for the car, therefore don't fit!
@MarioVrs
your looks different to one which i installed on my previous FWD car
No quite right... estate springs still fit hatchback but don't lower as much on rear as specific spring for hatchback would as estate is slightly heavier. What i received is completely different rear axle spring.
2 hours ago, MartiniB said:
@MarioVrs
Yeah that's what i mean... On your picture above the Eibach is quite a bit shorter than original spring, what i received is almost identical length but wider diameter 🤔😣
Anyway I've opened a dispute with Autodoc because the way they handled this is ridiculous...
Edited by MarioVrs
It's so frustrating dealing with companies like that!! They're either easy to deal with or a major pain in the bottom!!
Hope ur able to get a resolution soon and get the right springs sent ur way.
Edited by JR RS
Thanks mate 🙏🏻 it certainly has been a major pain in butt for me with mods this year 🥱😣
I hear that; last weekend - wrong LCAs, last minute realisation that Superpro front droplinks were still too long for lowered suspension so had to get new ones.
3 hours on one rear droplink because it just would not fit in the lower arm - had to jack up the other side to bring the tip of the arb into position, fit the end in the arb and persuade the base into the lower arm.
Car fought me and @OccyVRS on everything and the final straw was me not getting the front pendulum bolt lined up in the DSG casing and butchering the thread. That now needs to be helicoiled 🤦🏻‍♂️
May also be that I’ve been too ham-fisted and either damaged a wheel speed sensor (or hopefully just dislodged a plug) which is causing some of the Christmas tree effect currently on the dashboard.
Appreciate it’s not a competition, just securing my position on the bandwagon.
It'll be interesting to see what the cause of the DTCs is - @travs was fairly rigorous with the mallet, but I will be suprised if one glancing blow onto the dust shield or knuckle would knacker an ABS sensor.
In all fairness, it was a joke of a day. Absolutely nothing played ball, and everything required three hands and a lot of "well, what if we...".
Knackering the thread was disappointing, but by 10pm I think we were both pretty tired. Certainly, it's been the worst day of ratcheting since getting the BMW stuck in neutral after triggering an airbag failure the day before a fourteen-hour drive.
I don't understand why VW would fit external corrosion-prone components with small triple square fixings - absolutely useless. Bear in mind, too, that the car isn't exactly old, or that high mileage. Sure, we aren't mechanics, but with decent capability and the correct tools, it should have taken less than four hours to do two rear droplinks. Quite why one side required the weight of the car to push the bushing in, while the other just popped in, we shall never know.
Oh, and for those wondering - yes, you can drive a mile or two with the locking wheel bolt key fitted to the wheel ;)
I managed to do this but didn't realise until the car was in the garage having a broken spring changed! Turns out you can match them by eye and buy a new key from amazon for a cheap price, kind of defeats the object of having them, so I am now back to normal bolts on all wheels!
On my track record, that's good to know!
I've bought the same Eibach pro kit and my rear spring is hitting the rear droplink aswell without any load!
It's doing my head in. as mines is an estate do i go for F11-15-007-04-HA or F11-85-016-10-HA?
Not sure i coudl return the kit now as its been installed for 6 months! lol.
some shops still offer kit E10-79-012-04-22 (F11-85-042-03-FA + F11-79-008-01-HA) for AWD Superbs Mk3
-> https://www.eibachshop.co.uk/products/eibach-pro-kit-lowering-springs-e10-79-012-04-22
when i order for my previous FWD, i was sure it's from AWD,
because that were the goal, avoid huge lowering as with FWD springs
the main question is, how springs with the same number can be that different?
p.s.
have you try rotate spring around its axle?
p.s.
Not tried it, I will do next time it's up on the ramp and let you know
