Advice please on DMF
Morning all wise people.
Dilemma time. Been running a 2015 L&K 2.0 estate superb for coming on 2 years. Got as a stop gap but love the car and has been brilliant so kept it. It’s now done 280k miles but is virtually perfect …apart from DMF starting to go.
Do we think it would be pointless to change the DMF and clutch only for something else to go in another 10k miles. Local garage who is use for other cars has quoted about £1200.
Alternatively I’ve seen a kit with clutch for around £400 with a discount. Is it insane to try and do this on the drive?
Other alternative if can get the kit cheaply is anyone likely to fit a f and clutch kit I’ve purchased ?
Thanks for any advise in advance!
Doubt it would be easy on drive. Main problem will be getting car high enough to get Gbox out in the first place plus cant see the Gbox being much less than 60kg. Did my sons Fabia using a beam that sits accross engine bay and supports engine and gbox independently. I couldnt get car high enough to get Gbox out but managed to swing it out of the way enough to get to clutch etc. £1200 is probably about right. £400-600 for clutch and dmf and aprox 5-6hours labour as long as everything goes to plan. Reckon its a garage lift job unless you have access to a inspection pit. Factor in a new clutch slave cylinder at the same time.
Alasdair
Ive done gearboxes on the floor before but its a right PITA, thats on the floor of my mates barn, which is set up as a workshop with lifts (sadly none were free at the time).
Its not that its a really challenging job its more that gearboxes are just a terrible shape and weight to man handle, took me and two friends to get mine back in and Im pretty sure I was nearly crushed to death by it about 4 times.
@Alasdair1 has covered the other main points, id just do the master cylinder for what they cost its not worth not doing it, some clutch kits do come with them included.
