Fob dead locked out? What if?
Anyone know how  long a fob battery lasts before needing replacement? How do I change it?
I saw a video on line which seemed awfully fiddly involving a long thin screwdriver and much twisting. Why are these things so complicated? Do we get a warning of impending flat  fob battery?
I read we can use the emergency key to gain access if locked out. It said to put the emergency key next to the start/stop button and the car will open. How do we do that if we are locked out?.
I bought a 2023 Karoq and wonder if I made a mistake, what with the constant updates etc.
There a lock near the keyless sensor on the handle: You need to remove the smaller cover. Inside the fob, there a small key to open the car. Then the car should start even if the fob battery is dead, as it uses something like a NFC sensor to start which has not to be necessarily powered
Thanks for this. After searching, I see a small rectangular hole underneath the handle. Is that where I insert the probe from the fob?
When you say remove the smaller cover, do you mean the cover at the left hand end of the handle? How does it come off?
Do we get a warning if the battery is low?
Thanks again for helping.
A battery lasts as long as a battery lasts. Someone using the car multiple times a day obviously won't get the same use as someone using the car a couple of times a week.
There should be a low battery warning on the car's display to prompt a battery change. But given that the Panasonic batteries that are fitted at the factory cost around £1, probably easier to just replace it annually or at whatever point you choose.
You can open the back of the fob by withdrawing the emergency key around 50% & using that to push against the battery cover. You need to press a button on the fob after removing the old & before inserting the new. Like most things, harder the first time you try it. 😉
As above, you pry the cover off the door handle to access the manual lock, which the emergency key fits.
Not sure what's changed but I think the warning is better now. It comes up when the ignition is on before the car starts, but the trouble with keyless start is it flashed past that stage very quickly. However I think the warning shows better now - we've had it recently in our Karoq, Kamiq and SEAT Ateca.
Daughter used to run the Ateca (2018 model) and that did go through a phase of the fob just dying and it always seemed to happen when she got to work. She became a dab hand at popping the lock cover off (there's a hole underneath for the key blade to go in) and getting in (the alarm will go off) and starting the car (which stops the alarm). But since I had the car (18mths) it's told me it needs a new battery - did it a few weeks ago.
On the Kamiq that can be opened from the Skoda App. The daughter that drives that keeps a spare battery in the glove box just in case.
Edited by Rory
Thanks to all for taking the trouble to help. Why oh why can't we go back to a simple key to access and start?
If the little red light on the fob doesn't flash then reach for the 2032's before it lets you down - I test for the flashing light before each service inasmuch as the dealer picks up on it and offers to do the change for a kings ransom.........
@Cqrmine if you read the handbook most of your queries are explained there. Page 23.
Just over two years on mine! Car new in Oct 24 and just started getting the 'Replace key battery warning' . Car not used frequently (I'm retired) , just two to three times a week.
Already had Panasonic CR2032 spare batteries, replaced the one in my key , I guess the other key (which hardly gets used) will need replacing soon. Tried using the key blade to open the key as described in the manual but couldn't get it to work. Found post on here showing exactly how to use small flat bladed screwdriver to release cover easily!
I too tried to follow the manual instructions to access the battery (page 24) and it didn't work. Where did you see the instructions with the flat bladed screwdriver to open the cover?
They charge for changing the battery???? Of all the robbing *****
I looked at pages 23 and 24 and they don't work for me.
No need for screwdrivers, which is probably as well given you're unlikely to have one in your pocket if the battery suddenly fails. Release the emergency key & withdraw just enough until the black plastic clears the case. Then with the fob in your left hand, gripped between thumb & knuckle of the forefinger (thumb under the key to brace), grip the key by the plastic part in the same way. Then exert a snapping motion upwards on the key & the blade will pop the cover off.
As I said originally, harder the first time but easier thereafter.
that's because using the key blade forces the cover off damaging the catch. Using a screwdriver actually releases the catch properly and so doesnt damage it
Edited by NottsIan
It's the official way & doesn't damage anything. 😉
Edited by Rbz5416
25 minutes ago, NottsIan said:
@Cqrmine here's the post https://www.briskoda.net/forums/topic/436650-kessy-key-fob-battery-change/
go down to about the 4th post and it shows a picture of the inside of the key and the small tab that you are trying to free with the screwdriver
Many thanks. I still can't get the thing to open. Ho hum. I have tried pressing down hard as per illustration but the thing won't open. I dare no press and harder in case I damage something.
If it won't open you're doing it wrong, or you have a different key style.
You just need a brave pill, you're just prising two plastic pieces apart & they're not brittle. Maybe resort to a screwdriver for the first time, as it will give you more leverage to push the cover up. This is a rough sketch of how the cover sits on the fob. So you need to exert enough force for the "claw" on the cover to snap past the lip they sit on.
The "catch" referenced by @NottsIan is a bit of a misnomer IMO. What that method does is push the edge of the cover away, so that the leading edge of the "claw" can be eased over the lip. Kind of a "starter for 10", but the rest of the edge still needs to be snapped free. But worth a try if you're still struggling.
As I've said a couple of times now, the first time is the hardest & will require the most force. Once it's popped that first time, subsequent opening will be easier.
Can y0u prescribe me a brave pill please?
I have had to change mine a couple of times. I always have a spare battery in my wallet and another in the top cubby hole just in case, always Panasonic.
4 hours ago, Cqrmine said:
Can you prescribe me a brave pill please?
shopping?q=tbn:ANd9GcQklaDR5LB1xvlHakRmt
Good plan.
Be aware that PANASONIC are one of the brand of batteries often faked. So you need to be buying from trusted sellers, maybe not from Online market places and especially the ones where the items get to you from China quicker than a UK/ EU / European seller.
I hope Amazon Duracell are OK.
BTW, we have a Mercedes 62 reg C180 with 20,000 miles showing and the key fobs have never been changed. Could Skoda fobs last that long?
