Bixenon Headlights auto-adjustment problem
@AroCz - which channel r u reading the values from? I'm assuming this is on module 55 - Headlight, given urs is MY16
This is the Basic Settings values of mine (with DCC). However this with all 4 wheels hanging, for the DCC Recalibration procedure.
I'll c if I can get the readings with the car sitting normally.
Edited by JR RS
I’m travelling at the minute but will see if I can read level with my scanner when I’m back at my car as I don’t have dcc
Guys, thanks for the reponse.
Binx1310, awaiting your data!
A thought though. I wonder if it might be irrelevant anyway. May give you some info of relevant position but with regards to the precise number, @JR RS has me thinking. does the adaptation without dcc have to be done in the same way. E.g jacked up with wheels hanging at full extent to find a max extension and then all compression of suspension is relative to that figure.
Edit: just had a look at the manual and it only mentions basic settings for dcc. Will let you know what my numbers are when I get a chance to look.
Edited by Binx1310
The difference is that with DCC, the sensors are processed by the DCC control unit, whereas otherwise, they are handled by the BCM (Body Control Module). The system stores information regarding which axle is installed and the number of sensors—specifically two in the case of all-wheel-drive vehicles. The regulation mechanism functions on the same principle, regardless of whether DCC is present or not. The basic setting (calibration) for DCC is distinct from that of the headlights. The vehicle should be positioned normally on a level surface and left unloaded before performing the basic setting.
First Screen With positiv pwm = Seat
2nd Screen with negativ pwm = SKODA
Sorry, it seems that this isn’t a sensor that I can read with carscanner.
Hi Guys, Cairus
Edited by AroCz
English?
Source: OBDeleven screen recording dated 17 November 2026 (75.67 s). The parameters visible on screen have been transcribed in the order in which they appear. Where a field is marked “[truncated]”, the app displays only the beginning of a multi-part value. Missing portions have not been reconstructed.
Header and long coding
• Saved backup name: “All control units” (original: “Wszystkie jednostki sterujące”)
• Backup date: 2026-11-17, 11:18
• Odometer reading: 199735 km
• Module: Multifunction Module
• Long coding (60 HEX characters): 000000020100066A00003F00000000000000000000000000000000000000
Adaptation – 16 channels
|Channel|HEX value |
|2306 |62090200 |
|11543 |622D1700 |
|11561 |622D2900 |
|11542 |622D1601 |
|11558 |622D2601 |
|11583 |622D3F64 |
|11584 |622D4000 |
|11617 |622D61000000000000 |
|11618 |622D62000000000000 |
|1278 |6204FE000000 |
|1276 |6204FC000000 |
|1296 |62051000 |
|2778 |620ADA1E1E1E32323232324B4B5050|
|1297 |62051100 |
|1298 |62051200 |
|1187 |6204A303 |
Live parameters / measured values
|No.|Parameter |Reading |
|1 |Output test status |Inactive |
|2 |Basic settings status |Inactive |
|3 |Security Access: number of invalid keys |0 |
|4 |Terminal 30 voltage |12.1 V |
|5 |Engine stopped by start-stop function |OFF |
|6 |Engine started by start-stop function |OFF |
|7 |Terminal 15 status via CAN bus |ON |
|8 |Engine status |OFF |
|9 |Number of unplanned control-module resets |Watchdog Reset: 0 |
|10 |Multifunction Module Application Software Version |Version Routing FCM: 7160; Software Version AFS/MXB: 0065 |
|11 |Processor utilization |Total system FCM: 24%; Software component AFS MXB: 13% |
|12 |Predictive Route Data Street Class |Not available |
|13 |Predictive Route Data Number Of Lanes |Not available |
|14 |Predictive Route Data Speed Limit |Not available |
|15 |Predictive Route Data Placename Sign |Not available |
|16 |Predictive Route Data Intown Flag |Not available |
|17 |Headlight levelling control state |Static |
|18 |Left dynamic cornering light value |Fault |
|19 |Right dynamic cornering light value |Fault |
|20 |Front left suspension height sensor, learned value (zero position)|-0.01 % |
|21 |Rear left suspension height sensor, learned value (zero position) |46.00 % |
|22 |Driving profile selection |Specified value: 0; Actual value: 0; System status: Not available; Compatibility: Yes; Switching p… [truncated] |
|23 |High beam |OFF |
|24 |Reverse gear status |OFF |
|25 |Turn signals |Not activated |
|26 |ESP intervention |Inactive |
|27 |Ambient brightness |1890 lx |
|28 |Low beam |OFF |
|29 |Vehicle speed |0.0 km/h |
|30 |Steering angle |1.20 ° |
|31 |Front body deflection |0.0 mm |
|32 |Rear body deflection |-17.2 mm |
|33 |Left headlight range control adjustment motor, status |No fault |
|34 |Right headlight range control adjustment motor, status |No fault |
|35 |Left dynamic cornering light adjustment motor, specified value |32.000000 ° |
|36 |Right dynamic cornering light adjustment motor, specified value |32.000000 ° |
|37 |Left dynamic cornering light adjustment motor, status |No fault |
|38 |Right dynamic cornering light adjustment motor, status |No fault |
|39 |Variable lighting adjustment motor, front left, status |No fault |
|40 |Variable lighting adjustment motor, front right, status |No fault |
|41 |Left headlight range control adjustment motor, specified value |1024.0 mm |
|42 |Right headlight range control adjustment motor, specified value |1024.0 mm |
|43 |Switching from left-hand to right-hand traffic |OFF |
|44 |Dynamic cornering lights |OFF |
|45 |Front left suspension height sensor |-0.01 % |
|46 |Rear left suspension height sensor |42.40 % |
|47 |Light distribution status |Not activated |
|48 |Front left variable lighting, specified position |204.70 % |
|49 |Front right variable lighting, specified position |204.70 % |
|50 |Headlight basic settings status |No command |
|51 |Static cornering lights |Left static cornering light, dimming: 0.0 %; Right static cornering light, dimming: 0.0 % |
|52 |LED headlight, light distribution commands |Low beam: No command issued; High beam: No command issued; All-weather lights: … [truncated] |
|53 |Actual reference segment angle |Horizontal reference segment angle, left side: -500.0 ′; Horizontal reference segment angle, right side: … [truncated] |
|54 |Matrix headlight, calculated offset values |Left headlight horizontal offset: -300.0 ′; Right headlight horizontal offset: -300.0 ′; Vertical offset l… [truncated]|
|55 |Drift angle |-120.0 ′ |
|56 |Axle offsets |Rear axle offset: -400.0 mm; Front axle offset: -400.0 mm |
|57 |Matrix high-beam function status |Inactive |
Advanced identification
|1 |Number of programming attempts |Application: 0; Bootloader: 0 |
|2 |Number of parameterization attempts |Dataset: 1 |
|3 |Number of successful parameterization attempts |Dataset: 1 |
|4 |Maximum number of possible software updates |Application: 65535; Bootloader: 65535 |
|5 |Detected subsystems |Subsystem designation: Reserved; segment number: 4; subsystem present: Yes; subsystem … [truncated] |
|6 |Busmaster / Subbusmaster identification |ECU ID: 4B; ECU Name: Multifunction Module; LOGICAL-LINK SHORT-NAME: Multifunction Module |
|7 |Connected component identification |Identification number: 4B; subsystem name: Multifunction Module; Bus information / node address: A9 |
|8 |Subsystem diagnostic classes |Systems, diagnostic class 3: Yes; Systems, diagnostic class 2/2F: Yes; Systems, diagnostic class 1: Yes; Syst… [truncated]|
|9 |Service code and date of last software module update|Year: 0; Month: 1; Day: 1; Equipment number: 0; Importer number: 0; Partner number: 0; Programming status… [truncated] |
|10 |Date of last coding |Year: 22; Month: 18; Day: 5 |
|11 |FAZIT identification |Manufacturer plant code: SJ8-FST; Production date: 29.11.16; Manufacturer test station number: … [truncated] |
|12 |Parameterization identification |Number of datasets: 16; AFS dataset: 04; MXB dataset: – |
|13 |Diagnostic mode |VW diagnostic mode |
|14 |VW / Audi part number |3Q0907338 |
|15 |Software version |0285 |
|16 |Serial number |29111610520147 |
|17 |Hardware part number |3Q0907338 |
|18 |Supplier software version |FFFF2706201612111700000000000000 |
|19 |System designation |FCM MQB Low |
|20 |Adaptation service code |Equipment number: 60933; Importer number: 3; Partner number: 12289 |
|21 |Date of last adaptation |Year: 38; Month: 17; Day: 19 |
|22 |ASAM / ODX file designation |EV_MultiModulContiVW48X |
|23 |Parameter dataset part number |V03935248XG |
|24 |Parameter dataset version |0001 |
|25 |ASAM / ODX file version |001010 |
|26 |Hardware version |001 |
|27 |Vehicle equipment code |000000000000000000000058 |
|28 |Coding service code |Equipment number: 31; Importer number: 770; Partner number: 73216 |
|29 |Parameterization service code |Equipment number: 31; Importer number: 770; Partner number: 73216 |
|30 |Parameterization date |Year: 22; Month: 18; Day: 5 |
|31 |Short system designation |J745 |
|32 |Software module versions |Application: 0285; Bootloader: 0106 |
|33 |AUTOSAR Standard Applikationssoftwareidentification |Unknown; Software manufacturer ID: IAV GmbH; Major version number: 2; Minor version num… [truncated] |
|34 |Flash update data security |Hash value: Not available; Key unlocking mechanism: Not available; Key: No; Key typ… [truncated] |
|35 |Programming status |Programmable: Programmable; Program structure: Program available |
|36 |EEPROM data consistency |Fault during last dataset download: No fault; Data consistency: Valid EEPR… [truncated] |
Notes
• “Static” is the control module’s reported status at the time of the recording, not a confirmed adaptation or coding value. In the recording, both engine status and low-beam status are OFF.
• The difference between the rear sensor’s learned zero-position value (46.00%) and its current reading (42.40%) reflects two separate values shown in the recording.
• The “Fault” indications for the two dynamic cornering light values should be checked against DTCs; the other adjustment motor status readings indicate “No fault”.
• Date fields are reproduced exactly as raw values displayed by the application, even when they do not form a valid calendar date.
Create a backup of the headlight range control adaptation in control unit 09.
I’ll come back to this topic in the next week, after i will bring my OBDeleven from Poland....
