Whoosh noise from Dump valve
I'd spend the money on a downpipe though.
  • Replies 122
  • Views 9.3k
lol, ive had an idea, im off to get some gaffer tape, toilet paper and chicken wire.
Seriously - get a downpipe!
lol, cheers man, ill decide when i pop over to awesome on sat what i do, see your from round me. love to get a gander under the bonnet(wont touch or take owt promise) of ya car if your off to any meet soon?
No worries, more info on my car here: http://www.briskoda.net/forums/octavia/big-turbo-setup-my-4x4/53552/ and here: http://www.briskoda.net/forums/octavia/first-rr-run-my-big-turbo-4x4/64180/
Eddy h does the trumpet bit come out at all as it's a bit tight behind there to get the spine's out
It just unclips.
so.... CAI IS the best way for out and out peak power gains, forget noise and torque.
simple yes or no will do as my calculator is on the blink.:D
No.
cheers eddy your a legend. all i was after was a catagorical yes or no.
Of course that's only in my opinion but is based on experience.
well ill take your opinion into account when im stood in the shop. cheers.
eddy can you p.m. me regarding payment details on maf housing de screened
I've just been on the blower to JBS, and they can get me the panel filter and Green tubing.
Before I ordered, I took a look under that big flap on the front of the car that hides all the dirty bits, and found that mine (with a standard airbox) is missing the connector that links the airbox to the inner wing, so it's sucking in hot engine bay air at the moment :(
Also, the sounder for the alarm is stuck right in front of/across the inlet into the airbox. And i mean "stuck". It's taped to the inner wing! That's a quality installation then ... :P
My question is this. If I fit the green ducting to the existing airbox (which I intend to smooth as best I can), will it be OK to just 'dangle' it down between the headlight and battery box, rather than connecting it to the lower grille? I live out in the sticks, and there's too great a risk of deep water to mount it too low. I assume I'll still get cooler air from behind the bumper than from within the engine bay?
If I do this early next week, I'll post pics of the inside of the airbox etc for others to see what needs to be done. :)
there's someone selling a filter and cleaning kit here http://www.briskoda.net/forums/items-sale/octy-bits-sale/63451/
just looked again may be gone
i used a pair of plumbers pliers to snap off the ridges then sand paper and a dremmel to smooth it off looks a bit rough but just been informed thats ok
did you take any pics at all? :P
Thats the bits ordered ... roll on next week :D £74 + delivery.
I spoke to a very helpful chap called Mike. Good service so far.
i did'nt but i should have it back off tonight i'll take some then
You won't get the full potential but it will be better than it was and work fine.
Sounds good to me.
Glad I didn't cough
Sorry if im being thick but i got lost aaaages ago....
My dilema is my cars totally stock with a dealer 12 month warrenty (which probably isnt worth the paper its written on...) which if possible, I dont wanna invalidate.
From what i've gathered, I should steer clear of ANY type of aftermarket dump valve and simply modify my standard airbox internals (with aftermarket panel filter??) and fit a cold air feed....thus resulting in a slightly louder noise and better response etc.
Impossible performance sell a cone air filter kit for around £150ish with a pipe that allows it to be mounted at the front, which sounds good too.
Im stuck with too many bleeding options!!
I've had my vrs for 6 months - seems standard but I am definitely getting the dump valve "whoosh" when chanding - any idea why?
Are you sure it's a woosh and not a flutter? If it's a flutter your DV is almost certainly knackered and you need a new one.
cos u got a d.v. but it s a recirc one so its quiet
eddy did you get my last p.m.
I get a very slight "whoosh" when the cars warming up changing at about 3500rpm but when it gets hot it pretty much dissapears
you can only really hear it in the car and it only when going slow the engine noise is to loud otherwise it's more of a tttsshh sound if i had describe it
yes, thanks. :)
i'll post it in the morning too busy in work today to get out
