Best product to clean vRS exhaust?
Hi,
I was just after some advice on the best product to clean up the exhaust on the Fabia vRS? obviously over time they start to look a little black, I want to get it all nice and new looking if possible.
Rik
I use Meguiers metal polish and it brings it up a treat. :)
Barry Scott recommends Cillit-Bang! Bang, and the dirt is gone :thumbup:
Chris
Mr Jeeves miracle polish works for me:thumbup:
It also cleans your bumpers, windows, paintwork etc.
And it's cheap as chips.
( God knows what's in it though:confused: )
It might sound daft, but it is really really good, and very easy to use.
I use Solvol metal polish for most of the exhasust. For the bottom bit where the gunge accumulates, I use a special eraser which is designed for cleaning printed circuit boards (it contains metal particles. HX04E from Maplin). This cleans the metalwork without damaging it.
Autosol, and when/if it corrodes, a Dremel :)
I use oven cleaner.
Spray on, leave for 15 mins and then hose off.
Sparkling!
Just make sure you rinse well!
once clean, i little spray with wd40 and a wipe is all it needs once a week.
I use the same stuff that I clean my wheels with. Muck Off, its ment for bikes but I heard its not far off oven cleaner.
I also just use turtle wax wheel clean... Works fine, and shifts all marks with ease...:thumbup:
i use megiuars wheel cleaner.
I leave mine black and sooty like any self-respecting diesel exhaust should be.
people clean their exhaust :rofl:
I thought they came black from the factory.:rolleyes:
I use Duraglit Brass cleaner for the inner part and S Steel cleaner for the outer
You clean the INSIDE of the exhaust? :shocked: :rofl:
With his tongue:rofl:
you can't beat a bit of brasso
With all this cleaning, do any of you have time to drive your cars?!?! :rofl:
Chris
i once stupidly pressure washed the exhaust causing it to fill slightly with water :rolleyes:
then made the mistake of starting it up in front on the house..
the result....... black cruddy water all over the brickwork. :rofl:
I use oven cleaner.
Sparkling!
snap(ish)! mine gets done with Hob Brite - shines it up a treat :D
By inside I mean the flat oval S Steel plate where the twin exhausts exit NOT right inside the pipes :orb_lol:
Fibber:D
I must admit that your car is a credit to your anally retentive passion for not talking to your wife:rofl:
With all this passion (which I totally support! :D ) regarding the cleanliness of the 'shiney rear orifice', I was also wondering how easy it is to remove come the inevitable time for exhaust renewal? Had a 'finisher' on my last car but that just corroded on and couldn't be salvaged when that section was changed. How does the vRS fare? I can't see a securing screw or nut anywhere - just seems to be all flush. How is it actually secured?
Fibber:D
Watch it. The truth is out there;)
I used Autosol in the days of my beloved Octy vRS
