Miniature Skodas and stuff
theres a tutorial, dave has the link saved, but basically get our photo, press Q, click the gradient button, think it needs to be going white to black.... press D to make it default. select the type of gradient thing you want, cant really explain on here which one it it, its like a band across the middle, thinks its the 2nd from last one.....
pick your focal point (the bit u want to make look mini) click there and drag the line up to the top of the page. It should turn red. Press Q again and you will see your focal point highlighted. click 'inverse' which if I remember correctly is under 'select'. Then go filter - blur - lens blur. radius alters the amount of blur. click ok and it will apply the filter. You have to alter the curves then - pull the line upwards from the middle, should make the edges lighter. click ok et voilla :thumbup:
  • Replies 68
  • Views 5.4k
yeeeaaahhhhh like that!!! :D
The lil pug is ace :thumbup:
Airport rather good too.
I've had a shot at this:
^^^^ That looks spot on !!!
I'm not completely happy with it.
When you see it bigger, there's a definite in/out of focus straight line across the top, which fuzzes parts that are "Higher up" from other focused sections, as opposed to "further away" - I need to play around with the masks and how quickly the focus changes
tis fun to do. Did this one a while ago which is quite cute
That is excellent, looks like a Scalectric track:thumbup:
Ideally, you want to be looking down on the subject. That way it looks more convincing -- as such, butr i do like the one you have done :):)
here's another few
  • 4 weeks later...
and some more:
That is fantastic stuff. its amazing how the eye can be fooled so easily. I'm definatly going to have to try this out.
and some more:
Where are they taken?
this affect is called tilt & shift.makes any picture look like toys.in photoshop.
get some great effects with it
Ok...bad first attempts.
To be honest they're not the best photos to start with, but i'll keep trying. :)
They're really good, Johnny
my harbour ones were taken in Mevagissey in Cornwall - we were there on holiday this "summer"
Brilliant johnny ! :)
Cheers lads.
You know i'll be flicking through all my pics to find more suitable candidates now ! :D
How can you increase the size of the centre, so that it's not blurred ? (if that makes sense)
I'm getting too much blur at the top and bottom and cant get it right.
Think this one works fairly well due to the colours of the building.
Thought I recognised the place. I was there around 20th July. :thumbup:
the gradient lets you choose what's in focus, and how quickly it blurs.
red is in focus.
when you click and drag the guideline to show the gradient area, start at the middle of the area you want to be in focus. for a bigger focussed area, just make that line longer. Don't forget it will be top and bottom symmetrical
to change how quickly or slowly the blur comes in, double click on the grey gradient icon, and you should be able to grab and move the grey midpoint, so that the change over can be more abrupt to one side or the other.
just do lots of experiments - your focussed section doesn't need to be horizontal, depending on what angle you draw the gradient guideline at.
then we missed each other by a few days, we were there from the 15th to the 18th
I've just had a pop at this. it's harder than it seems like.
