Carista OBD2 - A cheaper alternative to (some of) VCDS
Recommended Posts
Ah right. Yes, I think so. Below is a dump of the info it pulled off about my car.
I just bought a cheap one off ebay. Can probably dig out the details if interested...
Engine
Part #: 03L906022QJ
Component: R4 2,0L EDC G000
Coding: 1078 (decimal)
[No fault codes]
Transmission
Part #: 02E300052S
Component: GSG DSG AG6
Coding: 20 (decimal)
[No fault codes]
ABS
Part #: 1K0907379AH
Component: ESP MK60EC1
Coding: 863D601609240003610B06EB90210082340000 (hex)
[No fault codes]
Steering angle
[failed to connect]
Power steering
Part #: 1K0909144J
Component: EPS_ZFLS Kl. 196
Coding: [none]
[No fault codes]
Airbags
Part #: 3T0959655A
Component: J234__LC0 VW10 H
Coding: 17200 (decimal)
[No fault codes]
Headlight aiming
Part #: 5M0907357C
Component: AFS-Steuergeraet
Coding: 1377095 (decimal)
[No fault codes]
Parking/steering assist
Part #: 1Z0919475B
Component: PARKHILFE 4K
Coding: 100108 (hex)
[No fault codes]
Instrument cluster
Part #: 3T2920941E
Component: KOMBI
Coding: 411F00 (hex)
[No fault codes]
Immobilizer
Part #: 5K0953234
Component: IMMO
Coding: 000000 (hex)
[No fault codes]
Central electronics
Part #: 1K0937087H
Component: BCM PQ35 H+
Coding: 48190AB8F853F1C040080080110089E4417100AE736D85605C0140000000 (hex)
[No fault codes]
Body/convenience system
[failed to connect]
Driver's door
Part #: 7N0959793A
Component: TSG FA
Coding: 011D0220DE01121002 (hex)
[No fault codes]
Front passenger's door
Part #: 7N0959792A
Component: TSG BF
[No fault codes]
Rear left door
Part #: 7N0959795
Component: TSG HL
Coding: 010C00200001221002 (hex)
[No fault codes]
Rear right door
Part #: 7N0959794
Component: TSG HR
[No fault codes]
Driver's seat
Part #: 3C8959760
Component: J810
Coding: 3 (decimal)
[No fault codes]
Steering wheel
Part #: 1K0953549CD
Component: J0527
Coding: 1732 (decimal)
[No fault codes]
Heater & air conditioning
Part #: 3T0907044AS
Component: Climatronic
Coding: 0000000002 (hex)
[No fault codes]
Trunk
Part #: 7N0959107
Component: HDSG-Modul
Coding: 082301C002 (hex)
[No fault codes]
Part #: 3T0035680B
Component: RNS-MID
Coding: 04000402000400810000 (hex)
[Purchase Pro Package to see fault codes]
Radio
Part #: 3T0035680B
Component: RNS-MID
Telephone
Part #: 5K0035730D
Component: TELEFON
Coding: 0200000000010110 (hex)
CAN network gateway
Part #: 1K0907530AD
Component: J533 Gateway
Coding: EDA1FF06420602009303 (hex)
[No fault codes]
Obtained with Carista 2.2 for Android.
Download app: https://play.google.com/store/apps/details?id=com.prizmos.carista
Facebook: https://www.facebook.com/caristaapp
Link to comment
Share on other sites
Silver1011 - I can't find the exact one in my ebay history - I bought it too long ago, but it was one like this http://www.ebay.co.uk/itm/TORQUE-ANDROID-Super-Mini-ELM327-V2-1-OBD2-OBDII-Bluetooth-Adapter-Auto-Scanner-/321119635389?pt=LH_DefaultDomain_3&hash=item4ac438c7bd
Any one will do- I'd go for on that says it's v2.1 and that says it supports CAN BUS, like this one. You can get wifi ones as well, but I've only ever used bluetooth.
J306TD - For faults I have the engine running. It also does some kind of rudimentary emissions test- I've never used it, but I think the engine has to have been running for a bit for it to work.
For customisation the app says within it that the ignition should be on, but the engine should not be running, so that's what I did.
One thing I should mention. I noticed that when I reset the country to Australia I lost some of the other settings on the Maxidot got reset to default (nothing major- clock, language etc were fine. Needed to set units back to miles from km). I just set them again in the Maxidot.
To get the big mph display, there is a setting in the top level menu of the Maxidot that says something like "alternative unit display" uncheck this option, then the big speed display option appears with all the other possibilities that you can select in the MFD.
Hope that helps...
Link to comment
The Apple (iOS) version is 1.0 which was updated on 20 Mar 2015. I don't know how that compares with version 2.0 for Android.
Carista warn that most ELM- compatible devices that claim to be v2.1 are fake and do not work. v1.4 or newer is required for customisations or advanced diagnostics.
Link to comment
I'd still rather have the security of the long coding feature of VCDS, even if it is dearer
Me too, Bryan, and with VCDS changes can always be reversed successfully if a scan is done first - except for the well-known hidden Byte. But this device intrigues me and has me thinking about other software which can be used with a wifi dongle.
  • Like 1
Link to comment
Gave it a go here's mine
ECU info obtained with Carista 2.2.1 for Android:
Engine
Part #: 1Z0907115D
Component: 2.0l R4/4V TFSI
Coding: 0203000318070160 (hex)
ABS
Part #: 1K0907379AC
Component: ESP FRON
Coding: 4738 (decimal)
[No fault codes]
Steering angle
[failed to connect]
Power steering
Part #: 1K2909144M
Component: EPS_ZFLS Kl.074
Coding: [none]
[No fault codes]
Airbags
Part #: 1K0909605T
Component: Q4 AIRBAG VW8
Coding: 20788 (decimal)
[No fault codes]
Headlight aiming
Part #: 1T0907357
Component: Dynamische LWR
Coding: 7 (decimal)
[No fault codes]
Instrument cluster
Part #: 1Z0920942C
Component: KOMBIINSTRUMENT
Coding: 7401 (decimal)
[No fault codes]
Immobilizer
Part #: 1Z0920942C
Component: IMMO
Coding: [none]
[No fault codes]
Central electronics
Part #: 3C0937049AJ
Component: Bordnetz-SG
Coding: E18E8F130004140000110D000000000000087F065C000000000000000000 (hex)
[No fault codes]
Part #: 1K0959433BT
Component: KSG PQ35 G2
Coding: 81801A085283007F3F02050FC0085F96907C00 (hex)
Driver's door
Part #: 1T0959701D
Component: Tuer-SG
Coding: 756 (decimal)
[No fault codes]
Part #: 1T0959702D
Component: Tuer-SG
[No fault codes]
Rear left door
Part #: 1K0959703J
Component: Tuer-SG
Coding: 144 (decimal)
[No fault codes]
Rear right door
Part #: 1K0959704J
Component: Tuer-SG
[No fault codes]
Steering wheel
Part #: 1K0953549BN
Component: J0527
Coding: 42 (decimal)
Part #: 1Z0907044AC
Component: ClimatronicPQ35
Coding: [none]
[No fault codes]
Parking sensors
Part #: 1Z0919283B
Component: Parkhilfe 4-Kan
Coding: 1 (decimal)
[No fault codes]
Part #: 3T0035680B
Component: RNS-MID
Coding: 0E000400000100030000 (hex)
[No fault codes]
Radio
Part #: 3T0035680B
Component: RNS-MID
[No fault codes]
Telephone
Part #: 3C8035730
Component: Telefon
Coding: 20121 (decimal)
CAN network gateway
Part #: 1K0907530P
Component: J533__Gateway
Coding: E9817F0E4006021303 (hex)
[No fault codes]
Obtained with Carista 2.2.1 for Android.
Sent from my Galaxy S5
Link to comment
I have just downloaded this to see how I get on with my mk2 Octavia.
I've got several fault codes that show up using vcds, but torque pro shows nothing. Will be interesting to see what this shows
Link to comment
I scanned with Torque Pro and nothing showed up. :confused:
Link to comment
I've taken a punt with a £5 dongle + Carista + OBD Car Doctor Pro + Torque Pro.  Total cost = about a tenner; not much to lose if falls over.
Actually, what I MOST want VCDS for is to adjust my headlight level/range.  I know this package won't allow me to do that, but I still might get some cheap amusement out of it...
Link to comment
What are the other bits for?
Carista is the downloaded App?
I'm guessing the 'OBD Car Doctor Pro' is the plug-in adaptor that plugs into the cars diagnostic port? This relays the data to the App on the phone via Bluetooth.
So what are the other bits for?
Link to comment
Car Doctor and Torque are just other Android apps which seem to come well recommended; they do real-time data analysis, but I don't know how useful they'll be...
  • Like 1
Link to comment
Was just about to buy this...
http://www.ebay.co.uk/itm/NEW-OBD2-ELM327-V1-5-Bluetooth-Car-Scanner-Android-Torque-Auto-Scan-Tool-OBD-II-/111088326026?pt=LH_DefaultDomain_3&hash=item19dd61558a
...and then noticed that in the listing it says that it won't work with diesel engine cars!?
Link to comment
Well it showed up that fault codes are under the same parts as vcds shows.
Without paying for the pro version I can't say whether it shows the same, but looks good so far.
So basically Torque Pro is a waste of money as it doesn't show fault codes that are there?
Link to comment
Correct, torque can only access generic obd codes.
This can read all of them by the looks of it
Thanks. Have you tried the pro version?
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
