Everything posted by gumdrop
Preserving the coiled rubber outer cable on my Nikon SC-29 ttl unit
As it stands the flash is still usable and I would prefer to seal the damaged areas. To this end I have looked at rubber repair paste and silicone repair tape (self amalgamating) Unfortunately the rubber outer sheath would need to be treated to make the rubber soft and pliable again. I considered liquid silicone but this may only be delaying the inevitable, you suggestion of a replacement cable means taking a working item apart before I can even count the cores it is a bit catch 22. I will wait and see if any other suggestions are forthcoming. Thanks again for your time.
The outer rubber insulation on my Nikon SC-29 ttl unit is cracking up. A new unit is around £100, If I could get one, what can I use to make the rubber outer case more supple again? By the By, Nikon seems to be dumping Amateur cameras and equipment, I contacted Nikon Spares and they referred me to another company (Fixon?), who referred me to WEX
Nephew broke light switch - based on a ticktock
I remember one going "click" and dropping onto the car mats glowing yellow red and the car swerving as driver and passenger both reached down to try and pick it up without getting burnt! I gained several grey hairs during that incident.
Yeti Diesel Power
I think my 110ps Yeti Elegance Outdoor 2wd diesel performed very well, solo it was very quick and it pulled my Bailey Orion really well.
Towbar fitting question
It is not economic to fit a 7 pin electrics, fit 13 pin, better resale possibility and can be dumbed down to 7 with an adapter The car electrics will recognise 13 pin as it is todays standard.
Foot rest
My Kamiq Monte carlo has a foot rest, for precisely that reason.
Custom button for Sport mode
To select sports mode is a gentle tap rearward, no pulling or tugging.
KESS model, Superb, how to effectivelly prevent keys being scanned?
My son uses a business card case, similar to a small cigarette case.
Wouldn't a tobacco tin work just as well? A hinged tin is around £4 from e-bay and others.
Ignition key stuck in barrel- DSG
Foot on the Brake select Park, handbrake on engine off remove key (front wheels straight ahead)
Estate rear end just slid out a little easily?
I think it is a slightly longer wheelbase, certainly the body work is longer but with correct tyre pressures and proper reading of the road conditions, even with my heavy right foot I had never provoked more than a twitch.
Premium Petrol for a Fabia 1.2tsi (2016)
My milage is quite modest nowadays so I use e5 but on a run I do get an extra few miles ( 3-5) per gallon. My Fabia estate (Kombi Monte Carlo) loved the higher octane rate and we travelled loaded to the gunnals with camping equipment. The Times disagrees on the extra milage. https://www.thetimes.co.uk/money-mentor/answer/is-e5-petrol-more-economical-than-e10/
Badger came off worse
I hit one once and killed it, I had to move it and it (a male) must have weighed about 15-20kg. all muscle. Company 4x4 Ute luckily, Took out the wing and bull bar.
Torn between skoda kamiq monte carlo and sel executive
My Monte is an automatic, the first I have owned, and now I wish they had all been automatics.
I saw my Monte Carlo in the local showroom, it was love at first sight, the seats are really comfortable and it accelerates in a most pleasing manner. Sold.! Oh! bye the bye it has everything the SEL has and the passenger seats are good as well, a few months after buying it I noticed it has a glass roof .....
"Cubby-Hole" Right side of the boot space
I think the space is for a warning triangle. It needs to be measured as most 3rd party triangles are too big. Regarding the bags mine went "floppy" and stuff started to spill out. I started reinforcing with hardboard strips but gave up and ditched them eventually. I aquired some Skoda nets and these are in use at the moment.
Android Auto Video
https://www.youtube.com/watch?v=BRBGt7u0GLA
Red oil light intermittingly flashing
These engines are designed to run on the oils as laid out in the instruction manuals for your region, with the car as flat and level as possible check the oil level, cold as per the manual. The really clever folk can now diagnose knowing the basics are satisfied. Good Luck.
Fitting underbody skid trays to improve aerodynamics?
Going to work one morning early, in heavy rain, i took a corner at 25-30mph and hit a tempory lake! In many years of driving this road it was normally dry what ever the weather, so the car surfed across the deepest part until the wheels found traction at the crown of the road. without the engine compartment pan I could have ended up very wet. Yes they are of some use.
Water drip from RHS of Front Reg plate - Long time after rain shower - Scala normal oddity?!
I had a betsy when I notced a leak, then I remembered I had the aircon on to clear the windscreen, there was my "leak" off the aircon radiator.
Kamiq -SE - No Sat Nav! Dog friendly?!
Link your phone in and use WAZE, my wife navigates using this program.
Is there a button to accept Downloads? and How do I get rid of phones on my system.
It has just the flat screen, thank you for your continued help. Car is 2021 Kamiq Mote carlo 1.5 petrol. I am busy crippling myself stripping out and rebuildiig a short rill that is pump fed to a pond. I never realised how unfit I had become, either that or the big stones I built in have grown
- Is there a button to accept Downloads? and How do I get rid of phones on my system.
