mydieselclaim.com
A mouseover says that's a page on ar$ebook . Wouldn't a real firm of lawyers have their own named website even if they were named say "Fleecem and Scarper"?
My 2019 Sportline plus modifications thread
Quite the reverse; WrecksIt has increased delivery times, when the UK supplier will still sell to the EU or an overseas supplier will still sell to the UK. What was that lie about "easiest deal ever" again Bozo?
Track rod end issue.
They're advisories; ignore them until they become failures. One one occasion I had "advisory; only 7mm tread remaining on front tyres". I'd had new fronts fitted 1_500 miles before the MoT,
coolant loss.
You sure? Not even a rising oil level or white vapour coming out the exhaust (both signs of HGF (qv)).
Intermittent power steering - help with diagnosis please
/\ Those, or a fault with the steering angle sensor, most likely with the narrative "Steering angle sensor - implausible value".
Well, IMO quad pipes are chavvy on anything but a V12.
British Built New Cars in Australia
and 53.5% to the EU. I was right that she's lying by omission.
Rear Bumper Moulding - Sorted
@J.R. Are you sure you don't mean Plasticote then?
Key word in OP "Plastidipped". No idea if that service is a thing in France or not.
Octavia 4x4 1,8t (2003) problems with fuelpump
On the grounds of being cheap, I'd start with the alternator control wires. When you switch on, does the battery light illuminate? If not, good odds on (90%+) there's an issue with the alternator control wires. You may well need to recharge the battery afterwards, but there's no point in doing that first because you'll only have the charge in the battery, since the alternator won't be charging.
More for the Australian members than anyone else. Which car manufacturers (if any) routinely send numbers of new build (unregistered) cars from the UK to Australia. I think the UK Trade and Industry Secretary may be lying (if by omission) or incompetent.
Felicia crank position sensor and aftermarket ignition
@Papez @Trabbi - A crankshaft sensor (include flywheel sensors here) natively generates 1 ping per engine revolution. A camshaft sensor generates 1 ping every other engine revolution if it generates a ping every time the camshaft rotates. I think (but can't guarantee) that a Megajolt, Emerald or similar EMS can accommodate this in software.
- How to make Skoda Superb MK3 more cofortable
Anyone know how to decode this 'QR-like' code?
That's arguable, but isn't knowing "localhost" geekier than confusing it with "home" which is user configurable and need not reference a specific IP address on every system.
Felicia 1.6 MPI Thermostat replacement
KenONeill replied to KamikazeCam's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanOdds on the thermostat element is cracked, dead or even removed by an ill-informed previous owner. In any event, when removing the housing to replace the element, look carefully for plastic in the outlet.
Briefly losing power
Yeah yeah but how many miles has the car done since new, and how regularly did previous keepers service it?
@MikeTheThinker - Could you do one that reads "There's no place like localhost"? For the ultimate Unix geek joke.
Engine warning light and occasional judder even after changing a coil?
Or the fuel feed, one or more injectors, traction control if applicable, drive by wire throttle if applicable...
Well maybe. Is the issue there when you're turning on steady throttle, or more when you do brake, turn in and then try to pick the throttle up again? I had the second one, and it was due to wear in the throttle pedal potentiometer.
Road noise / droning sound / wheelbearing / ABS failure
Not being funny but have you tried an olde-fashioned "rock test" for wheel bearing wear? Based on discussion so far, starting with the OSF.
how to remove this?
Stop following blue Fords. That gives you some idea how noticeable the mark isn't at first glance.
Forge adjustable Quick Shift, worth fitting?
ISTR if only shortens the throw in the fore and aft plane. I also have no idea what you change gears like.
Lower fuel economy/power 5w40 Quantum Vs 5w30
Why would it? the 5W is what cold protection comes from, and even if 40 centistokes at 100C equated to 10bar in the bearings and tappets, that would be like 1010bar rather than 1_000bar from the 30cs with thin film effects.
My fabia 1.9SDI needs new engine, is the same of the Octavia?
@Kharl - What sepulchrave said!! (irrespective of which of the 4 states of TDi tune "the guy" has; they're all different from the SDi).
