Lane assist is dangerous
@gumdrop What @olderman1 just said, with the additional note that you don't always have to depart from a marked lane (deliberately or otherwise) for Lane Enforce to decide that it knows better than you do where your car should be positioned, even though you can see stuff it can't.
Now, I'm not sure it's meant to do that...
I'd suspect a lichen, unless it's maybe 1cm deep which will be a moss.
Which reminds me; try changing the pollen filter (but not until the weather is warmer).
The future of cars in the media (TV, Print and Forums)
I was contemplating a Superb V10...
You could try explicitly switching the heater/AC off before switching the engine off.
My felly is DONE FOR
Similar thoughts about HGF (or if you're very lucky you just need a new pressure cap).
Spare wheel stuck & sticky drum brakes
@spectrumz80 - I think I agree about the drum locking on. On most cars I've worked on the spare wheel hold has been offset, bolting through one of the wheel bolt holes rather than though the centre spindle. Ref tests, I don't know your NCT, but a UK MoT does not test the spare tyre (not that it would matter since it's not compulsory to have one (source MoT testers)).
Buying back a total loss
That's most unlikely to be an economic prospect unless you had a set of Unobtainium Ultra-lite rims or similar. In any event, AIUI they only have to offer you the chance to retain a vehicle that's classified as an economic write-off or is on agreed value.
Engine swap RH mount query 1.3 replaced by 1.6
KenONeill replied to ChestnutJim's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanBig hint - The 1.6 engine is different to the 1.3, and has different mounts.
Adapting EU spec Octavia to UK
That depends on your headlights. Some models can be adapted from wrong hand to left hand dipping but others need replacing. UK law demands that your speedo displays in mph. I'm not sure that you can do the adaption with a sticker. You will, at minimum, have to have the car UK MoT tested, so why not talk to an MoT centre that suits you about the requirements?
Mk1 Octavia 4x4 1.8t - What drivetrain?
Well, it was a V@*xh@11 Coarser.
Drum/Cylinder replacement
I'm thinking ~£20 per cylinder, and maybe £50 if you need new shoes. So £90 for parts and 1 hour for labour tops.
Car in garage tomorrow (Nav, SOS and now collision light) - thoughts.........
You already know it; you've just posted in it.
Yes; the computers in the Octy 4 have never been right. There's a whole forum on this site about them.
Can anyone think why the fuel pipe clip here would have been removed?
Will removing it give better access for the gear oil change (good call outsourcing that BTW; used gear oil stinks to high heaven)? If so, then push and hope or that way oversize tie-wrap were easier than trying to fit a right size clip on the pipe.
CitiGo bulbs H4 or H7?
Osram Nightbreakers every time, all night long. As for fitting,it may be that the one car has H4, and the other H7. The only way to know for sure is to take a bulb out and look.
Exactly my point; "Factor is closed" is not a valid excuse for being unable to cost parts for $job.
Skoda Fabia 1.2 2009 power steering stiff
That's possible; advice about checking hydraulic fluid, and indeed electrical connectors to PAS motor is because those are way cheaper than a new motor. Prices vary but a new genuine motor on E-bay is at least £265 for the part.
Chrome decorations - Front and rear bumper
Also @JFJ Based on @akshayb photographs, those trims are alluminised plastic, not chrome. Just warning that if you really want chrome, that is not it.
Reversing & Rear Fog Lights
There are now 3 replies to your post, all citing different models and saying "you're wrong".
Tell that to my 52 plate (Sept 2002 to Mar'03) car's 2 factory fitted reversing lights.
Interesting advice on cambelt change
You've really never seen rubber get heat hardened and cracked, or oil contaminated?
Has he not heard of the internet!?
Skoda Fabia mk1 - different bumper styles?
...but fitting a vRS front bumper with a standard rear or vice versa may look somewhat silly.
Citigo headlamp bulb connector issue
You do have to pull quite hard sometimes to separate an H4 connector. I don't know what access on a Citigo is like, but you may be better to release the spring and pull with the bulb in one hand and the connector in the other.
