D.FYLAKTOS
  1. Factory, the best choice. I have used 2 brands Iridium spark plugs and never worked properly, also Bosch NGK with not good results. My Felicia is with ECU ship, custom exhaust, K&N filter and the Champion RC89PYC were/are/will be the No1.
  2. Mine was much-much worst not only in the MAP but also in the 2 plugs of the ECU. A thoroughly cleaning and a contact cleaner spray or electrical grease is a ''must''.
  3. Starters for Felicia 1.3 are around 0,8-1.1 kW 1.7-1.8 kW are for diesel 1.9
  4. For the one who will make the attempt to remopve the whole dashboard here are some ''sneaky'' screws. Here is something that i have done many years ago, i removed the glove box cover, fill it in inside with noise insulation layer (was hollow) and replaced some screws.
  5. Was "nice" from him to make political propaganda? Greeks, Albanians, Bulgarians diagree with guys like this, are we all wrong?
  6. As a last resort: There are 1 or 2 Upholster guys which make small modifications in the existing factory seat. I need a little bit higher in the sides and a little bit longer seat bearing, the frame/slide rails will remain original.
  7. As i have said in the Cold Start topic (which deleted exclusively from ''the other guy's" fault) i have done as a test only. In next life i will make it like Dino 246 GTS. 😄
  8. He knows very well what he meant. The latest years are all over the internet spreading their own propaganda but there is our answer and not only .
  9. @Papez i want to ask you, one of these 2 holes above the tow hook hole is for the hose that brinks fresh air inside the air filter box?
  10. I am out in a Cafe, when i turn back home i will try to find the fuel pump electrical diagram of the Felicia. This will help you?
  11. Relative topics with the same problem. https://www.briskoda.net/forums/topic/62322-felicia-fuel-level-sender-earth-connection/ https://www.briskoda.net/forums/topic/396359-fuel-guage-problems/ https://www.briskoda.net/forums/topic/255727-skoda-felicia-fuel-gauge-and-fuel-sender-problems/
  12. I haven't abandon this thought, many times i grab the chance to find bucket seat chairs like these https://media.partwerx.com/wp-content/uploads/2018/02/27141738/buerostuhl_racecar_sw_gr_fk_fkrse2481.jpg https://5.imimg.com/data5/SELLER/Default/2021/10/WX/HH/ZH/7276863/ufitblack-red01-1-500x500.jpg or this trying to see if i fit with every day clothes but there are some ''issues''. The 1st (and the most crucial) is that there is a huge distance between the back of my head and the head rest of the seat which means in every day use if someone hit me from behind i will brake my neck from the bounching (front-back movement). Yes there are some ''pillows'' in the market for this reason (as in the above picture) but that's not reinsurand me and they are ugly looking. in some of them i don't fit very good, the sides are tight and some of them have short lower part (seat bearing) which means there is gap between the back of my knee and the end of the seat. This gap causes fatigue while driving for long time, as we say here in GR ''your lengs are hanging''. For now i have found those 3 ''issues'' that makes the dream of bucket seat installing to moves away a bit ...
  13. Neither the majority of every day drivers, that's for a mechanic. He also use a gauge tester like this https://www.apexinds.com/mm5/graphics/00000001/atcltu32-20_640x640.jpg to check if you have fuel pressure and your injections status. Engine start spray.
  14. Run a scan tool or just made an ECU reset, tampering with this may cause an error and the memory will "hold it" and the car will turn off suddenly. It happened to me in the past while i was on the road.
  15. There is no country with that name, do you mean Vardarska Banovina? Here is the post stamp https://www.reddit.com/media?url=https%3A%2F%2Fexternal-preview.redd.it%2FUvKE__U4WUybZow2Cno-ijGZU1Yy6wsGQt0p7kDYcqY.jpg%3Fwidth%3D1080%26crop%3Dsmart%26auto%3Dwebp%26s%3D7f1bd0606163853afaec1f77eeb06997f01eb379 https://storage.googleapis.com/hipstamp/p/6b5793956ce1c786b29410d07e1b23ff-800.jpg That was the name till 1945 and with this name was printed in the WWII maps.
  16. Yes it has. I bought it with blue, i have tested in the past 2 sensors with yellow ring and both times i had major problems. I removed them, replace with blue and everything OK. Don't buy cheap sensor as VIKA or "no name", buy a brand one, "well know name" in the market.
  17. Mine was going up very fast in the first kilometers and the radiator fan was not working. This droved me crazy, one mechanic said that it's the VDO gauge problem and i had to replace it but this was a HUGE task for me plus the expenses. I have found the cause by my self, the base of the coolant sensor (mine has Blue ring) was dirty (here is an example) and this cause alteration of the signal, i clean it thoroughly and everything went back to normal.
