D.FYLAKTOS
  1. I don't want to open new topic, i found this while searching for the same thing. ''Krátké řazení Škoda Felicia'' is in Cz so if someone search with that key-word: https://speedpro.eu/produkt/kratke-razeni-skoda-favorit-felicia/ https://autobazar.hyperinzerce.cz/auto-tuning-ostatni/inzerat/56276645276713241645-kratke-razeni-felicia-1-6-nabidka-brno Looks like repair work.
  2. You means this? https://haynes.com/en-gb/tips-tutorials/what-is-car-heater-matrix This is in the back of the whole system, has 2 hoses (in-out) but i can not remove it by myself.
  3. Since i removed this dirty expansion tank i have done 2 coolant changes. The coolant sensor is clean but i can not know what's happening inside the engine. I will try to take photos of the new expansion tank (walls, bottom) for any signs of muck.
  4. Mine says, every 2-3 years, no need for more often because the gap only opens does not close so won't get any worst. I don't know if he is right or wrong. I have an MPi, so it's 0,25 IN and 0,20 OUT. Every year valve adjustment no matter the mileage? New gasket every time?
  5. That's the way Men here in Greece speaking about their cars (even when they were in the Army), they give them female names. Every year there is a gap change? You adjust them all the times? Or you inspect them ''just as precution"?
  6. I t was a difficult task, one hand holding the plastic tank and the other hand the Dremel, small pieces like filings everywhere even towards my face. This is the lower part, from there the hose goes to the radiator. I said the mechanic to remove the old coolant, fill it with water, rinse, fill it again rinse and then add distilled water and new antifreeze. No glitters or sludge was found in hoses, i personally check it even the coolant sensors was clean, no residues at all. According to the theory that when something boils the bubbles-lathe goes to the top and stays in the side of the utensil? Examples: https://www.argiro.gr/wp-content/uploads/2018/02/kameno-gala.jpg https://www.newsitamea.gr/wp-content/uploads/2014/10/med_gallery_447_8_96432.jpg The new coolant has about 450 Km on it, many times checked at night with flash light in purpose to the any glitters ''shining", nothing yet. The sides of the expansion tank are 95% ,only a small mark on one side but nothing serious. Except waiting and if necessary changing again the whole coolant and install a new expansion tank i don't know what else can i do. 🙄 No radiator cap on Skoda, there is only one on the expansion tank and the old and the new were clear. No residues (muck or glitters) on them at all.
  7. In the past (no internet, no forum, no pdf manual) we had major problem, only some old mechanics which knew Favorit wanted to work in a Felicia and we didn't knew anything except what the magazines wrote-stories by other drivers. Now he have Haynes, service manual, forum to ask for help there is a lot of knowledge from the owner. Fancy, famous repair shops (even young ECU programmers) don't want to work with it because they don't want to get their hands dirty and will have no big profit, they prefer newer models with ''come-i install-you pay a lot-go'' procedure.
  8. Oh God, did you got any bad smell inside the cabin?
  9. I have removed that expansion tank and i decide to cut it through to see how was inside and the result was shocking ! The most disgusting water expansion tank view that i have ever seen.
  10. Same here in Greece but with he (Local) young ones, they have that ''wise guy'' attitude with OBD scanner-laptop in their hands, a robe like doctors and disagree with everything you say to them. In case they don't know they reject you ''it's an old car, i don't have the programme for this car, no bulletin, my supplier does not have original parts for this, not worth the cost" and other excuses. Thankfully we have some old mechanics and some non Locals (young, non-Greeks) with smaller not fancy repairs shops which accept to work with an old car. By the way have you ever take measures for fuel consumption in City-Highway?
  11. Few years back i bought a new radiator fan, i learn by the hard way that the cables on the plug were posisioned wrong and the 2 scales of fan speed were in reverse. https://www.briskoda.net/forums/topic/485671-bosch-radiator-fan-for-felicia-help-wanted/?do=findComment&comment=5454358 No one made a test before they put it in a box for distribution to the parts shop (so also to customer).
  12. Just before installation. Finally i have access to the throttle cable any time. I have already done 30 Km in City Traffic, the rest of the test will be in Highway to see the Fuel Consumption difference.
  13. Count the rpm drop in gear change, make the change in 5000 rpm and make the same change again in 6000 rpm, then see where you are in the 1st change and where at the 2nd. The top performane for my car is above 5100 rpm.
  14. Velocity Stacks with foram filter, very interesting but i am sure @Thefeliciahacker will disagree with them. Here in GR we call them 4 throttles mainly for ''street racers".
  15. I never liked the engine cover, always causing me troubles so now it's time to modify it. I also made a repair on a crack. Next step is put back the two parts on engine and a 100Km road test in different conditions.
  16. Sandpapaer work is finished, no notches at all. Time for cleaning and painting.
  17. Let's wait for your new insurance contract for FIVA Felicia and it's terms.
  18. Why, how much you think will get from Allianz is someone broke your mirror? Keep in mind that there is no original part anymore so only an aftermarket can be accepted from the insurance.
  19. I had the cone removed for about 15 years, thus i could reach the 6100 rpm (5500 is the red zone) very easy with 2rd-3rd gear in Mountain Roads. You couldn't and still you can't.
  20. So if someone scratches heavily your door at night you wont get nothing from the insurance because the cost for a Felicia door (painting job) is about 180-200€ and that is beyond the exemption limit.
  21. Except all these notches (B) i will make smoother the left side (A), thus i believe more air will come inside smoother without turbulence. The same with the left side. I have finished the Dremel work and almsot finished with the sandpapers, then painting, cleaning and what's next? The cover, i will cut a part of it.
  22. https://www.briskoda.net/forums/topic/523298-im-back/?do=findComment&comment=5851914 These aren't? What we must add, key scratches-knife stabbing-pistol shooting-door kicking?
  23. Transalte this to Greek because i don't understand what you mean. Write the specific term that you had in your insurance contract that i have not.
  24. Yes you mention it avove about Allianz and i post about the Anyway programme. So the compensation limit is? The exception amount is? Mine are: Damages from a thief: 3.000 € (exemption 200 €) Audio system stolen: 400€ (exemption 200 €) Locks damages: 400 € (exemption 200 €) Fire from terrorist action: 2.000 € Fires from strikes-demonstrations (vandalism): 2.000 € (exemption 300 €) Material damage from the spread of fire: 10.000 € Broken glass (windows, windshields etc): 1.000 € (exemption 150 €) Record theft (documents of the car): 200 €
