Felica 1.3 - Something is 'on' but ignition is off!
Not always, here in GR when you buy a car with no factory unit intalled the electrician always asks you: Do you want the stereo to work anytime (even when the car is Off) or only when you turn the key? Some people want to hear music while the car ir parked and engine Off, ruins a bit the battery but i some cases helps (romantic dates 💗 ).
Koni Street rebuild.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanOne of the major problems in North Evia was this, in front of you a truck or a bus and all the other car behind it, no space for an overtake, here we call that as ''train line". The latest years the situation improved. Now a visitor can make an excursion without a ''traffic'' problem and a local guy can run a bit faster.
- E10 and E5 in UK for Felicia
The driver's lock is the first victim of an amateur burglar, mine is destroyed thus and i wish i was remote central locking without the alarm. Now every time i want to lock my car for a while i have to go to the passenger's side or open the rear door push the drivers pin lock and close the door so all the locks are engaged.
''be nice to America or we will bring democracy to your country'' The try to destroy-ban the tobacco farms there and now everything is aboput Corn and ''climate crisis'' although those which preach about is travel with learjets, have luxury villas with tennis court, swimming pool etc. They use in Brazil ethanol many years ego but here in GR i hear nagging from some drives (with experience in tuning) about this.
The noise is close to the grilles, water pump-altenator-radiator fan are away. It's like the blower fan to have some voltage (not proper) and try to spin a bit. @robchap here is about the dashboard removal. Here from mine.
Although ancient Greeks (Aristotle and Eyclides) say it and apply it first the other people know it as: Reductio ad absurdum. Soon or later we will find it, the sound is like a fan blade which barely touches something, i think it's a metallic noise and not plastic one (for example a teflon made gear moves back and forward).
Here are some examples: https://www.drive2.ru/l/488977835835261519/ https://www.drive2.ru/l/575590764801687759/ https://www.drive2.ru/l/2844587/ The phrase for Google search is: Снятие обдува Шкода Фелисия There is a mechanism in the first switch which controls where the air will be sent (driver, windshield etc), maybe this is stuck and it's under voltage continuously.
You mean from fhe engine bay side? No, some Russian sites have with the a/c blower out.
Felicia Special
@brefs No problem with your english, many members here (me included) are in the same condition as you. As for the protective fender flares why you screw them and don't use windshield glue?
- Felica 1.3 - Something is 'on' but ignition is off!
I have seen mechanics using a long screwdriver to spot the source of the sound, the nose touching different areas and the grip touches the ear. In the past i faced another situation, a small hand drill for carving, the switch on the power supply (had potentiometer for adjusting the rpm) was in Off position but still i could hear a very small sound ''Zzznnn'' like the drill was try to spin (but i didn't managed). The problem was in the switch, looked Off but wasn't 100%, a contack cleaner spray and everything OK.- Felica 1.3 - Something is 'on' but ignition is off!
@robchap If you had a/c i could say it's the air recycle motor, i had a problem in the past with it causing noise thst i could hear it because was stuck in On position. Nevertheless i would unplug everything and use some contact cleaner (with no oil). I am in smartphone, i can hear it good here in work but sounds like an axis of a fan always under voltage which tries to spin it but i can't because the blades are touching something.- Felica 1.3 - Something is 'on' but ignition is off!
Something relative but not the same, 2 times i the oast i had a continuous noise ("tzzzzz") from engine bay even when the car was off and the key removed. I could hear it while i was sitting inside, he made me mad because i couldn't let it like this all night. What it was? From the car alarm a plug from it's ground, due to moisture was a bit wet and was causing that cicada noise in it's contact. Did the previous owner had installed a device like GPS Tracking?- Koni Street rebuild.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanOne of the first post that i read about Koni Rebuild work at 2006, one of the most respected members in an auto-forum, more that 30+ years in repairs-modifications etc itself and knowledge of many brands-quality of parts etc. "As the Judge (nickname) said, send them to KONI, we buy KONI for 2 reasons, they are very good and repairable, don't think about it at all, the cost is several times less than buying new ones."- Koni Street rebuild.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI was reffering to the road of the @nta16 photo, no problem with the horsepower. One of my favourite car shapes was this:- Koni Street rebuild.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanIf has not potholes and it's wide enough for an overtake then it's fine.- Skoda Felicia goes to Russia (Siberia)
(Translated) IT IS HERE! The campaign was a success, and after a month of modifications to the car, we are leaving for the coldest permanently inhabited place in the world. To the Yakut region in Siberia - to Ojmjakon! This is the only video that has been released yet, the rest of this life journey will begin to be released after our return, in May at the earliest. Fingers crossed, we'll need it. About the Ojmjakon. https://weather.com/travel/news/breathtaking-photos-coldest-city-world-20140128 https://irishweatheronline.wordpress.com/2015/10/10/ojmkjakon-the-worlds-coldest-village/ Best of luck guys ! 🙏- Koni Street rebuild.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanOh yes.- Koni Street rebuild.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanThe GR road in an obsolate area in the country without lanes is this If you are a local guy and know that road extremely good then you can move a bit faster than normal, if you are not local guy and see that part of road you slow down. For sure a road like this it's not proper to test your new suspension-brakes-tyres, you must be careful all the time.- Koni Street rebuild.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanVery nice Mountain route but i wonder why the lines are _ _ _ (in GR means you can make an overtake) and not solid = which means you can not chane a lane. For example in 0:43 there is a turn with such marks but who would dare to make an onerturn there? In GR country road mainly is like this: Maybe you can find in an obsolete area a road like this https://images.greece.com/panoramio/07/23/06/57/5974c766a8e2f.jpg but it's wide and personally i would feel very unsecure to drive fast in a British country road like this: No lanes but mainly no good vision ahead.- Engine cover, do we really need it?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI meant comparing to a chrome tube that some air intake systems use. Supposed that reflects the heat and gets cooler sooner.- Engine cover, do we really need it?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanEvery time i want to oil the mechanism or clean the throttle body or clean the MAP i had to remove it (3 screws). The plastic absorbs heat from the engine and preserve it, it's not metal plus without it the area above the manifold could be more ''free'' for air circulation. I wish i could make the same. - Felica 1.3 - Something is 'on' but ignition is off!
