D.FYLAKTOS
  1. That was about 20 years ago in a famous exhaust maker, everything changed from the manifold till the tailgate, the steel that used was ''high'' class and not cheap that's why all these years i never had a problem. I told him that i want the car to be ''updated'' to have some HP gain in high rpm (combined with ECU chip plus sport air filter), i also changed the catalytic converter with a metallic (was ceramic). I lost some torque in medium rpm but i got some gain in high rpm, with 2rd or 3rd gear in the road (mountain) i could reach the 6100 rpm in sport driving (i don't like illegal racing drag style). Keep in mind that those days were with no internet, no auto-forums etc so the informations were coming mainly from magazines. Today's technicians now use computers and make things more ''calculated'' although now the steel is not always the best and with the economic crisis none Felicia (or old car) owner has the money to pay for such a custom A-Z work.
  2. Stability, especially in V\ style turns (here we call them Zig-Zag) something like Moose test. The car does not have the same inclination as the stock, is a bit stiffer and helps you lot in Sport style driving. I have them both and never regret that i installed them. How Sway bars work: https://consummatedriver.blogspot.com/2018/08/how-do-sway-bars-work.html?m=1 Strut bar https://www.sprracing.com.tw/strut-bar 😎
  3. I have a custom exhaust from A to Z, if there is a gain is in high rpm but any exaggeration would be ''paid of'' in low-medium rpm. As about the ''weight reduce'' in some things inside the motor is a know procedure but the last which must asked about this is the crank. For example i have heard stories about reducing weight from the flywheel but without balancing this with the crank isn't a risk for long term use?
  4. This is from the manual (with a correction by me) to show you how it is from the factory. This is from the hood, from that opening feeds with air the sponge filter, Has a gap. In dimensions it is smaller, it's 34x7,5cm when the sponge filter is 36x10cm and the plastic case is 38x13cm. If the guy removes the gasket and modify the remaining plastic case or make an outside one removing the ( and ) sides and make them vertical would be great?
  5. Unfortunately i haven't manage to solve the problem, take a look of how my cabin filter is today: Except the hair from dogs-cats, a bee and many other things. This is from an older snapshot, the sponge can not stop rain etc and to the sides i have this: which means that i breath dust and dirt. I have an idea, if i go to a guy which makes polyester, would be great to ask him to modify (by heat) the plastic case that the car has or make for me an outside rectangle case so i can fit filter like this (example) which have plastic frame and the guy can make them fit like an original? No leaks from the side, no dust etc, what's your opinion?
  6. The Haynes is for a driver that just wants to know the basics (of the basics) and do only few things, if you want to go further does not help you. Does these attachments help?
  7. I remembered this https://www.briskoda.net/forums/topic/491645-can-i-make-a-modification-to-my-felicia-13-filter-case/ when i saw that.
  8. In Greece those huge tailpipes we call them "stove pipes" 😆. You can hear their "bouaaaa" sound from blocks away.
  9. I have a custom exhaust from A to Z, few years back when i changed the muffler (the inside metal partitions have been destroyed) the mechanic asked me ''do you want to make it sound?'' but i replied NO because i know that this in a trip is a nightmare for the ears. On the other hand i am curious about the dimensions: 95x55mm 110x58mm 120x65mm 135x70mm The difference is in sound only?
  10. In the past i had a Remus muffler installed in my Felicia but after some years got a hole and i send it to recycle. While searching for Sport mufflers in CZ stores (the phrase in Google is Sportovní výfuk ŠKODA Felicia ) i found these: https://www.tuningshop.cz/sportovni-vyfuky-ultersport-skoda-felicia-1994-2001/ My first impression was the price, extremely high. https://tuning.autodoplnky.cz/vyfuky-ulter-sport/sportovni-vyfuky-na-konkretni-vozy/smid-3904/ According to the description: This exhaust is intended only for the following engines: 1.3 40/43/50kW, 1.6 55kW. It is equipped with E-homologation, which is valid in all EU countries. The exhausts of the Polish company Ulter are made of noble steel protected by black coating, the ends are stainless steel. They are made precisely for a specific type and engine of the car, they stand out for their extended service life, characteristic sporty sound and increase engine performance. Precisely specified for each car, assembly is easy. The manufacturer guarantees quality - ISO 9001:2000 certificate. https://www.laityng.cz/ladene-vyfuky-felicia/vyfuk-felicia-felrov1/ Especially in this i saw the dimensions options: 95x55mm 110x58mm 120x65mm 135x70mm 1) What's the gain to justify the high price? 2) The shorter the muffler the less is the torque in low rpm but there is a HP gain in high rpm?
  11. Maybe was one click loose maybe someone by mistake pull a bit the cable from inside the engine bay. By the way: before i put it back i have added in the past a light coat of glue or even strong silicone between the black cover and the grey factory dashboard because no matter how tight the screws are sometimes is getting loose and you hear crackle noises.
  12. One day i will show you my ashtray-project, has 4 buttons and one switch on the front surface. @nta16 : i kept my radio-cassette till 2022 in my car, everyone was thinking that i was crazy. @vucko1011 : Oh God NO ! R.I.P Sellotejp.
  13. These are not ''chemical experiments". New wheels-tyres were in the factory standards, new air filter, new discs-calipers-hoses were in factory standards. ECU chip were from a programmer from England.
  14. My A/C is Alex, added later by the local dealer. 2 times those relays caused me problems (1st time the mechanic slack and spray them and the 2nd time change one of them) with the radiator fan, maybe was a coincidence but immediately after the fan started work again.
  15. Felica 1.3 had already made a space for 2 speakes in the central console. https://nemigaparts.com/img/catalogs/etka/st/101863500.png https://m1.secondhandapp.at/2.0/5b27b219ccf1ea406c3fa31e?height=1024&width=1024 Even for the 1.6 can be found. https://www.megaparts.eu/en/product/228925056#gallery
  16. I never took risks putting different specifications fluids in Steering wheel oil-Brake fluid-Gear oil-Coolant-Engine oil. I have changed for example light bulbs (No Skoda) or added temporary an additive to Coolant or added noise-heat insulation etc but i don't like make ''Chemistry experiments" (in this case with DOT 5). Since i don't have extra money to spend on repairs and no time to do things like ''let's put some 0W-30 engine oil for few months do see how will work" or ''let's use plain water instead of Coolant to see the difference in performance" etc i stick with what the manual says. https://www.briskoda.net/forums/?app=core&module=system&controller=content&do=find&content_class=forums_Topic&content_id=512262&content_commentid=5752139 I don't know which is Fake.
  17. Amazing ! https://www.briskoda.net/forums/uploads/monthly_2023_05/64297cb0-b348-46f7-a2d6-7564acf124d1photo.thumb.jpeg.1ba8083cd3c3712791494788c35050cc.jpeg A fuse box wouldn't be better? Moisture,rain etc can cause you problems.
  18. Beneath that cover are 2 relays, open it remove them and spray with contact cleaner (with No Oil). In the past one of these relays caused me problems, the 1st day made a delay for the radiator to start and the 2nd day didn't let the radiator start at all and i had an overheating.
  19. Why would you want to make your car a "lab animal"? The Brake Fluid Is Black: What Does It Mean? If you open the car’s brake fluid reservoir and you notice black or brown fluid. So what happened to your car? We’re sorry to say that black brake fluid is a sign that your fluid is highly contaminated. When this happens, the braking system’s ability to pressurize is reduced and brake performance may be affected. Besides, black brake fluid means that the rubber gasket has deteriorated and the liquid in the tank is too old and needs to be replaced. In fact, it turns out that brake fluid contaminants are attacking the rubber seals and washers. The black color in the liquid is the carbon particles from the rubber pads. Why does brake fluid turn black? Many drivers said that black brake fluid is caused by its age. It’s a true opinion. Like other fluids, the brake fluid will degrade after a long period and it needs to be replaced. After a while, your brake fluid will accumulate enough contaminants and cause the color to begin to change. This changeover will change from clear/yellow to a darker yellow, and when brake fluid is brown or black, this can seriously affect the braking system. Inside the brake system is the brake fluid tank. From this reservoir, brake fluid travels its way from the cylinder to the car’s wheels. If you frequently step on the brake, the brake fluid will get contaminated faster. And even if you don’t drive as hard, as its feature, your brake fluid will still build up contaminants over time. The second cause of discoloration in brake fluid is the deterioration of some parts in the brake system such as rubber brake lines, the gasket on the auxiliary cylinder, or the wheel. Because brake fluid is corrosive. Even though brake system components are designed to resist such corrosion. If not serviced or cared for properly, these parts will show signs of wear and tear. At this time, the microscopic pieces and soot of the rubber will follow the path to penetrate into the brake fluid. Discoloration as well as reducing the effectiveness of the fluid. https://carfromjapan.com/article/car-maintenance/brake-fluid-is-black/
  20. From another source. VW SKODA TRW Wheel Brake Cylinder BWD268
  21. So let's read what the Mini Cooper drivers (not Americans) say about it: https://www.theminiforum.co.uk/forums/topic/275028-dot-5-brake-fluid/ Among them:
  22. https://www.corvetteforum.com/forums/c3-tech-performance/4724682-help-finding-seals-compatible-with-dot-5-brake-fluid-please.html Selection of EPDM Elastomer in Brake Hose Application for Improved Brake System Performance https://www.sae.org/publications/technical-papers/content/2010-01-1885/ Here is a ''study'' ,Rubber fluid compatability reference https://www.parker.com/content/dam/Parker-com/Literature/O-Ring-Division-Literature/ORD-5700.pdf I don't know if Model: Å koda Forman LX - W/LPG Year: 1993 has EPDM.
