D.FYLAKTOS
  1. No errors from throttle with 3 diagnostics. A local ''car guy'' with many cars (one of them was Favorit) told me that a gap of 100 rpm is not noticable from the computer and will not give an error. He insited that ''something small'' is the cause of that raise of fuel consumption on idle and suggested me to check the TPS but with 7 pns and no background (video from another Felicia) i can not do anything. The guys with 3 pins have the knowledge ready.
  2. The TC-6 says the fuel consumption in idle is ''approximately 0,8 ltr per hour" but i was seeing in the LCD screen always 0,9-1,00 ltr/hour which means every time the throttle plate was closing was not as it should be. More air-more gasoline-more fuel consumption in idle (traffic light for example) and especially in city traffic this is very crucial. I cleaned the sticky grease, lubricate the plastic reel and the axle of the plate and ofter some minutes of driving i started seeing 0,8-0,9 ltr/hour in the LCD screen, i don't think it was a coincidence. This gives some kind of tolerance, i have tried in the first years to make it more tight (i thougth will give immediately response to the gas pedal) but i saw that i was very wrong.
  3. No one has ever touched the cable at least for about 20 years. When the throttle plate returns to ''rest'' position (Off) seems to stop ''physically" ,only when i pushed with my finger the ''Z'' guide moves and touches the plastic buffer. The throttle plate can not close 100% otherwise the system will not have enough air for idle procedure and i think the grease much was delaying even stopped a little bit sooner (even for 1mm) the whole procedure.
  4. As the throttle plate is in ''resting'' position the ''Z'' style guyde does not touch the plastic stop but when i press it with my finger it closes and touch it. When i release my finger the ''Z'' guide returns back as the throttle plate. I know that there must be a gap between the plate and the body of the throttle because some air needed to pass inside for the idle but i don't think that muck helps in something so i remove it with a brush and a cleaning spray.
  5. I manage to take some photos (not very good) to show you something which i have done n the past and i think is Wrong. I apply grease to the plastic part (reel) of the throttle as a maintenance but i was exaggerate. I have the thought that after few years this became some sort of ''sticky'' making the moving of the wire a little bit difficult especially when i release the gas pedal and the throttle plate returns to Close position. Am i right or the tension of the mechanism (spring) is more powerful and can slur over?
  6. I would not buy a Vika for such a ''crucial'' part, there are some other brands in the market, for example here and here and here . Here is mine https://ntotsikasparts.gr/product/aquaplus-antlia-nerou-skoda-felicia-1-3-96-6-loukia-10691-85-5705/ installed 4 years ago.
  7. 047133061 PIERBURG 5WP4270 With that code the Google Search results wer disappointingly but searching with just the code 047133061 the results were just a little bit better. The price for new here in the local market is at least 320-370 € and of course no one sells the 7 pin connector it self. Here a guy manage to open it from the side. Of course i don't dare to alone such a thing.
  8. I will make a GL-4 change with the first chance.
  9. Motul Motylgear says covers API GL-5 and GL-4, this will harm the synchros in long term use?
  10. No good news, this is from anothe Felicia same as mine, i don't konw if i can open the side plate and remove that 7pin sensor. Then i have to do the same with my throttle body (plus new gasket) and if that won't work then again the whole procedure in reverse? Oh God No.
  11. An extreme example from Usa shipping to Egypt US $90.00 (approx EUR 88.40) eBay International Standard Delivery and another from Uk shipping to Egypt GBP 30.19 (approx EUR 34.63) Expedited Shipping (International Priority Shipping) Things are tough when you are in economic hardship.
  12. Shipping rates from Usa are outrageous, many times are 200% than the price of the product it self. I thought i was the only fussy guy because my Felicia takes 3.40 to reach the 70 'C
  13. @R_U_AFA : Take a look at this https://www.briskoda.net/forums/topic/499328-how-much-time-do-you-warm-up-your-felicia/?do=findComment&comment=5616459 it's similar to your problem? I Had it and some times still i hear that noise it but the solution is simple, double clutch.
  14. Poland-Hungary-Czechia are not so ''welcome'' in may EE countries and in USA because they don't accept their agenda in many political things and way of ''modern'' life (personally they do the right thing and here in Greece we respect them very much for this). Your Boot light is awesome and looks ''factory'', may years back when i installed mine i din't had that idea and now i regret it a llitle bit. Maybe in the future i will change it with a Led-Stripe, i need lot of light in the trunk becauise many times i work with my car at night or in a dark parking lot etc.
  15. No oil or muck in the throttle or even in the tube, what i saw there at 1:08 was a shock: Different type of engine of course but i read about carbon deposits in valves and since i have an old car maybe this Oil Catch Can could heped me over time.
  16. Can a Felicia owner have some benefits from installing a device like this? I have read many articles and i have seen many videos but for turbo cars although here in this forum there is a thread about Fabia 16V https://www.briskoda.net/forums/topic/481634-fabia-mk2-14-16v-oil-catch-can/?do=findComment&comment=5410097 but since Felicia is an older generation car i wonder if it's good to have an Oil Catch Can. What say you?
  17. When you press the clutch pedal the noise stops? Many times when you start the car at morning when it's cold you hear that noise too? It's a rythmic noise ''kar-kar-kar'' the same tempo with car's idle noise?
  18. In the past i had Eibach and the latest years i have Apex. I am trying to avoid not famous brands in such products, the risk is big.
  19. The weak point in CV shafts is the boot. After years and miles of turning and bumping up and down with the suspension the boots weaken and begin to tear. A torn CV boot allows the grease to leave the joint and road dirt, water and other contaminates to enter the joint. Contaminants inside of the joint cause friction which creates accelerated wear on the internal components in the joint and creates play inside of the joint. Once a CV shaft has failed you can hear a loud click, click, click noise when turning the vehicle and slowly accelerating. https://www.timsquality.com/blog/cv-shafts--what-are-they-and-how-do-they-fail-
  20. I know because Greeks named that city as did in hundreds of others in the area. Alexander the Great is Iskandar in Middle East right? https://en.wikipedia.org/wiki/Iskandar Alexandria in Greek is Αλεξανδρεια which means ''the city which named by Alexander", the same applies for example to Antiochia (named by the Greek Antiochos) etc. This brand can be found here in Greece since 2000 but it's not too famous https://www.yiannitsaros.com/product/anti-freeze-5l-green/ In the green says TL 774-G (G-11) ,there must be a mistake it's TL 774-C https://www.iada.es/en/product/glycogel-hybrid-50-g-11-2/ Few years ego i was using another Spanish brand Repsol G11, fantactic but difficult to find it here now.
  21. ''Iskandar" I also use 10W40 engine oil here in Greece but you are using for Coolant? What mixture 50-50 or 60-40 or 70-30?
  22. That's a good idea. I thought you were native Polski.
