Everything posted by pab567
MiB 2 coloumbus infotainment system frozen, buttons and touchscreen don’t work
Then either the glove box unit or harness.
- Fabia III 2019 MFSW retrofit
Update to Bolero
Sent in PM
OK, that's enough. I have never met a digitizer faulty in these displays. Being in your shoes I would order a complete display unit for replacement, with possibility to return if it doesn't help.
Seems teh faulty display but pls share VIN in PM so I can check part numbers.
OEM head unit without a serial number...??
One more idea - assuming you are NOT interested in Android AUto and/or Apple CarPlay you could also use Amundsen+ (RNS315) but you have to make sure it is the version with BT buil-in (as they were units with and without BT).
Look for RCD 330 / RCD 360 units with green backlight. Or MIB STD2 PQ series.
Unfortunately I don't know these units. WHat features would you like to get with such retrofit?
Upgrade Standard Radio to factory Bluetooth...
Unfortunately I am not familiar with units used in Citigo
Firmware Request MST2_EU_SK_ZR_P0480T
Sent in PM
- Is it possible to upgrade the infotainment screen?
Amundsen MIB2 Firmware Update
Pls contact @ricSKODAoct he has prepared some nice manual
Unfortuntaely I don't have it @thaifred check your PM
Yes, it is the same. @Sanbu sent in PM
Sent
Help! Amudsen: black screen but sound and touchscreen are working
PM sent
Sent in PM
This means you have done something wrong. Use Manual SWDL and select all but emergency in Main and emergency in CPU.
First of all: this is NOT Amundsen, this is SWING. Pls share VIN in PM.
Radio with Weak/Intermittent DAB Signal
Yes, you can change all RequiredVersion lines to "0". It can be done befor you start the update.
Nope, you modify it on SD card
@augusto73roma you have to patch swdownload from toolbox and then start installation of 0480 firmware. It will break with some error messages - you have to modify metainfo2.txt (change "RequiredVersion..." lines from any version it has to "0").
Infotainment Screen Replacement
@AJK87 sent me VIN in PM
