pab567
FREEDOMTech
Everything posted by pab567
  1. It does NOT support Bluettoth - no required HW inside. Think about retrofitting MIB2 - you will get higher resolution, Bluetooth, Sport Menu, Voice Control, RVC support, and creme de la creme - SmartLink.
  2. 5E0035874A is MIB1 glove box unit, it will NOT work with 5E0919605M display unit which is dedicated for MIB2 units - so either you return to your old dsiaply unit or you have to replace glove box unit as well. Pls share VIN so I can check more details for compatibility.
  3. First of all - thisis NOT Amundsen, this is Bolero MIB1 simplified version - without Bluetooth, without RVC support, without Voice Command, and of course without SmartLink. What do you expect from firmware update?
  4. MSTD_EU_SK_P6230 MU0490 is NOT for Bolero 5Q0035840C, you need MST2_EU_SK_ZR_P0480T for it. I sent you download link in PM.
  5. @dacn I sent details in PM @Andymod MST2_EU_SK_ZR_P0480T will NOT work directly on any unit that was manufactured with software different than 04xx (xx - any number). This means it will NOT work directly with 5Q0035874B. There is a way to push MST2_EU_SK_ZR_P0480T into 5Q0035874B but it requires unit to be patched first - google for MIB STD2 TOOLBOX.
  6. This unit does NOT have built-in Bluetooth at all :( I suggest replacemnt with MIB2 unit. @fatzz I sent you in PM link to download MEN2_EU_SKGPx_P0080L_8755
  7. What's the part number of your unit? Like 5E0035812A, you can check it in settings / system info.
  8. Partnumber of your unit or VIN of your Fabia pls.
  9. Download link for MST2_EU_VW_PQ_P0254T sent in PM
  10. 1. format SD (best max 32GB) under FAT32 2. unpack to root (metainfo2.txt and all the folders must be placed directly on SD, not in any folder) 3. insert SD card into the slot 4. enter Service Menu (long press MENU button)
  11. Thank you :) @ceper80 check your PM
