Everything posted by pab567
Emergency Download
Link to download MST2_EU_VW_ZR_P0140T sent in PM
I need Bolero Update :-)
I have never heard about such firmware. Moreover, I have never found installation files for any newer software than MST2_EU_SK_P0359T. The solution you can use is to: Patch swdownload to enable installation of different firmware. Install VW firmware MST2_EU_VW_P0480T (metainfo2.txt must be adjusted to enable installation on your unit). Install patch to enable VW FEC/SWaP codes. Enable VW FEC/SWaP codes. Install modifed SKODA HMI.
Thank you!
Link to download MST2_EU_SK_ZR_P0253T sent in PM. If you want you can donate The Great Orchestra of Christmas Charity
Link to download MST2_EU_SK_ZR_P0369T sent in PM
Desperately in need of this software: MEN2_EU_SKGPx_P0080L_MU8755
:ink to download MEN2_EU_SKGPx_P0080L_8755 sent in PM
- 2017 SW update questions??
Radio Head Unit Issue
Remove it and post the picture of label from upper housing
Amundsen MIB2 Firmware Update
Unfortunately I don't have it, 0359 is the most current firmware I have
- CarPlay crackling issue, software update fix?
Octavia Mk3 Screen Retrofit
Link to dwonload MST2_EU_SK_ZR_P0480T sent in PM
@amurskoda you can switch from your screen to 5E0919605M or 5E0919605N but you can NOT to 9.2" screen 5E0919606D unless you rework your glove box unit to MIB2.5
- Skoda Fabia MK3 2019 CarPlay shows only sometimes.
@Adenauer unfortunately this is NOT possible, you have to replace infotainment reader to either full version of Bolero or Amundsen. Pls let me know if you want me to prepare the offer. @Keew62 I sent you in PM link to download MST2_EU_SK_ZR_P0369T
- OEM+ android auto options
Facelift steering wheel
Yes, there wwas Superb Mk2 with paddles, I even had one MY12 V6 3.6 DSG with paddles. Send me VIN of your Superb in PM.
For manua DSG gear shift? Of course it was!
As far as I remember 0 yes, unless you instal the one with paddles.
Unortunately, you are right, you need MFSW either from Superb Mk2 or Yeti. I think some from O2 will also work but not sure which ones.
As far as I remember it's plug&play. You can add MSFW with paddle shift but it requires coding and MAY require change of steering wheel controller. Pre-lift airbag will NOT fit, it must be replaced too, as well as the harness located inside the steering wheel.
- Amundsen MIB1 Firmware update finally completed - MSTD_EU_SK_P6230 MU0490
Download link for MST2_EU_SK_ZR_P0480T sent in PM
Skoda Swing Firmware Update - MU 8755
PM sent
