pab567
FREEDOMTech
Everything posted by pab567
  1. It looks like it's a glove box problem. WIthout dedicated tools (at least UART) you can't say what the root cause is.
  2. Yep, sorry, I forgot it, you need VCDS, OBD Eleven, VCP, ODIS or VC Tool to enable develope mode.
  3. Nope, you install it as a regular firmware update (as long as you have unit with oem sat nav - and you have it )
  4. @Cdrmihh it's normal. You have to patch your unit first. Google for MIB STD2 Toolbox
  5. Unfortunately I rather expect glove box unit to be faulty... Pls ping me when you have new LVDS cable...
  6. Both possible with your unit, check MIB solution one website
  7. Then pls make backup from 5F unit with coding and adaptations and send to me by PM
  8. @major-eyeswater pls share your VIN so I can chaeck your current setup and list you the options you have.
  9. @superb5335 do you have adaptation channels maps from old and new unit?
  10. I think it was even earlier and no, there is no update for Superb Mk2 navigation units.
  11. Sorry, too tired... switch to PM
  12. Pls share your VIN so I can check your car configuration and describe you all the options
  13. LInk and instruction sent via PM
  14. What is your sat nav model?
  15. Amundsen 5Q0035864x / 565035874x / 565035864 / 575035875 and Columbus 3V0035020x / 3V0035021x / 3V0035043x / 3V0035044x where x is any letter
  16. No, you already have the most recent SW. Possible ONLY via external third party adapter connected to USB, e.g. CarLinkIt.
  17. Link on PM. Toolbox installation in non-nav unit as yours requires soldering.
  18. You have to store each station once again, this should find the logo in internal DB and save it.
  19. Unfortunately it will not. I will send you contact to me on PM.
  20. Change channel IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode to 1
  21. No need to send the unit for recoding First of all - good job with adaptation maps. You need to adjust coding, change byte 13 to 88, byte 15 to 00 (unless you installed LTE antennas and phone coupler), byte 22 to 01, byte 24 to 7E Some adaptations shoul dbe changed as well: Channel new old Identyczne IDE10480-MAS10741-Interface for external media: activation-Connection 1 not activated activated FALSE ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE not activated activated FALSE ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high not activated activated FALSE ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high not activated activated FALSE ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B activated not activated FALSE ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus Terminal 15 Suspension data bus FALSE ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL available. Not available FALSE ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus Terminal 15 Infotainment data bus FALSE
  22. 1. I'm not 100% sure but I'm afraid not 2. Yes but NAV and TRAFIIC buttons will not work as 5q0035840b doesn't have oem sat nav built-in
