pab567
FREEDOMTech
Everything posted by pab567
  1. Indeed, MODE-Selection is SWAP-thing and Skoda does not allow or sell any retrofit-possibility this like Audi/VW. Link for latest SW I sent you on PM
  2. replied in your original thread
  3. When you caonnect the phone with USB cable is there any message displayed in the upper left corner? Can you insert VCDS log from 5F unit so we can see if there is any error reported?
  4. The issue is that there have never been released OEM trunk handle RVCs of this size (90mm). If you do not want to cut your trunk lid then the only solution is to install aftermarket camera, e.g. LS8012 The biggest disadvantage of it is missing sprinkler which is present in most of 110mm wide OEM trunk handle RVCs - but to install OEM trunk handle RVC you must cut your trunk lid to increase the whole for trunk handle Coding is required in both PDC / PLA module and infotainment unit. Parking module (PDC / PLA) might require firmware upgrade or replacement, pls share part number of your current module. To have guidance lines you must add camera controller 7N0907441B.
  5. Nope, 5Q0035840 (with no letter suffix) supports MirrorLink only - no Android Auto, no Apple CarPlay.
  6. All check your PMs. If by MIB2 Columbus display you mean 5E0919606 then the answer is yes, but two buttons (NAV and TRAFFIC) will not work as 5Q0035840 does not have oem sat nav built-in.
  7. Do you have any diagnostics tool like VCDS or OBD Eleven?
  8. Probably you have old type of Premium Bluetooth that takes over SIM via RSAP (Remote Sim Access Profile) and doesn't support audio streaming. Look under front right seat and read the BT module part number (located under the plastic housing).
  9. There might be several reasons for such behavior, both HW and SW. If you don't find anyone locally you can send it to me for repair - just pls note I'm located in Poland 😞
  10. SO I understand you have infotainment system with SmartLink activated. Try another cable between USB and your phone and try another phone to with both cables to identify if the problem is with your phone or with the infotainment system. Also pls post part number and SW version of your infotainment system - can be checked in menu SETTINGS then SYSTEM INFORMATION
  11. This is the best as gives overall picture and detailed error codes
  12. Can you post full autoscan from VCDS?
  13. Why don't you search forum before asking again? All your questions have already been answered several times...
  14. Unfortunately not... I sent you link for SW upgrade in PM. If it doesn't help I beleive you need to have it replaced.
  15. Sent you link to MEN2_EU_SKGPx_P0080L_8755 in PM.
  16. Pls post you unit part number and SW version - can be checked in menu SETTINGS then SYSTEM INFORMATION.
  17. Pls check your PMs,no message in PM = you already have the latest available firmware.
  18. First of all,pls use English on this website. You have thje latest avaliable firmware for your unit.
  19. Unit must be patched first (swdownload) and MST2_EU_SK_ZR_P0480T version with modified metainfo2.txt file must be used. If you don;t have CANTON then after such upgrade right and left channels will be swapped.
  20. Nope, you have the latest firmware.
  21. Unit must be patched (swdownload file) to install MST2_EU_SK_ZR_P0480T
  22. It is possible toexport end user data, which should also include data you need, but it requires special software tools. Are you going to buy another Superb Mk II?
  23. And unfortunately I don't have a solution for you either 😞
  24. I'm sorry I have no firmware for your unit 😞
