pab567
FREEDOMTech
Everything posted by pab567
  1. If you share VIN i can provide more details on car configuration
  2. Nice lady
  3. Yes, I have, if you are interested pls contact me on PM. It's quite easy, all you need is torx T20 screwdriver and 2 removal keys. 30 minutes work. It's just the question of replacing glove box unit (infotainment reader), display unit replacement is not necessary.
  4. Any unit - but Bolero and Amundsen can be patched which is not possible for Swing+ (at least I don't know any solution for it).
  5. If you don't need Android Auto and Apple CarPlay then Swing+ is a good choice otherwise go for Bolero or Amundsen. Swing+ must have component protection removed by Skoda dealer (or someone having ODIS online account for Skoda) and parametrization (at least coding and adaptations) adjusted to your car.
  6. Have you used VCDS or any other disgnostics tool to read errors?
  7. I suspect that dial encoder is broken. Do you have VCDS or any other disgnostics tool to read errors?
  8. All check your PMs. 1. format SD (max 32GB) under FAT32 2. unpack to root (metainfo2.txt and all the folders must be placed directly on SD, not in any folder) 3. insert SD card into the slot 4. enter Service Menu (long press MENU button)
  9. There is 0480 available but if everything works OK then I do not recommend to run this update as changes to 0478, which is very stable firmware, are minor. Radio stations logos are built into the firmware. Maps on seaparate SD.
  10. BT Harness pin 4 -> Head Unit pin 11 BT Harness pin 5 -> Head Unit pin 5
  11. You are not the first with this problem... make reset to factory settings.
  12. Just re-save the stations and they should appear again
  13. Link to 8755 sent on PM. What is your CarPlay problem?
  14. Contact your Skoda dealer
  15. Yep, your units support it, so you have to contact yoour Skoda delaer to have it enabled.
  16. For this generation of Columbus units (RNS-510) map updates were not available online. Since couple of years (I beleive like 6 or 7) there are no more updates as support for these units has been closed.
  17. Well,assuming there is no bug in the catalogue, activation is available for your unit - see screenshot below. Make one more check. Go to service mode (long press SETUP button) then FEC/SWaP codes then supported codes.
  18. Well, looking at the unit I'm not 100% sure. Pls share VIN.
  19. I believe buying a second hand panel and replacing it by yourself is the cheapest option. It's easy and takes 5 minutes.
  20. I'm sorry, this is not possible, you hae to replace gloe box unit. Pls share ypour VIN so I can proide more details.
  21. MST2_EU_SK_ZR_P0138T What would you like to achieve with upgarde?
