pab567
FREEDOMTech
Everything posted by pab567
  1. 0254 - sent you link on PM. Unfortunately, I have no change logs 😞 Yes Yes, unit muct be patched.
  2. 1. format SD (max 32GB) under FAT32 2. unpack to root (metainfo2.txt and all the folders must be placed directly on SD, not in any folder) 3. insert SD card into the slot 4. enter Service Menu (long press MENU button)
  3. So this is Amundsen. You mentioned that you have CANTON sound system. In such setup each speaker is driven independently by a pair of wires, directly from the amplifier (not from teh glove box unit). I believe there are two separate issues: 1. Bluetooth disconnection/reconnection. 2. Tweeters being overloaded One of the reasons could be some SW problem - I will send latest SW (048) on PM.
  4. SW upgrade does NOT activate ANdroid Auto, it is protected with FEC/SWaP codes, so must be either activated by Skoda dealer or unit must be patched.
  5. For coding change byte 04 in 5F unit to BE.
  6. I can deliver P&P, pls contact me on PM if you are inetrested.
  7. Google for 5E0919605J, 5E0919606, 5E0919605M (display units) and 5Q0035864A, 5Q0035864B, 5Q0035864C, 565035864 (glove box unit) as both are required
  8. In such case unit for you is Amundsen 5Q0035864x / 565035864 (x - any leter A, B or C).
  9. You have Swing radio, part number 5E0035867C - no Bluetooth, no SmartLink, no DAB reception, no OEM sat nav, no video playback... nothing but FM radio reception and music files player (from SD and USB). The question is what are the "must have" features out of listed below: 1. Bluetooth, with handsfree and streaming support 2. SmartLink (Android Auto, Apple CarPlay, MirrorLink) 3. DAB reception 4. Video playback from DVD, USB, SD 5. CD playback 6. OEM navigation 7. displaying OEM maps in Virtual Cluster (Active Info Display).
  10. Unfortunately, I have nofirmware for you unit, allothers pls check your PMs.
  11. No native support, only via external third party adapter connected to USB
  12. This is Composition Media PQ MY16. Languages are coded in the firmware, I beleive BUlgarian is not available in this one and cannot be added just like that.
  13. You have the latest available firmware. This unit does NOT support wireless SmartLink.
  14. There is no "Amundsen without navigation", 5Q0035840C is Bolero MIB2 MY18. You have download link in PM.
  15. I'm in Poland so it does not make any sense to send it to me due to high costs. The IC that needs soldering is 8-bit microcontroller PIC16F747, I marked it red on the picture below.
  16. It's not the issue of wiring, it's probably the well known problem of breaking soldering points of one of ICs. If I am right then the repair is quite easy - it's enough to have this IC resoldered.
  17. It's enough to drive external aftermarket PA
  18. In original setup: 8 speakers means front 2 tweeters and 2 woofers, rear 2 tweeters and 2 woofers 6 speakers means front 2 tweeters and 2 woofers, rear 2 wideband
  19. SmartLink - fully understood. It can be activated in your current unit. BUt what do you need oem sat nav,which is always outdated and offline, for if you have SmartLink and can use online navigation, which usually is actual and has traffic information available?
  20. You can either buy activation from your Skoda dealer or the unit must be patched /hacked which requiresit to be disassembled and soldered 😞
  21. I sent you on PM link to download firmware. Pls note it will requires maps re-installation after the upgrade.
  22. According to parts catalogue, your car is equipped with MIB2 Bolero unit with DAB, part number 5Q0035842A and display unit 5E0919605H. What are you missing in this unit?
