pab567
FREEDOMTech
Everything posted by pab567
  1. 3 - yes 4 - KL30 (+12V), KL31 (GND) 5 - yes
  2. Unfortunately I don't have software for your unit.
  3. Unfortunately there is no update for your unit.
  4. Unit must be placed in emergency mode and reflashed. It requires unit to be open and UART connected.
  5. Check your PMs. Please note I will not be available until September 6th so the requests for SW update will be on hold.
  6. Unfortunately there is no newer SW version available for your unit. A solution MIGHT be to reflash your instruments cluster with newer SW however this does not always help.
  7. Not possible with 5Q0035820, must be replaced with 5Q0035842x (x = A, B or C)
  8. Unfortunately there is no SW update for your unit.
  9. Unfortunately there is no SW update available for your unit at all :(
  10. Model number and SW version of your current unit?
  11. There were no MIB1 units installed in Fabia 3 so for sure you have MIB2 unit. Pls share model number and SW version of your current unit.
  12. Check PMs - no link means I have no update
  13. @Zephyrus unfortunately I don't have newer version for you unit. All others pls check PMs.
  14. Bad news - your unit is 5Q0035819C, such units do not support SmartLink (although you might have such icon available in touch screen menu). Checking PQ codes of your car just confirms it: To get SMartLink active you must have glove box unit replaced :(
  15. VIN of your Fabia?
  16. Even MST2_EU_SK_ZR_P0480T PMed
  17. 0480. But if you have 0478 and don't have any issues then I do NOT recommend to update.
  18. @vdias if you want to get such unit for your car pls contact me on PM
  19. Rear view camera image but no OPS - this is related to SW versions above 0241. To have it solved (to have OPS overlay or RVC image) you need to replace or upgrade SW in your PDC / PLA unit. The ones that work are those used in Yeti FL cars - 5J0919475C (4 channels - rear only, can also use any module with HW version 5J0919475A and have firmware updated to 0011), 1Z0919475G (8 channels, can also use any module with HW version 7N0919475 and have firmware updated to 0011), 3T0919475G (PLA 12 channels, can also use any module with HW version 4H0919475E and have firmware updated to 0013), An interesting option is also to replace 8 channels controller with 1K8919472C which has the feature of self turning on when approaching car / wall in front of you (it requires re-pinning or special adapter as plugs are different).
