pab567
FREEDOMTech
Everything posted by pab567
  1. Unfortunately I don't have any formware for your Swing :(
  2. Yes, you can get the cheapest version and have it upgraded to the most recent version.
  3. No... 0411 is the lates one. All others pls check your PMs.
  4. Firmware you have is the most recent I know :( so if you have any issues I recommend to raise complaint (as I expect your car is still under warranty). But first try another cable between USB port and your phone.
  5. Unfortunately I don't have firmware update for your unit - although I have seen units with newer version (0363).
  6. If your unit was factory installed then it should not have happened. Or is it retrofitted hacked unit?
  7. Unfortunately there is no newer version for your unit :(
  8. And what is the unit you have now?
  9. Προτείνω επίσης να γράφετε στο Klingon, ο καθένας σίγουρα θα καταλάβει Translation below:
  10. Bolero MIB2. Can be done but NOT remotely. Contact me on PM if you are interested.
  11. @d_olalla detailed list of changes (so called change log) is not available, no new features, just bugfixes - check your PM.
  12. Unfortunately it will not - your unit does NOT support SmartLink, although this is included in the menu items. None SW update will have it sorted. The only solution is to replace unit mounted behind glove box - if you are interested pls contact me on PM.
  13. This is NOT SW version... software version is like 0253... or train like MST2_EU_SK_ZR_P0253T... and model number like 5Q0035819A...
  14. They are right - this is normal behavior when unit is exchanged. What is the exact model number of software version of unit you installed?
  15. I have no clue if this unit support RVC, sorry...
  16. @RABAH has SWING, I cannot help with SWING.
  17. pab567 replied to Hoggyf's topic in Skoda Yeti
    P&P although additional QuadLock adapter (from old 40-pin to new 52-pin) and new USB is required. Climatronic visualization doesn't work in MIB STD2 PQ.
  18. pab567 replied to Hoggyf's topic in Skoda Yeti
    This is either Amundsen (RNS510) or Amundsen+ (RNS315). As you mentioned that there is no BT module under the seat then this must be Amundsen+ (RNS315). Unfortunately I have no firmware for it. If you are going to use this car for next couple of year I fully agree with @langers2k regarding MIB STD2 PQ.
  19. pab567 replied to Hoggyf's topic in Skoda Yeti
    Let me know model number and software version of your infotainment unit.
  20. Visit your local Skoda dealer... but I really doubt they will be able o help you if your car was installed wih unit taht was not supporting these features.
