ords
Everything posted by ords
  1. No problem if it's a left hand drive. Same as the bonnet release.
  2. Slightly different model, but check list should be almost the same
  3. You could try re-callibrating the system. There's a youtube vid in this link.
  4. If the a/c won't work when it's around freezing point, how do they get on in cold climate countries? How do they stop windows misting up?
  5. It's a modification. Ins co has to be told.
  6. Chips are fattening anyway
  7. This thead also mentions whether to leave the battery connected or not.
  8. If it was doing a regen the stop/start would be disabled.
  9. I mean no one has said they've had to replace the battery
  10. Interesting about the the siren back-up battery. I don't recall anyone mentioning this & the early models are well past 6 years old.
  11. Plenty of info on the Web. Some insurers will not insure these type of cars.
  12. Lots of threads in this forum about coolant levels dropping with no signs of a leak
  13. 100K = 100,000 miles. Is that what you mean?
  14. Too many threads to go thru. Just start searching
  15. If you search for "rattle" in this forum there are many threads
  16. Tried several times re-booting it & suddenly it gave me the source option on the sd Tried re-booting a few times & then it suddenly gave me the source option. All went thru smoothly, so thankyou for the advice.
  17. I have the instructions from a couple of years ago & had the same problem then. I'll do what you suggest & re-boot with the usb already inserted & try the same with the sd card if that doesn't work. Thank you for your reply.
  18. My problem is that when I want to choose the source, either usb or sd card the the 2 options are not highlighted. The unit recognises the usb stick or card when I insert them. Any ideas please? Thank you
  19. These are just a couple of many threads on this forum. Just search for "dab" in this forum.
