langers2k
  1. On a FL it should be a H7 for dipped and H1 for main beam. Using LED's in dipped or main beams is equality illegal and should both fail the UK MOT in the same way, namely "4.1.4(c): Light source and lamp not compatible". Personally, I never had an issue with the main beams on my MK2 FL, they were nice and bright with decent throw. I'd suggest you make sure they are correctly aligned and that the reflectors, lens, bulbs are in good condition and clean. However, if you do need more light, fitting an LED lightbar is probably the best solution. They are typically more popular in the Scandinavian counties and can be fitted in a few places. As for the DRL, the method to turn them on/off is mentioned in the owners manual: If that doesn't work, you'll probably need the DRL's enabling with VCDS or similar first
  2. Looking at your adpmap: ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26,maximize ,16 ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26,maximize ,16 ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26,maximize ,16 ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,100 ,16 ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26,0 ,16 ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26,0 ,16 ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26,0 ,16 ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2E ,16 ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,0C ,16 ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,not active ,16 ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,Always ,16 ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16 ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26,not active ,16 ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26,not active ,16 ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26,not active ,16 ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26,not active ,16 ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26,not active ,16 ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26,not active ,16 ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26,not active ,16 ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27,maximize ,16 ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27,maximize ,16 ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27,maximize ,16 ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,100 ,16 ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27,0 ,16 ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27,0 ,16 ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27,0 ,16 ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,2F ,16 ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1C ,16 ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,9 - allgemeine Glühlampe 27W: auch H15 ,16 ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,Always ,16 ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16 ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27,not active ,16 ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,not active ,16 ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27,not active ,16 ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27,not active ,16 ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27,not active ,16 ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27,not active ,16 ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27,not active ,16 So at a guess, I'd change "Leuchte26NSL LA72-Lasttyp 26" to "9 - allgemeine Glühlampe 27W: auch H15" and see what happens. I know you've checked the bulb is there, have you also checked both sides have the same number of wires to the rear cluster?
  3. A rear work lamp is a perfectly valid solution even if you don't like it As would fitting some motion triggered lights to your driveway If you do fit an LED, my only suggestion would be to buy a decent quality branded LED rather than generic Chinese stuff. If it causes a bulb out warning, have the car coded to suit (ODIS-e or VCP only, VCDS can't do this on a Yeti) or fit load resistors. If you do use load resistors, remember they will get warm so attach them to the metal bodywork to help with heat dissipation. I'm not sure what bulb the Yeti uses but these tend to be well liked: https://www.powerbulbs.com/product/philips-x-tremeultinon-led-gen2-p21w-6000k-twin
  4. If I remember correctly, the 1989 UK regs state "The total wattage of any one reversing lamp shall not exceed 24 watts". However, your car will actually be covered by the ECE regs rather than the UK ones. In this case, it's R23 that covers reversing lights and it's got much more complex requirements. Just for example, 6.1.3 states: That being said, there are no brightness checks/requirements for the UK MOT
  5. I've never used OBDeleven but I believe you can select control modules? If so, I think you're looking for "Lock Electronics", at least based on these screenshots I found:
  6. The most reliable way to check for a VAQ is with VCDS or similar, check if address 32 (Differential Locks) is present Otherwise, you can check the original build data for PR-1Y2 which I think is the front diff lock.
  7. Adding front sensors might be close to that price but a rear camera shouldn't be: - Genuine highline rear cameras with moving guidance lines should be £80 - Aftermarket versions with moving guidelines are closer to £40 To the OP, if you find a car that meets your spec but is missing a camera, there is a guide to retrofit one for an Octavia below. The Superb should be very similar but with longer wires
  8. Q should be fine based on this list: http://wiki.ross-tech.com/wiki/index.php/Navigation_System_(RNS510)_Retrofitting
  9. Please use English so we can understand you As this is the Superb section, you might have better luck in the Octavia section. This post is probably a good starting point:
  10. Faulty start switch seems possible as it effects both starting and stopping the engine 🙂
  11. A missing fuse would do it! Glad it's sorted
  12. Run a switched live for the headunit?
  13. Yup, there are some 1520/V13 files up for the MIB2 Amundsen as mentioned in another thread:
  14. I agree the URL doesn't feel like a VW one but it is If you go to the VW webportal https://webspecial.volkswagen.de/vwinfotainment/int/en/index/downloads/maps-download#/ Select something like the Golf GTI from 2017 and discover media, then look at the links, they are all at lighthouselabs.eu For instance: https://vw-maps-cdn.lighthouselabs.eu/vw-maps/DiscoverMedia2_EU1_1410_V12.7z Changing the 1410_V12 to 1520_V13 gets the newer version.
  15. Not sure I'd call them bootleg - they are hosted on the VW servers if you check the URL's
  16. Does this help: http://www.pss-steering.com/en/prog_rack_steering.html Or maybe this different system:
  17. I've never used OBDeleven but I think there is a 'history' option. You could also ask on their forum for support
  18. What did you do and which tool did you use? Depending on the tool, it may store the changes you made to restore the config. If you have no backup, you'll need to take it to a dealer as only the Skoda/VW servers will have the original coding...
  19. @MartiniB - Looks like there are some new VW maps https://vw-maps-cdn.lighthouselabs.eu/vw-maps/DiscoverMedia2_EU1_1520_V13.7z Downloading at the moment so I've not checked them.
  20. 5E0919605N looks to be a Bolero with a 'Setup' button. 5E0919605M looks to be an Amundsen with a 'Nav' button.
  21. Sure, drop me a PM if you'd like a scan I've removed airbags a few times so if you need a hand, I'm happy to help
  22. Yup, either checking the part number printed on them or getting the car scanned with VCDS or similar should confirm the part number. The last digit is important in the case of MFSW buttons so I'd suggest replacing like for like if possible.
  23. Great! Out of curiosity, why did you downgrade it?
  24. @aki78 - I assume your car resets to normal as you've fitted a 'magic box' to fix it? I have a 3Q0907530L HW436 SW:4326 which currently doesn't reset to normal (remembers the setting). @Krosta - it looks like your 3Q0907530L gateway has been downgraded as HW442 is normally a AA, AC or AG index. Can you confirm that? Just need to find someone with a Q index
