Everything posted by Williami33
Trailer Assist
I was aware that it was possible to get Trailer Assist on a Kodiak , I just wondered if anyone knew if you can get it as an option on a Karoq ?
Trailer Assist
Does anyone know if Trailer Assist is available as an option on a new Karoq ?
Car Renewal Advice – Considering a Skoda Karoq (Lighting Question)
I would agree with Tilt we had Xenon headlights on our Yeti but the LED headlights on our Karoq are much better for driving
Map updates 2024 on 2019 karoq
Hi, Have you used a Mac to download the maps ?
Electric Swiveling Towbar retro fit
Hi I have an “Audi Protective Cap for trailer hitch swivel ball head” on mine when not in use , Audi part no 8r0803910 It is designed to let the water drain away when the ball is stored out of the way
Richter Automotive fitted the genuine ŠKODA towbar to my Yeti in 2012 , very friendly , professional and competent people
Extended warranty
I had to get both the struts on the electric tailgate replaced on our Karoq last year, all was covered by VWFS having taken out the “all in one package” . As our car is nearly 6 years old when the all in one package ran out I had no hesitation in renewing it , now means I have A manufacturer backed warranty cover until the car is 7 years 6 months old
Rear seat electrical connections
Hi Mike Sorry just seen this , did you manage to swap out the flaps ? I just raised the middle slightly until they popped out then manipulated them again in the middle to pop them back in Regards Will
All in One Policy vs Actual Practice at the garage?
If anyone is interested from 01 - 30 Nov there is 25% of the cost of the all in one package https://www.skoda.co.uk/owners/servicing-maintenance-offers
Hi Mike If it is the spring loaded flaps that are broken then you need to get the whole connector as I found out , the flaps are easy to swap across to replace the broken one’s To replace the whole connector is slightly more difficult as you have to take out a lot of the interior to get to it Regards Will
Skoda Citigo SEL 2019 or similar owners manual
Hi if it helps you can download one FOC from Skoda https://manual.skoda-auto.com/004/en-com/Models
Electric Tailgate
If you do specify an electric tailgate ensure that you have an extended Warranty , Both the struts on our car have been replaced over the last few months but covered by VWFS having taken out the “all in one package”
High beam assist stopped working
On mine on the Infotainment vehicle settings menu under light assist there is a box which must ticked for the high beam assist to work
Brampton Trev , thanks for your reply , Does anyone know the part number for this flaps?
Hi Did you ever find a part number for the broken flap ?
Am I thick?
If it is a Columbus then any formatted 64 GB SD card should work , I have a Columbus and use a Mac to download updated maps to , as the Mac generates spurious files I use “Clean my Drive “ to remove these files and have never had a problem with the updated maps loading
Am I thick?
Is it a Amundsen or Columbus you are trying to update ? If it is an Amundsen then you have to use a Skoda SD Card otherwise it won’t work
Adblue topup from pumps
I topped up on a pump last week cost was £1.79 per litre
Tow Bar Preparation (again - sorry.)
Trevor , we have a factory fitted tow bar on our Karoq, the fridge and battery charging function are all connected correctly as expected
Navigon updates
If you go on to the Skoda Update portal there is a paragraph on updating Garmin ŠKODA move and fun maps, I did ours, downloading the new maps to our Mac with no problem https://updateportal.skoda-auto.com/ Skoda_Move_Fun.pdf
Citigo garmin password
Not sure if this will help with your password problem! Anyone else If you go on to the Skoda Update portal there is a paragraph on updating Garmin ŠKODA move and fun maps, I did ours, downloading the new maps to our Mac with no problem https://updateportal.skoda-auto.com/ Skoda_Move_Fun.pdf
All Season Tyres for Citigo
Our Citigo has Goodyear 165/70 R14 (81) T VECTOR 4 SEASON G2 on it, we got them at Costco for less than £60.00 per corner, fully fitted. After 2500 miles we have had no problems with them.
Roof bars/rack for Karoq
I use Thule 127cm Aero bars and 775 feet that I used on my Yeti no problem
