Everything posted by Kenny R
Interior lights ON when Tailgate open
Ask the Skoda/VAG bean counters that removed it, and every year remove something else, such as only one umbrella supplied now, red lights in bottom of doors replaced with reflectors, carpet from glove box, etc etc.
Windows closed and doors tried to lock while driving.
Your trousers are too tight and you’ve operated the lock button on the remote Other than that I would check the wiring in the door bellows from A pillar to door for damage.
Things you wish you’d ordered with your Kodiaq!
Apparently basic digital dash now standard instead of analog dash. See post 13 in this thread.
Yes
Ending phone call
Yeah, that’s it. Previous Kodiaq had dedicated button, but new Sportline message comes up end call , pressing button B ends call. Note.. For those old enough to remember, pressing button B does not return coins if nobody answers.
Ending phone call
My previous SEL and current Sportline certainly has, just can’t quite remember which button it is as is instinctive to use, and I’m not in the car at the moment.
System updates
In addition to the number showing how many updates are available, if you drag down the bar at top centre of screen, a menu will show notifications of updates available.
Max Tow ball nose weight?
How to stop ECO tips
I used to get the nagging eco tip to turn stop/ start on in my Kodiaq, and never even crossed my mind to look for a setting to turn it off till I read this. Thanks, nagging eco tip now gone,
Thick question over personalisation
Did you opt for personalise / 3rd key option?
Kodiaq MY23 changes
Electric drivers seat is still standard on Sportline. £480 option to add electric passenger seat.
Yes heated front seats are standard on Sportline.
Kodiaq MY23 changes
If it is the biggest survey of car owners I get where @roottoot is coming from, you would think lots of owners on here would be saying that they voted, but not one has came forward, so it does make you think, who has voted.
"Skoda connect services have been deactivated"
Have you had the car more than a year. If so did you renew your Connect subscription?
2022 kodiaq sel exec seats
You wouldn’t need to have any worries with “leather “ seats in a Skoda as no animals are harmed in the making of the “leather”
Could you not fit seat covers?
Keyless Entry System... What's the mini key bit in the fob for? Where does it even fit?
On the later KESSY fobs the key part is also used to open up the fob to change the battery, instead of the previous method of butchering it with screwdrivers.
Low Mileage Skoda Octavia Hatch MK4 brake issues.
Autohold applies all 4 brakes, same as using foot brake. Can’t say I’ve seen many posts on here implying that this causes any widespread problems though. I agree not using the brakes or using lightly maybe exacerbates the problem.
Enyaq towing capacity???
From the brochure… Also has note at bottom stating that if tow-bar not factory fit, or factory tow bar prep option not chosen VIN plate could show zero towing capacity and will not be legal to tow, or have aftermarket tow bar fitted.
Just bought and think my car came with incorrect wheels
- No launch control on new vRS?
From owners manual… Select S mode deactivate ASR keep brake pedal depressed fully press accelerator release brake pedal- Email Messages
You can set up area notifications in Skoda Connect that will notify you if your car goes out with this area, sounds like this is what you have done.- Keep engine clean
There is an issue with the engine cover and they need to be removed. You should get a revised cover when they become available.- MIB3 Map Updates - again!
If you downloaded 21.11 on to a usb stick, it’s very wishful thinking that it will miraculously update your unit to 22.7- Stop Start
The ignition stays on when stop/ start cuts the engine, can’t see why it would cause any problems with dashcam. - No launch control on new vRS?
