Everything posted by Kenny R
parcel shelf - 7 seater Kodiaq
Decision Day
Exactly having 4x4 on summer tyres in winter just means you can spin 4 wheels instead of 2 Also a 4x4 will still slip and slide braking on snow/ ice same as any other car on summer tyres. So your golf on Crossclimate tyres would easily out perform your Karoq on snow/ice unless you fit all season or winter tyres of course.
How To Stop Our car being stollen throught OBD2 port ?
Even if they do break a window, the doors are deadlocked and won’t open.
Low coolant warning
What was the coolant level at when you purchased? Where was the level the last time you checked it. Where was the level when you checked it when the low level warning came on. Coolant level expands when hot and contracts when cold, so the cold weather could bring up low level warning if the level is at or below the minimum level.
They do, on the Kodiaq if you press the lock button on the remote, then press the KESSY lock indent on the door handle the indicators flash confirming KESSY is disabled. You need to use the key fob to unlock.
New My Skoda App
2 diabolical apps being merged together will make one doubly diabolical app
Change to MpH
The change from kph to mph on the maxidot definitely needs VCDS to change on a Yeti.
Karoq Family Pack
From the Karoq configurator, looks like you get tinted window in the Karoq and not the blinds the Kodiaq gets.
Skoda Online Configurator Issue
Just tried configuring some Karoqs on the configurator and appears to work for me. What model are you looking at and what options are you trying to add?
MySkoda support ends 10th December
So it will be twice as bad then
Which version?
There has been one, 700+HP and documented here....
Emergency braking with Winter Tyres and Winter-tyres mode engaged
As said all the winter tyres setting does is allow you to set a speed warning as winter tyres normally have a much lower max speed than the original summer tyres. It certainly doesn’t change any braking profiles or anything else.
Wipers
So an 17 3/4” blade on the passenger side instead of a 21” is quite satisfactory, I wouldn’t think so.
Wipers
Bosch A864S appear to consist of a 26” and an18” blade which aren’t the correct size for a Kodiaq. They appear to be correct for a Karoq if you know someone with one
Karoq Adaptive LED lights
The Karoq has the same AFS LED headlights as the Kodiaq. Only the Superb and new Octavia have the full LED matrix headlights. https://www.skoda-storyboard.com/en/press-releases/innovative-lighting-technology-for-maximum-safety-skoda-utilises-led-headlights/ The link I previously posted has the date 2015 on the bottom.
skoda roomster 12 tsi 2011 model
Most likely to be broken wires in the body to door loom. Plenty posts in the Roomster section how to repair.
Towing Eye
A rope with an eye in it or web sling you could choke through your towing eye and put the shackle on the other vehicle
Towing Eye
Would a smaller 1.5T D shackle instead of a bow shackle not be better idea. I would be throwing that bow shackle away anyway, especially if it doesn’t screw right in.
https://www.skoda-auto.co.in/models/kodiaq/kodiaq/kodiaq-adaptivelights
Strange I’ve never had any problems downloading map updates for my previous Yetis and current Kodiaq. I too have an ancient laptop and does take a while to download, but it’s never taken more than 3/4 of an hour to upload to the car, and the ignition hasn’t had to be on either. It can also update whilst driving and will carry on where it left off if you stop.
Wipers
It’s not even 1” when you compare OEM to Bosch
Wipers
Can’t see why you’d need a bigger than original blade.
Wipers
The Bosch passengers side blade is the correct size it’s only the driver’s side that is slightly smaller when compared to original. As said above it doesn’t make any discernible difference to the wiped area, and are streak/ noise free unlike the originals.
Banging from engine
It’s probably going to turn out to be something simple and a cheap fix, but you throwing money on a cambelt, clutch and flywheel that wasn’t required doesn’t make sense, especially your last comment.
Banging from engine
So has the clutch, flywheel and timing belt been replaced and you still have the noise? Would help if you said what engine your Yeti has.
